How much water do I use when using a front loader say 5 items of clothes with 3 large towels and two sweater
  • 29 Answers
Many front loader washing machines don't have different water level options since they cycle the water differently than the "tub-o-soap" upright washers. The best answer I can give, if there are different fill settings, is to put the laundry in the machine and see how full it looks. Err on the side of overfilling, since the towels will soak up a lot of the water, and unless the sweaters are delicate or inclined to stretch out badly, I'd opt for an extra spin cycle to get rid of the excess water soaked up by the towels and sweaters.
Posted on Mar 21, 2011
Clothes come out dirty in front loaded washer
Check the level sensor at the rear of the drum.
May 16, 2017 | Whirlpool Washing Machines
My washer has a mildow smell and my clothes smell musty, especially towels!
This is a comin in all front loaders. It it caused by two things not using HE soap and keeping the door closed when not using it. The only way to get rid of the smell is to run 3 to 5 cycles with bleach and no clothes or use a washer cleaner. Most large hardware stores carry them. Once the smell is gone be sure to leave the door open when you are not using it and wipe out the gray boot(gasket/seal) after using.
Jun 03, 2011 | Kenmore HE2 Plus Front Load Washer
My washer bangs and goes off balance in the spin cycle. It has been leveled and is not off balance.
Without knowing the type of washing machine that you are using I can tell you generally that:
First make sure that the washer is level. There should be leveling legs on the machine that you can screw or unscrew to level it.
And that there are several causes of this problem.
1. Load is too large for the machine. Be sure not to stuff the washer full. The items should have room to move around.
2. Items being washed are not of similar weight so that they unbalance easily (Wash jeans with jeans/knits with knits/towels with towels)
3. Items are poorly loaded (in a top loader). Distribute the items well.
4. Front loading washers on platforms with drawers,etc. are very prone to this problem. We finally took our off the drawer/ platforms and the problem went away. After a couple of service calls that helped not at all.
5. Front loaders sometimes have this problem if they are installed on a "soft floor" such as Laminate flooring. You can help this by placing a thick rubber-backed rug or a piece of plywood underneath your machine.
These are the solutions that I have learned from my own experience. I hope that these ideas help you.
Dec 21, 2010 | Washing Machines
I have a kenmore front loader Model #11047512601 Type 832 and it will not wring out the clothes proberly I have an f code can you tell us what is wrong please.
An f21 code indicates that there is something blocking the drainage system. could be something clogging it like mine did. My problem was a washcloth stuck within the drain. My fix was to remove front panel below door using a 1/4" driver to remove 3 screws. You will need a 5 gallon bucket, towels to soak up water, and a pair of channel lock or large pliers to remove drain cap. let remaining water drain into bucket. remove large spring clamp holding rubber boot to drum housing and check to see if anything is in there. that was my fix. good luck
Nov 20, 2010 | Kenmore Elite 45986 Front Load Washer
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
Is fading and shrinking my clothes
low temperature and low rpm of motor,must try this.
Feb 16, 2009 | Frigidaire FTF2140F Front Load Washer
Mildew smell on cloths
The brand of your front loader is not that material on this issue. What is happening is that your old top load washer may have used as much as 45 gallons of water per cycle, while some front loaders use as little as 12. Because of the low water use, you must cut back on the additives you are using. Use only 1 tablespoon of HE detergent (even less if 2x or 3x detergent) per load. If you use fabric softener, use only 1 teaspoon per load. Odor on clothes after wash is indicating that the detergent and or softener has not been fully rinsed out. If you throw a load of washed towels into your machine and start a cycle without any soap, then stop the cycle, you should not see any suds. If you do, there is obviously soap left in the clothes. With bath towels, the towels are used to absorb clean water off a clean body. They do not need soap when you wash them, and never use fabric softener on towels.
If your washer is a LG WM-1832 it has a assessable filter behind the access door on the lower left front of the machine. Clean that out first, and if it has a tub clean or sanitary cycle use that cycle (if not, use hottest longest cycle available) with 3 Affresh tablets or use whirlaway to clean out the washer outer tub (the not visible tub that holds the water). You might want to use another cycle like that with bleach to head off mold or mildew growth. Use of proper amount of detergent and fabric softener should really help the clothes odor issue from then on. Also check the tub seal at the bottom of the door area to clean out any lint from drain hole areas to help prevent water from remaining in the tub seal area.
Oct 28, 2008 | LG WM-1832C Front Load Washer
Odors on the clothes after washing in Maytag front loader
Oct 23, 2008 | Maytag EPIC MFW9700S Front Load Washer
Beach towels sopping wet after machine done spinning
The washer will not proceed into high speed spin with just two large beach towels in the basket. The washer is detecting a out of balance condition, and remains in low speed spin. Solution? Try adding more items into the basket. With only two towels, there is not enough mass to balance the washer. With more clothing or towels, there is more items for the machine to balance, and reach full speed spin.
The only other thing that could cause this, would be if the water in the tub is not completely draining in the time allowed. This washe does not have a cleanout, and checking for an obtruction in the pump is difficult. I would go with the more clothes first, then see.
Sep 25, 2008 | GE WSXH208A Front Load Washer
Clothes have a mildew smell
Hello billpmm,
You are not alone with this problem. Seems that that everyone of the front loader washers exhibit similar characteristics .. the short story is that in order for a washing machine to be a front loader, they need to be water tight .. being water tight, they are also air tight and herein lies the problem.. any water left over from a wash cycle will sit in gaskets , nooks and crannies and eventually develop mold or mildew.. here is a link to product you may find that solves your problem
http://www.smellywasher.com/
or.. you can use the AFRESH tablets sold in Home Depot and other home improvement stores.. in either case.. these products will help rid that musty mold out of your washer..
Sep 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
70 people viewed this question
Top Washing Machines Experts
