Hello The LG WF-T9230TP washing machine make a knocking noise when spinning. Looks like the outer tub in knocking against. Might be the stabaliser rods Regards Russell
    Brigadier General:
  • 6,277 Answers
Balance first!
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Mar 21, 2011
Sounds like a screw or similar spinning on the spin cycle but can't get the screw out of my fuzzy logic 6.5kg WF-T652 washing machine. Don't want to force it... left or right. ??
watch the videos
Search Results
LG washer - Inner Tub Assembly replacement - Diagnostic & Repair ...
? 1:01
https://www.youtube.com/watch?v=vTKJFuKuUZg
Apr 30, 2015 - Uploaded by ApplianceVideo.com
WT1001CW LG Washer, Visit us at http://www.appliancevideo.com Do-it-yourself diagnostic and repair videos ...
ApplianceJunk.com - LG Top Load Washer Removing Bearing ...
? 4:17
https://www.youtube.com/watch?v=osTIeI7BIMI Dec 15, 2011 - Uploaded by ApplianceJunk
12:56. LG washer - Inner Tub Assembly replacement - Diagnostic & Repair - Duration: 1:01. ApplianceVideo ...
LG Top Load Washer Wash Plate Replacement #AGZ72909702 ...
? 1:39
https://www.youtube.com/watch?v=HBw4DvtrIjs Apr 11, 2014 - Uploaded by RepairClinic.com
This video provides step-by-step repair instructions for replacing the wash plate on a LG top-loading washing ...
lg wf t652 washing machine remove drum Google Search
Apr 01, 2018 | Washing Machines
LG 7.5 wd-10165fu when spining on 1000 makes a noise like its touching against the side of the machine
If tub is banging around it could be dampers, but if it's a scrapping sound then something is caught in the inner tub and at hi speed it touches the outer tub.
Apr 23, 2017 | LG Washing Machines
Have a lg direct drive front loader model wd11020d makes a knocking noise and after a while an Le error comes up, pulled the back of all looks in good condition
Open front door. Pull push on inner drum and see if it wiggles independent of outer drum. If it does, then the knocking is a bad bearing or spyder(part that hold drum to bearings). If inner tub is tight, then I'm not sure issue. LE error is a Rotor Position Sensor error.
Jan 30, 2017 | LG Washing Machines
Lg wf-t9230tp is not pumping
Open small door at bottom front of washer. get a pail and put small black hose in pail and remove plug. After machine is drained remove large screw cap. probably a sock or something in trap remove and put back in place.
Apr 23, 2014 | Washing Machines
Noisy on spin cycle
It's very difficult to advise on a noisy washing machine because you can't describe noises accurately enough. People often describe the same noises quite differently.
Generally though, if a washing machine is rumbling, and noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on washing machines due to water getting into them if the drum bearing seal fails. To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings have probably gone.
Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure is a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust.
Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as they coins get tossed around inside. Usually, spinning the drum by hand will not reproduce the noise in the case of coins as the coins drop to the bottom of the tub when the washing machine isn't spinning.
A light scraping noise when the drum is turned by hand is usually a bra wire trapped between the tub and drum.
A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
A knocking noise can be a loose tub weight. This would be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk.
Jul 28, 2012 | Roper Washing Machines
Noisy drum bearing also play on drum
Apr 30, 2011 | Washing Machines
Noise from drum
This is difficult to work out as there are so many different symptoms. Here are my thoughts -
Dust from carbon rushes is black. Grey dust usually comes from a loose concrete weight. Loose tub weights are rare on this model but they cause a loud knocking noise which is often worse when the washing machine is revving up to spin and dying down from a spin (suspension problems are also often worse at this safe too). It's not normally a metallic sound though.
If the noise is coming from the motor banging against the sides of the machine then it will make the machine move when it happens. The whole machine may jump or move to one side. The motor often thumps the side of the washing machine on Hotpoint washers where the motor is fitted at the top of the tub and over to the right hand side. This is a daft place to fit a motor and only .I think they've eventually stopped now though.
It is normal to be able to push the drum to the side so that the motor hits the casing. If the suspension has gone, the tub should be twisted and leaning to one side more than the other or it just could be very loose. It's difficult to check suspension if you don't know how it should feel.
If the noise is coming from the inner drum hitting the heating element or throwing an object like a £1 coin (trapped between the inner drum and the outer tub) around, then the washing machine will be stable but the noise would still be a horrible metallic knocking. This is one cause I suspect.
Thank you for contacting Fixya.com
Aug 30, 2009 | Hotpoint Aquarius WMA52 Front Load Washer
When washer agiates it makes a loud squeaking noise, what can it be?
Aug 30, 2009 | Washing Machines
Drum banging is it bearing when on spin
Aug 29, 2009 | Zanussi FLA1001W Front Load Washer
Loud banging noise when machine goes into spin mode. sounds like it is banging on the side. Please help !
Usually this is an out-of-balance condition caused by too much weight on one side of the tub, move the clothes around and try again.
Apr 26, 2009 | Washing Machines
Washing Machines Logo
187 people viewed this question
Top Washing Machines Experts
