Question about Bosch Exxcel WFO 285S Front Load Washer
Makes noises when spinning - Bosch Exxcel WFO 285S Front Load Washer
    Brigadier General:
  • 6,277 Answers
Balance
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Mar 21, 2011
Noise while spinning
My 90 series kenmore washer. At the start of spin,makes loud clicking noise while it spins. Than it stops after a min. I changed the coupler. Still makes noise.
Jan 05, 2014 | Washing Machines
I have a westpoint washing machine wen it is spinning it make a lot of noise serial number wtw 500. it is a 5kg. can you help me with this problem.
Thanks for choosing FixYa and welcome to the site. You need to check your spin bearing and the motor drive. If the noise is only during spinning, you need to check these. Anytime a washer makes loud noises during spinning, always check the spin bearing and motor drive.
Apr 24, 2011 | Washing Machines
Makes buzzing noise and won't spin or drain
Sounds like something is stuck in the drain pump.  If nothing is stuck in the pump replace the pump.  It won't spin until it drains, so fixing the drain problem will fix the spin.  You can get at the drain pump by taking off the bottom panel.
Dec 19, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer makes a lot of noise during spinning
we need the brand and the model
but for starters, please check on the links below.
http://forum.appliancepartspros.com/washer-repair/4501-washer-makes-extremely-loud-noise-during-spin.html
http://www.thestuccocompany.com/maintenance/Washing-Machine-noise-during-spin-cycle-169980-.htm
http://www.askmehelpdesk.com/appliances/washing-machine-noise-during-spin-cycle-167960.html
Sep 10, 2009 | Whirlpool Washing Machines
Tub makes loud thumping noise when spinning
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
May 02, 2009 | Washing Machines
Washing machine making whining noise during spin only
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Apr 11, 2008 | Washing Machines
Washing machine making crackling noise when spinning
check for some loose items underneath the unit. washing machines normally reverses its rotation when spinning. check if mechanical solenoids pulls the right levers as it starts to spin....
Feb 12, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Bosch Exxcel WFO 285S Front Load Washer Logo
55 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
