Question about Garmin GPSMAP 192C GPS Receiver
I have a garmin gpsmap 192 c that will not power up__ i am revieving power to the machine
  • 5 Answers
SOURCE: GPSMAP 180 power/data connector
Okay
guys: book says:
PIN 1 (red) 10-40 volts DC
PIN 2 (black) Ground
PIN 3 (blue) NMEA out Shows this goes to Autopilot/NMEA devise and to RXD positive RXD negative goes to ground (black)
PIN 4 (brown) NMEA in Goes to GBR 21 Beacon Receiver to a blue wire, brown wire on thaat devise goes to PIN 3 and the negative goes to ground
PIN 5 (white) no connection
PIN 6 (Green) no connection
PIN 7 (yellow) goes to alarm low Shows going to negative terminal on alarm relay and positive terminal goes to PIN 1 (red)
All Greek to me, have fun
Seadrive Joe
Posted on Aug 29, 2008
reef runner
  • 7 Answers
SOURCE: Garmin GPSmap 76 not acquiring satellites
I had the same problem? GPSmap76S was hung up trying to AutoLocate. It just couldn’t find itself, and it just stopped working all of a sudden one day, while I was traveling. I spoke with Garmin about the problem, and they advised me of an ongoing problem with WAAS. I was told that I should "Disable" WAAS, because the signal from the WAAS satellites had been changed by the government, and Garmin had not yet put out a software update to address the problem, on the 76 units, anyway. Also said that an update "should" come out, in the future, however, no commitment or promise on that. Evidently, once your unit hits one of the WAAS signals, it scrambles up the receiver in the GPS, because mine sure went crazy. The support guy also said, that if this did not correct the problem, I might also want to try a "Master Reset". So here’s what happened.
I disabled WAAS, but this did not correct the problem. The unit was still lost out there somewhere, trying to AutoLocate, so I ended up doing the “Master Reset”. Please read up on this procedure before trying it, and understand that you “will loose” any settings that you might have made to the GPS, along with all waypoints, routes, tracks, etc., however, my maps actually remained in tact? This procedure will actually set the unit back, just as it was when it originally came from the factory. Once completed, you will then have to allow the unit to initialize it's self again, just as you did when the unit was new. If you have forgotten about doing that, it simply means that you need to set the unit outdoors and leave it “on” for a while (15 – 20 minutes), until it actually AutoLocates it’s self, or locks in on your current position. Once this is done, re-do your setting preferences, back to the way you had them before the Master Reset. At the very least, you’ll have to re-set it to the correct time zone, and tell it about daylight savings time. Note: It’s a very good idea to go thru first, and jot down your page settings and main menu settings, before doing this procedure, or the screens may not look familiar to you, once the unit resets. You think you’ll remember them all, but you won’t. But whatever, once you have done the “Reset” and “Initialization”, you must now hook the GPS up to the computer and reload your waypoints, routes, etc, back to the GPS. You did have them saved on your computer, didn’t you? Hope so… If so, you should now be good to go…………….
My unit now works like a champ, good as new, just not as accurate, due to WAAS being turned off. I still don't know if the WAAS issue, was part of the problem or not, but I do know that the Master Reset got the unit back to working immediately, allowing it to locate itself almost instantly. What a relief…………..it’s a little work, but it takes much less time than it took you to read this post…………..
Hey, when all else fails, call Garmin 1-800-800-1020. They are good guys and willing to help, in fact, I would advise you to call them before you do anything, so you can describe to them, exactly what your unit is doing. I am only relating my situation and what happened to me. Your situation may be different…….
Posted on Dec 13, 2008
SOURCE: Garmin gpsmap 295 will not run from internal battery power
I had the same problem. After following the instructions in solution number two the problem was solved and my 295 is working flawlessly.
Posted on Nov 21, 2009
  • 15 Answers
SOURCE: battery power trouble
I have discovered an intermittent problem on my 10 year old 295 when powered by batteries.
