Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
I have two residences and having the same problem at both. The phones ring the answering machine answers - no problem, but when I pick up the phone I lose the connection.. usually reads "welcome please wait! searching... " Someone suggested resetting the channels or something like that?
Its come base. how can remove that
Posted on Mar 21, 2011
How do I change the number of rings on this phone?
The KX-TG2313 isn't an answering machine. It will ring until you pick up, an answering machine or voicemail system picks up, or the caller hangs up.
To change the ring count, refer to the documentation for whatever answering machine or voicemail system you have on your phone line. If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
Jul 15, 2014 | Panasonic KX-TG2313 Cordless Phone
How do I change the number of rings before answering machine picks up Vtech cs6619
The CS6619 isn't an answering machine. It will ring until you answer, an answering machine picks up, or the caller hangs up. To change the ring count on an answering machine, please refer to the documentation for that machine. If you require further assistance, please add a comment to this question and identify the answering machine.
Feb 17, 2014 | Vtech DECT 6.0 Cordless Phone with Digital...
Extend number of rings before answering machine
The 6041 isn't an answering machine. It will ring until you pick up, an answering machine or voicemail system picks up, or the caller hangs up.
Please refer to the documentation for whatever answering machine or voicemail system you have on your phone line. If you require further assistance, please add a comment to this question and specify the answering machine or voicemail system.
Dec 26, 2013 | Vtech Cordless 6041 Phone
My Lexmark Interpret S405 fax?copy machine picks up incoming call from cell phone as fax. it goes onto fax automatically after 2 rings..
It seems that you're sharing your home phone line with your Lexmark fax machine. You can adjust the "pick-up" ring from the printer operator panel by pressing the Setup button > Fax Setup > Ringing and Answering > Pick Up On > select your preferred number of rings before the fax answers.
Please note:
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 08, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Phone is plugged in to a fax machine and the phone rings too many times before answering machine picks up so the fax machine takes over. How can I reduce the number of rings so that the answering machine...
Change the answer machine rings to answer number to less than the fax number of rings to answer or increase the number of rings to answer on the fax machine. Would need exact model number of phone system to give more detail on programming steps. Info should be in manuals of phone system and fax machine.
Dec 07, 2010 | AT&T DECT 6.0 Cordless Phone System with...
I have philips landline phones. My main phone does not ring or flash when an incoming call comes in. I t won't go onto answer phone either it just rings out. I can pick it up and answer the call. i can...
Looks like the basic functions of the phone are correct. Remain the answering machine. Are you sure it can act as an answering machine?
If it can act as answering machine the reason it is not doing so may be the following.
  1. Answering function is turned OFF
  2. Answering function may be ON but the number of rings before it answers is set too high.
I suggest you try the following
Call you phone. Let it ring at least 10 times. If it can act as an answering machine it will pick up the phone and read the welcome message, because most answering machines (the recent ones at least) answer after 10 rings even if answering function is turned OFF.
The phones that can be answering machines usually do have a display that shows the number of incoming messages, or a LED that flashes to let you know that you have new recorded messages.
Jan 03, 2010 | Philips Lands Phones
Set number of rings before answer machine pick up
From the main menu select the Voice Mail option in Voice mail select Ring Delay in Ring Delay you can choose the delay time before Answering Machine pick up the phone from 0 to 30 secend.Reza from Iran
Oct 01, 2008 | Siemens Gigaset S455 Cordless Phone
DXA18580 series
Increase the # of rings before the fax picks up so that it's greater than the # of rings before the answering machine picks up. When you're expecting a fax, turn off the answering machine.
Syskiyou
Jul 26, 2008 | Uniden Cordless phone EXS9950
The Answering Machine won't pick up, phone just rings
the cordless phone was working in power and inbuild batteries. answering machine is not like that. It does not have inbuild batteries! keep seperate batteries for answering machine OR otherwise keep UPS.
thank you...........
Jun 17, 2008 | Uniden Cordless phone EXS9950
Answering machine doesn't pick-up reliably
I found in the manual that if the machine doesn't answer after the correct number of rings, then it may be the ringing system used by the phone company. But I have also heard of people with VOIP (such as Vonage) having problems with this as well.
http://telephones.att.com/docMgt/public/art/21714/1738_english_manualpart2.pdf
Dec 05, 2007 | AT&T 1738 Digital Answering Machine
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
254 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
