Question about Hotpoint WMA33 Front Load Washer
I have taken over by moving house this machine. No papers with it. Possible to receive instructions about : 1- time saver 2- hand wash 3- "one" ????????? Would be much appreciated
    Brigadier General:
  • 6,277 Answers
You need a manual!
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C.
Posted on Mar 21, 2011
Testimonial: "thank you very quick to reply"
Black scum forming forming on rubber seal on inside of washing machine door
  • 1 Put on rubber gloves and safety glasses before commencing the cleaning process.
  • 2 Lay an old towel or drop cloth on the floor under the front of the washer to prevent floor damage as you clean.
  • 3 Fill a plastic cup with bleach and dip a tooth brush into the bleach.
  • 4 Remove the toothbrush and scrub the washing machine gasket with it to remove the black mold from it. Hold the gasket open with the fingers of your other hand so that you can clean the center grooves of the gasket where the most mold is likely to grow.
  • 5 Rinse the toothbrush in the cup of bleach and continue cleaning until you have removed the mold from the entire gasket.
  • 6 Wipe the gasket with a paper towel to remove excess bleach residue and any remaining mold.
  • Jul 02, 2011 | Zanussi Washing Machines
    Even There are not papers inside the printer, at start I receive the message Paper Jam. In maintenence mode, the message is Error code 36. I tried to unplug few times, same thing. I don't know what to
    Two possible causes.
    1. There is paper jammed in the purge unit or on the left side of the machine. Move the print head by hand to the centre of travel and look inside at the ends of the head travel path. You might see paper jammed in there.
    2. If there is no paper, you will have to take the machine apart and check the encoder strip on top of the head. It should fit into a slot on top of the head. If it is not in the slot, carefully reseat it into the slot, reassemble and test.
    There are other more remote causes but those are the two common ones.
    Apr 22, 2009 | Brother MFC 420CN All-In-One InkJet...
    Phone diverts to machine after just 3rings
    Hi, Here's the instructions to change # of rings. You will see that in instructions below, numer 1 says press w, actually what you press is not a w, it looks like three lines. I will also give you a link for the manual as it has good photos on page 23.
    http://safemanuals.com/brand-user-guide-instructions-owner-manual/DORO
    Scroll down to the box that says, select model number, then scroll to 830R. You will have to enter the 4 numbers into the page before downloading but it's easy.
    Good luck. If this helps you plz rate it 'fixya' for me. Thank you kindly.
    Number of Rings
    The number of rings before the answering machine answers can be selected between
    2, 3, 4, 5 or TOLL SAVER.
    1. Press w.
    2. Scroll using < </> > until a fl ashes in the display. Press 0.
    3. Press 0 repeatedly until the display shows 3/5.
    4. Scroll using < </> > to the required setting (2, 3, 4, 5 or TOLL). Press 0 to
    confi rm setting and move to the next programming sequence, alternatively.
    5. Press w to exit the Menu system.
    Jan 23, 2009 | Doro 830R Cordless Phone
    Moved into new house need set of instructions
    Try this. I'm not sure if it applies to your model.
    The reset sequence used is:
    1) Crack the door open.
    2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
    3) Close and latch the door
    4) Press the cancel button (the circle with the triangle in it)
    Jan 19, 2009 | Kenwood KW85 Air Conditioner
    Xerox Copycentre C123 Creating a Ghost Image
    First place an original on glass and make a copy -- mark #1. With that same original on the glass, move the exposure all the way light and make a copy -- mark #2. Again with the same original on the glass, move the exposure all the way dark and make a copy --- mark #3. Place #1 in the middle so the the copies read --- #2, #1, #3. The #2 should be the lightest and #3 being the darkest. If #2 is darker than #3 you have a developer problem and you need to call for service. If #1 and #2 are bad and #3 is a good copy your machine probably just needs a good cleaning, mainly the optics and charge units. If all 3 copies are still poor with the speckles, your are looking at the PCU ( photo conductive unit) also called the drum unit. You can order this unit online -- it is a customer replaceable item.
    Jan 04, 2009 | Xerox CopyCentre C123 Black and White...
    Indesit Prestige Line 822
    i have this! 4 is a normal wash cycle 7 is a spin 5 an 6 seem to be quick washes an never tried 1 2 or 3!!! hope this helps!!
    Jul 20, 2008 | Washing Machines
    Moldy smell in washer
    run cycle using bleach only in water after cycle use a bleach/water solution to thoroughly wash door seal be sure to pull seal at bottom of drum opening and clean inside lip in future leave door open as much as possible between cycles just remember YOU ARE NOT ALONE..all front loaders no matter the brand have same issue some just worse than others
    Jun 18, 2008 | Kenmore Elite 45986 Front Load Washer
    Wma54
    will help type this into a search engine it the user manual !http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WMA50_WMA52_WMM53_WMA54_WMA56_WMA58_WMM59_small.pdf
    Feb 15, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
    Frigidaire FWT647GHS0 Front Load
    you have a bad rear bearing in the rear housing the rear housing is a warrenty part for life on the part but there is parts that should be replaced at the same time expereance guy can do it in about 2 3 hours if not chould be a long hard prosses
    Dec 26, 2007 | Frigidaire GSTF1670A Front Load Washer
    Top loading washer whirlpool
    When we move the drum, even with our hand, about 1/2 way through, there is a loud clicking, popping type noise? Sounds like a train is coming through the house before it stops the cycle?
    Dec 20, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
    Hotpoint WMA33 Front Load Washer Logo
    41 people viewed this question
    Top Hotpoint Washing Machines Experts
    vince
    Eric Taylor
    ptpumpman
    Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