It appears that the chrome plating is de-laminating from the battery contacts that are either side of the back panel attachment hole. At first glance it looks perfect but if you run a fingernail or other small item across the face of the contact you will see and hear a movement as if there a a loose layer of foil over it. This is causing all manner of faults including 'external power lost, shut-down in 30 seconds' when the external power was not even connected at all!
Posted on May 05, 2010
  • 6 Answers
SOURCE: Garmin GPSMAP 76CS won't power on.
no power at all? never? what kind of batteries that can make a diffrence, if that still does not natter call them and req a repair, which you will have to pay
Posted on May 15, 2010
Compass will not caibrate
Garmin GPSMAP 62 - Initial Setup - Calibrate Compass ...
? 7:27
https://www.youtube.com/watch?v=OG7uVh2kQ24
Nov 9, 2010 - Uploaded by Jim Cyr
have owend 3 garmins. will be using handheld for biking. this looks like fast map ... Anyways, your review was decent, just don't know if I like garmin (possibly not). .... Compare Garmin GPSMap 62S vs Garmin GPSMap 60Csx ...
How to Reset the Garmin GPSMap 62 Series Handheld ...
? 1:23
https://www.youtube.com/watch?v=v-M7Ev6YTcA
Jul 20, 2012 - Uploaded by GPSCity
GPS City will show you how to RESET your Garmin 62 series GPS back to factory default settings. Back up all ... -My GPSMap 62s will not track satellites! -Forgot what ... -My barometric altimeter will not work or calibrate.
[PDF]GPSMAP® 62 series - Garmin
static.garmin.com/pumac/GPSMAP62_QSM_EN.pdf
Jan 04, 2016 | Garmin Gpsmap62s Hand Held Gps
Tip
How to Download your Garmin GPSMAP 545 / 545s Users Guide
Have you lost your User's Manual for your Garmin GPSMAP 545 or 545s?
Would you like a digital copy for easy searching of terms and quick reference?
The GPSMAP 545 owner's manual is available from Garmin here.
I hope that helps.
on Jan 31, 2010 | Garmin GPSMAP 545s GPS Receiver
Garmin GPSMAP 178C not boot
can we download india map?if tell me how to download and install the map in my device Gm4300?
Nov 20, 2013 | Garmin GPSMAP 178C Sounder GPS Receiver
I haven't used my Garmin GPSMAP 292 for a couple
Have you tried pressing Page + Power at the same time while starting the 292?
Seems like there is a well Kinoen problem with the auto locate locking in wrong position and IF you reset the past position memory by pressing Page + Power while Power up should fix the problem.
You still need approx 20min location time but its better than 12-24h.
Jul 27, 2011 | Garmin GPSMAP 292 GPS Receiver
Download Garmin GPSMAP 4008 repair manual or Garmin GPSMAP 4008 service manual
Hello.
You can find the garmin manual here.
Just type in your unit details.
Jun 30, 2010 | Garmin Gpsmap 4008
May 15, 2010 | Garmin GPSMAP 76CS GPS Receiver
Can not updait a GARMIN GPSMAP 60CSx
Try http://brilliantcorners.org/nodes/87-fixing-a-dead-garmin-gpsmap-60csx. It has helped many people. Complete steps to fix a dead Garmin are listed there.
Dec 31, 2008 | Garmin GPSMAP 60CSx GPS Receiver
Garmin GPSMAP 60Cx Powerup Problem
I suddenly had the same problem. Here a page with the explanations : http://forums.motionbased.com/smf/index.php?topic=3814.0 I removed the cache back to clean power connectors, tighten the cache back to properly adjust the power connectors on the map. Now everything is working properly.
Oct 31, 2007 | Garmin GPSMAP 60Cx GPS Receiver
GPSmap 60Csx power up problems
I had the problem where I ended up disassembling the Garmin and adding a small piece of plastic to the on/off button. For some reason the push button on the top does not reach the one on the circuit board.
Oct 19, 2007 | Garmin GPSMAP 60CS GPS Receiver
Garmin GPSMAP 192C GPS Receiver Logo
114 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
