I m using compaq presario cq40. when i opening my lapy igetting massage on screen ( windows 7 ,build 7600, this copy of window is not genuine) and my screen in black. so pl help mi about this.
  • 629 Answers
If you have a genuine copy, make sure your date and time settings are correct and try last known-good configuration if available else repair or reinstall your OS installation
Posted on Mar 21, 2011
  • 508 Answers
Try this program:http://www.softpedia.com/get/Tweak/Unins... and disable automatic updates: START-> CONTROL PANEL-> AUTOMATIC UPDATES -> CHOOSE THE OPTION -> Turn off automatic updates <- ;-) ....
Posted on Jul 25, 2016
Remove wat could not solve my window is not genuine build 7600 problem give me another aolution
Windows 7 Build 7600 by default will not allow you to do an upgrade install.
This how to will describe the process needed to upgrade from Windows 7 Build 7100 to Windows 7 Build 7600 with out doing a clean install.
Download the ISO as you did previously and burn the ISO to a DVD.
Copy the whole image to a storage location you wish to run the upgrade from (a bootable flash drive or a directory on any partition on the machine running the pre-release build).
Open the file cversion.ini in a text editor like Notepad
Modify the MinClient build number to a value of 7100.0
Save the file in place with the same name
Run setup like you would normally from this modified copy of the image and the version check will be bypassed.
bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB.
1. Insert your USB (4GB+ preferable) stick to the system and backup all the data from the USB as we are going to format the USB to make it as bootable.
2. Open elevated Command Prompt. To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter. Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command:
DISKPART and hit enter.
LIST DISK and hit enter.
Once you enter the LIST DISK command, it will show the disk number of your USB drive. In the below image my USB drive disk no is Disk 1.
4. In this step you need to enter all the below commands one by one and hit enter. As these commands are self explanatory, you can easily guess what these commands do.
SELECT DISK 1 (Replace DISK 1 with your disk number)
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
Don't close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Insert your Windows DVD in the optical drive and note down the drive letter of the optical drive and USB media. Here I use "D" as my optical (DVD) drive letter and "H" as my USB drive letter.
6. Go back to command prompt and execute the following commands:
D:CD BOOT and hit enter. Where "D" is your DVD drive letter.
CD BOOT and hit enter to see the below message.
BOOTSECT.EXE/NT60 H:
(Where "H" is your USB drive letter)
7. Copy Windows DVD contents to USB.
You are done with your bootable USB.
You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).
Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
http://100-downloads.com/publisher.php?pb=http://www.microsoftstore.com/store/msstore/html/pbPage.Help_Win7_usbdvd_dwnTool&dl=727
http://download.cnet.com/windows-7-usb-dvd/3000-18513_4-10972600.html
Create a copy of your Windows 7 ISO file on removable media
Sep 27, 2013 | Compaq Presario CQ62-209WM Athlon II X2...
My window is not genuine window7 build 7600 this
Aug 01, 2013 | Computers & Internet
Windows 7 build 7600 This copy of Windows is not genuine,
Sep 01, 2012 | Computers & Internet
Windows 7 build 7600 this copy windows is not genuine?
The serial key that you used to install Windows is not valid, and cannot be used. If you used the key on the bottom of your laptop, you can open the Start Menu, Right-Click on Computer, then click on Properties, then scroll down in the window that opens, and click on the blue text under Windows Activation. You'll be able to activate your copy of Windows over the phone.
Aug 19, 2011 | Computers & Internet
Saying that windows7 build 7600 this copy of windows is not genuine
If you got it your Windows 7 from a Retailer, then take it back to them, Or call them up for assistance.
Have you tried to use phone support on Registering Windows 7.
Go from there and see what you get.
Good Luck.
Nigel.
Jul 28, 2011 | Microsoft Windows XP Home Edition
I'm having this error on my laptop.my screen shows windows 7 build 7600 this copy of windows is not genuine
You will need to activate your copy of Windows 7. Once this is done this message will dissapear. If the activation fails then this means that you may be a victim of software piracy, contact the microsoft support center an Microsoft.com
Feb 12, 2011 | Microsoft Windows 7 Professional Upgrade...
Windows 7 build 7600 this copy of windows is not genuine .. what is that mean and what should i do ?
Did you buy your copy of windows or did some one install it for you?
If its installed by someone else then most probably your windows copy wont be genuine. You can try purchasing a new copy or you can try using windows genuine maker tools. like wga patch
Nov 16, 2010 | Microsoft Computers & Internet
How i can make windows 7 build 7600 genuine
if you have the wga icon in the system tray saying your copy of windows is not genuine, look on torrent sites like isohunt for a wga remover and make windows genuine registry patch
Oct 02, 2010 | Computers & Internet
Our computer always display "your windows(windows 7 build 7600 ) copy is not genuine" how can i download genuine copy and from where ?
You have to buy the genuine software licence from authorised microsoft vendors or buy online from microsoft.
Sorry no free genuine copies of Win 7.
Aug 21, 2010 | Computers & Internet
How to disable sata in bios of compaq CQ40 laptops
have an compaq presario cq40-301tu laptop want to load xp already vista is loaded in that while installing xp i get an blue dump error & no setting in bios found to make sata compatible please give me the solution how i can install win xp2-
Nov 27, 2008 | Compaq Presario Notebook
Computers & Internet Logo
131 people viewed this question
David Payne
David Payne
