Question about Emprex LM1704 17" Monitor
My lm1704b monitor only works occassionaly, when i start up the computer i can hear the speakers crackle and the light flashes green on the front. When i plug the computer into another monitor it works perfectly.The problem seems intermitent, i unplugged the power and vga and it worked, but this trick isnt working now.
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, this unit needs to go in for repair.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 21, 2011
  • 11,361 Answers
Look for bad caps as suggested by ST11, you can also learn ore about what to look for inside the monitor, also make sure to use low ESR type caps for the repalcement.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
2005 jeep grand cherokee dash lights flashed on and off and now speakers do not work
cluster dead, and warnings in the cluster are dead.
so does car drive perfectly in the day?
yes.' now.
if all things work but one thing, we check fuses first.
all cars for 100 years same deal.
crackle from radio. ok.
this is the 05 GC and wiring is very complex. I have 2010.
surely you can tell what works an not.
and matters big time.
I say get it serviced, like the 99.9% do.
unless you can post full set of symptoms.
Oct 02, 2016 | 2005 Jeep Grand Cherokee
I just bought a speaker for my computer but i can't hear sound from two of speakers ! how can i solve it ?
if your sound is not working you can check that the plugs are in the computer correctly usally there are green and pink ends on computer speakers green indicating goes in the green slot and pink in the pink some people often gets confused and there are sometimes on new modles a blue slot that can look green in low light i would suggest checking they are plugged in correctly to the computer preferably in the back and not the front if the front option is avalible and check the appropriate drivers are installed on the computer to use the speakers
Jan 19, 2012 | Logitech X-530 Computer Speakers
Can I use the my old HP speakers with my new HP? The old speakers have a peach, not green, material around the jack. The speakers that are built in with the monitor are working, but I think the old...
If the speakers are detachable from the monitor then try to put it in the jack where you usually put your speakers if you hear any sound it should work .the color coding is usually green but its not mandatory .
Mar 28, 2010 | HP Compaq Computer Speakers
Monitor light flashes green and screen is blank
Best thing to do, hook up another known working monitor to the computer and this will verify that the computer is working properly.
If you get video on the known working monitor when you turn on the computer then you know the computer has a problem.
Aug 27, 2009 | Computers & Internet
Front speakers not working on hyundai accent
check wiring in door hindge area for breaks move around loom while listening to radio to hear if speakers start to crackle or work
May 27, 2009 | 2000 Hyundai Accent
Can not hear sound
Try going to support.dell.com and entering your Service Tag. Then click on drivers and downloads and download and install the audio driver that they currently recommend for your machine. Sounds like a driver problem and something that wasn't set properly after the computer was reset.
May 27, 2008 | Dell A215 Computer Speakers
Automatically turns off and on withing 2 secs
the power button board is electronically fried you need a new one
May 07, 2008 | Hyundai ImageQuest L50S 15" LCD Monitor
Picky speakers
uninstall then reinstall adobe flash player. see if it works.
Feb 14, 2008 | Dell A215 Computer Speakers
Emprex LM1704 17" Monitor Logo
406 people viewed this question
Top Emprex Computers & Internet Experts
David Payne
David Payne
Are you an Emprex Computer and Internet Expert? Answer questions, earn points and help others
