Question about Universal Power Group 24V 5A Universal Scooter Power Wheelchair Battery Charger
I have not used my go.go elite traveller plus for several months now,and when i went to switch it on the battery light would not come on.I have tried charging the battery and the power light illuminates but the charging light does not illuminate,I have tried pressing the reset button and still no joy. hope to hear from you soon Mrs.Ann Teasdale
  • 692 Answers
Ann You probably have a problem with the charger and your batteries. If it has sat for several months and wasn't charged during that time the batteries are too low to be charged and the charger cannot pickup the charge on the batteries. Now check the charger to see if it has a fuse if it does check the fuse to make sure it is good If the fuse is ok then if Charlie has a voltmeter he cqn check the output of the charger at the 3 prong plug set the meter to 200 volts dc and touch the 2 outter pins of the plug careful not to touch the barrel of the plug. the voltage should be 27+ volts output. If you aren't getting any reading then the charger needs to be replaced. Hope this helps
Posted on Mar 21, 2011
Scooter won't start
hi, so has the fuse blown again ???
Regards
Rob
www.gewizrepairs.co.uk
Mar 11, 2014 | Pride Go Go Elite Traveller Plus HD 4...
I have a go go elite traveller plus , the battery pack will not lift off my scooter it seems to be stuck , i need to replace the batteries
The manual for this scooter is at http://www.discovermymobility.com/store/scooters/summit-scooters/elite-portable-scooter/manual.pdf
The closest info I can find is page 14. MOVING AND TRANSPORTING YOUR Easy Travel Elite
6.1. Moving Your Easy Travel Elite in Freewheel Mode when unfolded:
The Freewheel switch (Fig. 1/17) is used for releasing the brake and moving the Easy Travel Elite without operating the motor. Before activating, make sure your Easy Travel Elite is switched on. Turn Freewheel switch to the "freewheel" position and push or pull the Easy Travel Elite manually.
NOTE: The Freewheel mode can only be activated after the battery is in place and the power switch (Fig.9/1) is turned on. Doing otherwise will cause a fault situation indicated by rapid flashing of the Indicator light (Fig. 9/4). See section 4.2.
WARNING: The Freewheel switch should never be engaged on a slope.
CAUTION: The seat back must remain in the upright position.
They seem to assume removal is obvious, I would check any connections from battery to scooter are pulled out and that freewheel mode is not engaged.
Oct 07, 2013 | Pride Mobility Products Go-Go Elite...
Pride go go elite plus stops when going up inclines
batteries heading for replacement, to much weight, controller fault, are the most lightly suspects.
Aug 19, 2013 | Pride Go Go Elite Traveller Plus HD 4...
I am travelling by air next week and I need to know the serial no. of my scooter. Where do I find this. I have a 4 wheel Go-Go Elite Traveller Plus Hd
hi , its located on the bottom part of the seat stem , you will need to remove the seat and battery pack to see this,
Regards
Jan 25, 2013 | Pride SC53HD GO-GO Elite Traveller Plus HD...
My father-in-laws gogo will be not used for several months while he's in florida. how should the battery be stored/charged while not in use?
Charge the batteries fully and remove the battery pack from the scooter. About once a month charge the battery pack. It shouldn't take long to charge since you are not using the scooter Don't overcharge when the light on the charger turns green turn it off and unplug it from the battery pack. This should keep the batteries fully charged and fresh when FIL gets back home. Hope this helps you
Oct 04, 2010 | Pride Mobility Products Go-Go Elite...
The new batteries that we bought for our gogo elite do not stay charged for more than 15 min of use. The batteries are only 3 months old
battery cells damaged
replace
it
its in warranty even if its not og
other third party battery makers give 6 month warranty
Jun 03, 2010 | Pride Mobility Products Go-Go Elite...
I have an Elite Traveler Plus. The batteries are dead. I plug in the charger and the light indicator is green (saying charge is ok)? but the batteries are still dead. Batteries have been drained for a...
The batteries will not accept a charge, therefore the charger things they are full. When a battery sits for that long then they drain beyond the point of repair.
Dec 09, 2009 | Pride Mobility Products Go-Go Elite...
Universal Power Group 24V 5A Universal Scooter Power Wheelchair Battery Charger Logo
283 people viewed this question
Top Universal Power Group Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Universal Power Group Health and Beauty Expert? Answer questions, earn points and help others
