Question about Elite Microwave Ovens
Kenmore elite microwave is not working. code F3H apeared after trying to run "baked potato" setting. no functions operate, display screen functions normally.
I unplugged the microwave for a few inutes, and let it reset itself. found solution on another site that DID NOT CHARGE ANYTHING for people to share solutions with each other!!!!!!!!!
Posted on Aug 03, 2008
Samsung Microwave Mod # SMH9187ST. Starts on its own, "bake potato" on display screen. After shutting down, code SE appears on screen. No response from keypad until unplugged. Reset and problem ret
Contact Samsung, I was having a similar problem with the SE error appearing on my microwave. Apparently its a problem with the control panel and they are going to replace it free of charge under there epidemic warranty
Mar 18, 2013 | Samsung SMH8165W Microwave Oven
Microwave won't restart after baking potatoes.
If your microwave is not a convection then the moisture most probably is somehow getting to the controls as potatoes has quite a bit.
Oct 27, 2017 | Emerson MWG9111SL Microwave Oven With...
GE microwave not heating, sensor error.
first suspect is the inverter board (power) and magnatron a distant second----in either case the part involved unless an expensive unit is pricey.
Aug 26, 2012 | GE SpaceMaker Microwave Ovens
Whirlpool Microwave error F3H
F3H Humidity sensor failure 1. Unplug microwave oven or disconnect power.
2. Connect a new sensor to the board (at P5).
3. Plug in microwave oven or reconnect power.
4. If no failure code appears when starting sensor function:
 Replace old sensor.
5. If failure code appears when starting sensor function:
 Replace power supply board.
6. Plug in microwave oven or reconnect power.
Aug 04, 2010 | Whirlpool GH5184XPQ Microwave Oven
Baked potatoes went up in flames now microwave has no power no lights. power outlet has 110v ac
Were the potatoes wrapped in foil? If so, the megatron tube was burned out. Replace unit.
Nov 06, 2009 | Kenmore 62622 Microwave Oven
Kenmore Elite microwave Combi funtion not working
Unplug the unit for 1 minute to clear the ECU.
re-plug, and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 29, 2009 | Kenmore 62622 Microwave Oven
KENMORE ELITE MICROWAVE
F3H is a humidity sensor error.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again. If that doesn't work, leave it unplugged for maybe an hour.
If it still fails, you have a bad sensor.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Nov 01, 2008 | Kenmore 62702 Microwave Oven
Microwave troubleshooting
I found the fix to the F3H error on another site. Just turn the power to the microwave off for ~2 minutes at the circuit breaker, and then turn it back on. Microwave will start working again then.
Feb 23, 2008 | Whirlpool GH5184XPQ Microwave Oven
Microwave Ovens Logo
157 people viewed this question
Top Elite Microwave Ovens Experts
William Miller
William Miller
Are you an Elite Microwave Oven Expert? Answer questions, earn points and help others
