Code error E000100-002 on canon iR6800? What is this? Thank you!
  • 168 Answers
SOURCE: canon irc 3200 error code E000584 - 002
ok so a 584 code has to do with your finisher bins not moving is something blocking them from moving????
Posted on Jan 10, 2009
spinal
  • 287 Answers
SOURCE: canon ir 5570 - error E000100-0001
Hello prntrfxr,
E000100-0001 is a secondary code to the initial problem. It means verbatum " The power has been turned off and back on again without resetting the error ". So, there was a previous error code that instructed the customer to turn off the main power and turn it back on in an effort to reset the code. Unfortunately this must have been an error code regarding the fusing system. Canon designed the copier to prompt the customer to power the copier off and back on for all error codes, and more often than not the copier can recover to some degree or another. Fuser codes on the other hand WILL NOT reset even though the display says to power off/on . You will need to go into service mode to reset the error. Press "additional functions"......then the numbers 2 and 8 at the same time and then additional functions again. If you have followed these steps properly you will now be in service mode and a different screen. Just follow these instructions. Press copier. Press functions.Press clear.Press err.Press ok. Power off and on . This WILL clear the code. However, if the problem still exists the code will return of course. THAT code is the one we need to troubleshoot! :-)
Posted on Apr 20, 2008
checkitright
  • 1362 Answers
SOURCE: Error Codes CANON IR6800 We can't figure out what they are
E007 The fixing film is off to the side. E008 A specific number of copies are made after the machine detects that fixing oil is out. Since a user cannot re-supply fixing oil, the error code is indicated.
Check the fuser, either the film is off to the side or it is torn
or the oil is out (usually silicone oil) needs to be replaced
E013 •The PLL lock is released because waste toner motor is locked up, etc.
•The micro switch employed to detect clogging of waste toner is activated.
•The waste toner case is detected full.
Check the waste toner container, if full empty, other wise the waste toner drive system located on the drum needs to be cleaned out.
Posted on Nov 11, 2008
  • 66 Answers
SOURCE: i have canon imagerunner 3300 it shows error E000100-0002
sounds like a laser issue. try replacing it.
Posted on Apr 14, 2009
E000079-001
Posted on Jun 22, 2009
CANON IR6800
CLEANING WEB MUST BE CHANGE AND RESET
Feb 10, 2014 | Canon imageRUNNER C6800 Copier
Tip
Error code: E000070-0201.Model:IR6800
This tip works on all Canon Imageclass 6500 series machines including the MF6500 MF6530 MF6531 MF6540 MF6550 MF6560 MF6580 MF6590 and MF6595.
First of all if you are experiencing blank copies and or prints the best thing to do is try a different toner cartridge. In rare cases the black copies/prints CAN be caused by a defective cartridge. In MOST cases it is caused by a broken or detatched laser shutter lever or arm. When a toner cartridge is inserted and the door closed, a small plastic arm opens the laser shutter. If this arm is broken or has become disconnected then the shutter is not opened. This blocks the laser from writing the copy or print image onto the drum and this results in no print being applied to the paper. If the arm is broken you CAN open the laser shutter manually and block it open. What you need to do it open the cartridge access door, remove the cartridge and look for a 1/2 inch wide slot running from left to right in the metal frame that is in the back upper section where the cartridge goes. The plastic arm that operates the black plastic shutter is on the right side. If broken you can manually lift up the shutter and "block" it open using something like a folded up scrap of paper. I know it sounds strange but I have used this repair on several of my customers machines and they have all worked fine since. If you can not find or effect the repair yourself at least you will know where to point the service person when they come out to look at it.
Good Luck and Thank You for using Fixya.
on Nov 19, 2010 | Office Equipment & Supplies
E070
getfile.asp?rid=1258 April 12, 2007 getfile.asp?rid=3215 Product : iR6800
iR6870 Title : E070 Problem :
E070 error code.
Sensor reflectors on the inside of the ITB become dirty and do not reflect the light properly from the home position sensors.
Note* - If the equipment is not properly serviced, in regard to filters, the equipment filters can clog up and cause stray toner to build up in the ventilation area. If this occurs, there is a chance that HVT2 can become contaminated and copy quality issues will occur.
Additionally, soiling the white ITB patch may also occur causing E070 error code.
Solution :
Clean the reflective surface inside the ITB or replace ITB.
In regards to filters - Be sure ALL 6 Filters are replaced and/or cleaned at it's proper intervals. If ALL 6 filters are not addressed, poor ventilation will occur and toner can contaminate HVT2. If contamination of HVT2 happens replace HVT2.
HVT2 = FM2-0528-000
ITB = FC5-1658-000 Canon USA, Inc. Systems & Technical Support Division
Dec 22, 2010 | Canon imageRUNNER C6800 Copier
I have a canon copier ir6800 jamming at paper side deck
If the other paper trays work and you use your paper deck more than any other cassette.Your side paper deck tires are worn. You need to replace the 2 pick up tires, the 2 feed tires and the separation roller. Hope that helps.
Apr 21, 2010 | Canon IMAGERUNNER 6570 Copier
What are the steps to put an ir6800 as a printer using RJ45 cable...?? Thanks
You will need to assign an IP address to your
Canon to identify it. Then run a ethernet line from your router to the canon. Go to add a printer, create a TCP/IP port with that ip address and follow the screen. You will need the drivers for that machine if it is not listed. Get the drivers from the Canon website.
Mar 24, 2010 | Canon IMAGERUNNER 6570 Copier
Can it scan?
OK, you should have canon driver/software cd.On that CD you will find Scan Gear, after installation, open Scan gear and "discover" the ir2020.( copier must be in scan mode) then press select.
Open the word or similar on your pc that is connected with USB to copier.Under tab insert chose the insert from scaner or camera, chose scan gear and custom insert.
Feb 25, 2009 | Canon imageRUNNER 2020 All-In-One Laser...
Response
do in this order add functions 2 and 8 key at same time then add functions again screnn should change to service mode then this order copier / function /clear/ pwd / ok
Dec 17, 2008 | Office Equipment & Supplies
Connecting an ir65800 to a customer mac
turn apple talk on under system settings then network settings then appletalk settings then off and on you may have t put driver on apple also www imagerunner.com
Aug 06, 2008 | Office Equipment & Supplies
345 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
