Question about RTO PasLode 900420 Impulse Framing Nailer
I have taken apart my paslode impulse framing nailer to remove a nail that had got lodged in the nail channel,i removed the lodged nail,but now have a part and a small spring that im not sure where they have exactly come from,i think it my be the lockout bar(40 on schematic)and spring 80.but cannot work out where these parts go!any help would b appreciated!cheers.
  • 2,176 Answers
They go under the plate where the follower is. What you need to do is remove the screws that hold the channel to the side where the follower is located and then lift the steel plate up. Pull back on the follower and the lockout bar and spring fit into a recess that you will see (once you get it to this point you will see what I am talking about), set the spring and bar into the recess and push it a couple times to make sure installed properly. replace the laarge steel plate and hold in place while reassembing the nose piece (4 screws, 2 on each side) and then reassemble the rest of the tool. Let me know if you need more assistance. If I have helped you would you please vote accordingly, Thank you
Posted on Mar 21, 2011
Have taken gun apart ,and now can remember how it all goes back together , when nailing the thing that slides was jamming , now apart there are 2 pins im not sure where they should be
Go to this site. www.ereplacementparts.com
Look up your gun, they have parts for it there...
They also will have an exploded diagram of your gun so you can see how it goes together.
heatman101
Apr 18, 2011 | RTO PasLode 900420 Impulse Framing Nailer
I have pulled my impulse nailer apart so I can replace the nail tension spring in the handle and am unsure how to remove the clip that keeps the tension
it is a push on nut and to remove you would probably damage the nut along with the button that it is pressed on, if you can cut the push on nut you would at least save part of tool. after replacing spring I used a socket and GENTLY tapped the push on back into place to secure it.
Feb 21, 2011 | RTO PasLode 900420 Impulse Framing Nailer
Paslode Impulse Framing Nailer won't operate
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
May 10, 2010 | Omega Paslode 901000 Impulse Cordless...
I TOOK IT APART & CAN'T GET IT BACK TOGEATHER
it goes under the side where the follower is, you will need to remove the cover on that side and pull back the follower, you will see the slot where it rides, also there was a spring that pushes it out of the way. I suggest going to Paslode.com for a parts breakdown. Let me know if I can help further.
Jan 24, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Cleaned impulse framer 900420 put in new fule
If this is a framer there isn't a lockout for it. you would need to pull the front assembly to remove a jammed nail or look for problem.
Oct 20, 2009 | RTO PasLode 900420 Impulse Framing Nailer
I can't put mt paslode finish nailer back together again
go to Paslode.com and you can download a manual that shows the spring. It sits in a recess under the follower that pushes the nails
Jul 20, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode framing nailer loss of power.
Here's what I found at the Paslode Troubleshooting Site:
Tool will not cycle - fan runs, indicator light
is solid green.
Lockout bracket is stuck in lockout position.
Work-contacting element is bent, or build-up of
debris in track restricts operation.
Follower is not behind fasteners.
Fuel Cell empty.
Spark wire out of spark plug.
Spark plug is dirty.
No spark is generated.
Check lockout.
Remove and inspect lower probe. Clean and
lubricate track with Paslode Impulse® oil.
Repair or replace lower probe as required.
Position follower behind fasteners.
Replace fuel cell.
Remove cap and check spark lead, insert in
spark plug and replace cover.
Clean tool cylinder head and spark plug.
If this doesn't work, I suggest contacting Paslode directly 800-222-6990
Mar 11, 2009 | RTO PasLode 900420 Impulse Framing Nailer
RTO PasLode 900420 Impulse Framing Nailer  Logo
598 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
