Question about ASUS Eee PC S101H Laptop Charger (1300735LMD0017380)
The charger has stopped charging working fine since morning the suddenly stopped please help
  • ASUS Master
  • 32,281 Answers
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Posted on Mar 21, 2011
My battery will not charge. Have tried different batteries and chargers. Works fine on mains power. Any ideas please? Roger
sounds like to me you have a bad connection in the battery terminals. try cleaning the contacts with a Emery stick.
Nov 08, 2014 | Acer Aspire 3810T 4810T 5810T
Sony ccd trv218e
The symptoms you describe suggest the battery will not charge and should be replaced.
Mar 04, 2014 | Video Cameras
I have a hp g60, i have a really weird issue. Some times my laptop stops charging suddenly and the small led next to my charging input slot does not show any light. I checked my charger its showing...
Kind of vague. It could be the port on your laptop where the charger plugs into. It could be bad, or could have a bad connection to the motherboard due to use or manufacturing defect. When the charger stops charging then it has to use the battery power. This morning the battery may have had a low charge causing the laptop to shut down. Did you notice the battery's power level before it shut down? If you are wiggling the end of the charger that is plugged into your laptop to get it to start charging again, then that is most likely your problem. Do not wiggle it , for it could fry your motherboard. If that is the case then that port needs to be re-soldered.
Jan 24, 2011 | HP G60-230US Notebook
Hi my LX5 stopped working on some of the surfaces. It was fine the other day and all of the sudden it only works fine on paper. On desk or mouspad i've been using for years the pointer barely moves. I...
Don't know about the different surfaces problem, but the batteries...I had similar problem with duracell charger/rechargeables and my digital camera. I bought new batteries, charged them up and they didn't last long at all. I finally bought a brand new charger and batteries and they work great as they should. Maybe the charger is bad or try cleaning the charger battery contacts with pencil eraser to see if that helps. Also, some devices work best with "normal" batteries.
Sep 12, 2009 | Logitech LX5 Cordless Optical Mouse
Ipod does not charge after plugging in ac adaptor for 8 hours
Is it an official Apple charger? A lot of 3rd party chargers have this problem, they work fine for a while and suddenly stop working. I would try plugging it into the computer, if that doesn't charge it then something could be wrong with the ipod. If it doesn't charger google "reset ipod" and follow the instructions provided by Apple.
Hope this helps!
Tim
Jun 27, 2009 | BoxWave Corporation Apple iPod 3G (20GB)...
Motorola SLVR L7 not vibrating
When you are charging a phone you are not supposed to leave it on vibrate, for whatever reason-it damages the phone. My suggestion take the battery out with the power still on then try and turn it on again. If that doesn't fix it your ******** is shot. You may need to replace your phone. Sorry your having trouble, hope I helped!!
Mar 19, 2009 | Motorola Mobility SLVR L7 Cellular Phone
My sidekick 2 won't charge
mine stop charging sometime ago, and I switched to a nokia 3310 charger and its been working fine since. might be a little tight going in at first. good luck.
Aug 10, 2008 | T-Mobile Sidekick II
Casio EX-Z700
I think, Charger is out of order and battery used all its charge, now charger is not functioning, so battery is not being charged. I mean no power from either side to camera.
Try to use another charger to charge battery.
Jun 01, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Iphone touchscreen not working
try fully charging the battery
Apr 15, 2008 | Apple iPhone Smartphone
ASUS Eee PC S101H Laptop Charger (1300735LMD0017380) Logo
214 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
