Error F-04 appears on screen and then blows the electic.
    Brigadier General:
  • 6,277 Answers
Sorry but with such a major fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer.It could be internal wiring/plugs sockets, control panel switches, control PCB, main motor, drain motor. Also you do not say the make and model of your particular machine and different makes, models, different fault de-codes ;-0)
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Posted on Mar 21, 2011
I have a 07' MK5 GTI and i need help figureing out why im getting absolutly no boost. ive used the vagcom reader and it threw some codes that i have no freaking clue about please help me.
so,you have Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle , Status: Malfunction 0010 0F-Digital Radio -- Status: Malfunction 0010 15-Airbags -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 46-Central Conv. -- Status: Malfunction ,start by repairing these codes to figure out your boost problem
Apr 26, 2015 | Volkswagen GTI Cars & Trucks
Hdr sr1e won't work error c:04:00:00
The camera is 7 years old and things happen. If you have the original Manual, look up the code error to see what it relates to. If you say you installed Fully Charged new batteries, then an event relating to C:04:00:00 could be a circuit board malfunction or the metal conduction ends that touch the battery are corroded. With a light look inside the battery chamber to see if any material is covering the contacts. If dirty, scrape and clean the surface.
Dec 23, 2013 | Video Cameras
F2 04 error
An F2-04 is the IC chip on the toner cartridge was blown by the machine because it was unable to replenish tone in the developer unit , replacing the toner would clear the error but if it is a symptom , and usually is , i would suggest to take it to a Sharp technician to have a look at it, because if the problem is deeper it would just blow the new toner`s IC and that would be a waste
Oct 08, 2013 | Sharp AR-5316 Advanced Digital Imager...
During restore windows i found error "Windows could not complete the installation. To install windows this computer, restart the installation.
Reboot windows without any CD in drive and tap F8 key before windows screen appears. Select safe mode from the menu that appears and elect to do a system restore.
If this doesn't work you could try changing the boot order in the bios ensuring that your hard drive is first boot device. should get into bios when starting PC usually F2 or del key. remember to save changes in bios normally F10
Oct 13, 2012 | eMachines E730, Core i3-330M 2.13GHz,...
Panasonic DP-8035 Copier. Machine Error E04-02
Yep, you need to go into the service mode to reset this code. To enter the service mode press and hold the FUNCTION, ORIGINAL SIZE (LEDGER/A3), and 3 keys and F1 should appear on the screen. Go to F9 by pressing 9 on the keypad, press the down arrow key once on the touch screen, press 06 RAM Initialize on the screen, and choose 04 LBP Fuser Reset. This will clear the code.
Jan 28, 2011 | Office Equipment & Supplies
Lens error
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Oct 19, 2009 | GE A830 Digital Camera
Error 701 appears on the screen. no booting at all. all dead.
hi the laptop v3000 comapq pesario teh error code 0701 usb not working . witch smd has the problem
Jun 19, 2009 | Computers & Internet
Error 3
An error of 03 or 04 indicates that the unit is in safegaurd mode.
Elect the cassette once then re insert it. If the error is still visible you must contact your nearest dealer.
Here is a link to the user manual and troubleshooting guide.
http://uk.jvc-service.net/webtemp/GR-D250EK.pdf?CFID=1168480&CFTOKEN=98803594
Regards
Marc
Apr 16, 2009 | JVC GR-D250 Mini DV Digital Camcorder
Laptop will not fully start
This could be a device failure. However, try flashing the bios. Do this by going to Acer's support site and creating a bootable disc with the bios or updated bios, if there is any, on it. Then run this in your machine. You will have to use a different computer to do this, apparently. If this doesn't fix the problem, then you will need to take it in and have a tech run down the device that failed.
Jun 26, 2008 | Acer Aspire 5100 Notebook
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
