Question about Zanussi ZWF1420W Front Load Washer
Drum makes a noise when spinning - Zanussi ZWF1420W Front Load Washer
    Problem Solver:
  • 14 Answers
Seems to me washer is off balance clothes are not evenly distributed or something may have become lodged hindering the spinning of the drum OR factory defect if recently purchased. Hope this helps
Posted on Mar 21, 2011
As it spins very slowly back and forth it also makes the grinding squeeking noise.
Hi Robert.
What you describe sound like a distorted drum and/or collapsed bearings. The grinding noise is typical of bearings which are worn out, and the squeaking can come from the drum rubbing on the door seal.
Check if the inner drum is loose and flops up and down. Also spin the drum by hand and see if it's touching the rubber door seal anywhere. If it spins freely but make a growling noise your bearings need to be replaced..
Neither of these situations are good. A serviceman is probably required to know for sure.
Good luck.
Nomess
Check that drum (2nd below) is not rubbing on this door seal
Drum should rotate quietly and smoothly
Jan 13, 2015 | Washing Machines
Whining noise from kenmore elite washing machine during spin cycle
it is poss. the bearings are going. if you can spin the drum by hand and it makes the noise it is the rear bearing...
May 06, 2014 | Kenmore Washing Machines
Tumble dryer drum making a noise spinning
hi take top off hold back of drum see if u can pull it up if you can feel play its more than liklely the bearing wot dryer is it
Feb 13, 2014 | Beko Dryers
Indesitw123 front load washing machine making very loud noise when spinning
The noise you can hear is the drum bearings, the seal between the drum and bearings has failed and let water into the bearings which has destroyed the bearings.
Mar 10, 2012 | Indesit Washing Machines
Spin the drum by hand, it make metal noise
Remove the rear lower panel of washer,and remove the drum belt.
From the front of the washer, spin the drum by hand, and if it feels rough or is rumbling, could be the drum bearings are going.
If there is something caught, it will make a completely different kind of noise, more like a catching or rubbing noise.
If no noise,then could be the motor that is casing the noise.
Hope this helps.
Jan 23, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
Washing machine has started to make noise. What could be the issue.
could be coupler or bearings on the bottom of the agitator and tub
Jul 09, 2009 | Maytag MER5775Q Electric Kitchen Range
Noise from drum when spinning.
can u move the drum up and down if so the bearings have gone
Feb 03, 2009 | Whirlpool AWM8163 Front Load Washer
Loud noise when it spins
Sounds like main drum bearing noise, try turning the drum by hand, if it feels rough or you can hear it grinding or rumbling, then it is the the main bearings that have failed..
You will probably need to call an engineer.
Dec 03, 2008 | Washing Machines
Zanussi ZWF1420W Front Load Washer Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
