Question about Bosch Refrigerators
I have a bosch Integrated fridge model KIR38A40GB and the plastic fixings that attached the fridge door to the unit cupboard have all broken
  • 29 Answers
SOURCE: Bottom hinge on fridge door broken
Yes, there is supposed to be a plastic bushing/washer under there. Usually 1/8 inch thick. If a dealer is not handy you may cut some out of plastic to put there. Then undo the top hinge, and carefully lift the door off (you might want to empty the shelfs). Put your spacer on the hinge pin, and replace the door and the top hinge.
Posted on Jan 28, 2008
  • 518 Answers
SOURCE: fridge parts broken
Try checking HERE.
Hope that gets ya fixed up...
Geno
Posted on Mar 24, 2008
SOURCE: hotpoint fridge freezer / howdens kitchen - no instructions!!
Luckily the hotpoint helpdesk admitted that the instructions for hanging the kitchen doors does not come as part of the standard instructions. There should be a seperate piece of paper with these instructions.
After some to'ing and fro'ing they managed to email me the required diagram.
Posted on Feb 06, 2009
  • 441 Answers
SOURCE: Does anyone know what the part is called that
Its called the Panel kit,
Posted on Jul 07, 2009
SOURCE: fitting an integrated fridge freezer!
Hi Gareth. I fitted a door to my Hotpoint hsz2321L today. I used self tapping screws through the brackets into the fridge door sides. Looking at the old fridge that came out showed that this was the method used previously. No seal is broken and so the fridge is working perfectly. I do have an issue re-fitting the door onto the new fridge though. The pivot hinge on my fridge doesnt give enough clearance and so it catches on the unit at the side of it. The old fridge (a Bosch) cad cabinet hinges that would sort of concertina out to give clearence. Anyway, good luck.
Posted on Aug 01, 2009
How do I get the dimensions for a fridge freezer?
Looks like they are the same outer dimensions.
Old:
New:
  • Width of cavity: 560 mm
  • Height of cavity: 1772-1776 mm
  • Depth of cavity: 550 mm
http://www.appliancesdirect.co.uk/p/ckbc3150euk/candy-ckbc3150euk-integrated-fridge-freezer#maindesc
Oct 06, 2014 | Refrigerators
How do i fix my cupboard door to model IN TS 1612 UK
Hello there.
Why this is posted in Washing Machines I don't know !!!
Yes the Indesit user guide is no help eh ?
OK try these for how to do it. Should put you on the right track friend,
http://www.ukwhitegoods.co.uk/help/buying-advice/installation-advice/3493-integrated-fridge-and-freezer-installatio.html
Youtube http://www.youtube.com/watch?v=sMyiA_iAC1g plus others on there should help.
Good luck
Sep 10, 2014 | Washing Machines
Stench from back of fridge
Sounds like a regrigerant leak. Have it checked by an appliance tech.
May 26, 2012 | Siemens Bosch Neff Integrated Fridge...
Door falls open
The side spring springs could have unhooked. Some springs connect to a nylon rope that slides over a plastic guide. The rope could also have snaped or slipped off the guide. You need to open the sides (normaly the back first) to check. This is easy to fix if you have the right tools...
May 11, 2010 | Bosch 24 in. SHU66C05 Stainless Steel...
Broken catch
what has happened is that the ridiculously flimsy plastic that the catch spring pushes against has snapped off. I tried getting it plastic welded but still too weak finaly I took off the door unscrewed the transparent central part(remembering to keep the little black plastic rod at the top that operates the microswich when the door closes then snapped off a piece of hacksaw blade about15 mm long and put it where the plastic had been. I carefully lifted the end of the spring over the blade and while holding it screwed back the transparent part so that it held the blade in place. Works really well!
Jan 14, 2010 | Smeg WDI12 Front Load Washer / Dryer
When doors are opened it stops. Ice is forming unnaturally in the
It sounds like you may have a bad evaporator fan motor or broken blade.
Another cause could be a failed defrost system component. The would cause a build up of ice and frost and the fan blade could be coming in contact with the frost or ice.
The fan stops running when the doors are opened on this model to prevent the circulation of warm air.
Sep 11, 2009 | Bosch Refrigerators
Door on my integrated Bosch fridge keeps opening
Seals rarely fail most likely needs hinges replaced,parts quite cheap
Jun 16, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Fitting an integrated fridge freezer!
Nov 23, 2008 | GE Profile GCG1700LII 15" Built-In Trash...
Refrigerators Logo
37 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
