My nokia C6 is showing error which says "General: System Error" when i delete any images which i took from my cam, and they are not deleting from my phone
The *#7370# is the equivalent of a hard reset on any SERIES 60 mobile.
It will delete all software/settings etc., and restore all applications
to as they where when the phone was bought.
You can get the SYSTEM ERROR problems from
corrupted/edited/deleted/incompatible files that are in use, either in
the fone or on an MM/SD card fitted. To see which is at fault, simply
remove the card & turn on the fone again!
I get these errors often as I make software on these things (just starting).
If my solution is fix your problem give me the four thumb
Kindly check the memory card as pictures are stored there and you can erase them from there. You can format the memory card from - go to Office Folder , File Manager choose Memory CArd and in options choose Format ( you will loose other data too ) or you can open memory card in file manager and delete the images folder .
If we are helpful kindly give us all thumbs up
Farhan
www.senseapplied.com
First, backup all of your data as you can. And then, format your memory card. If still not work, you should reset your phone. Enter *#7370# from standby screen, and the default security code is 12345
