Question about Sylvania G-Netbook
My new sylvania 7" netbook is not
    Problem Solver:
  • 14 Answers
Go to start menu. click on control panel. click on network connections. click on the computer icon that comes up, to the left with list options, one of the options should be search for wireless networks. Your Wifi card might have gotten switched off by accident. The computer icon I spoke of earlier would likely say "not connected" right click and a box will appear click "connect".Or if it is a wireless window, you will want to click scan for available networks. Hope this helps
Posted on Mar 21, 2011
Can't get online at my mom house
The Sylvania 7" G-Netbook only has wireless b/g if your mothers wireless is running a or n you might not be able to connect. You may need to change the configuration on your mothers wireless router, get a new wireless router, or get a new wireless card for the netbook.
Feb 12, 2013 | Sylvania G-Netbook
Cannot accress WiFi on Sylvania SYBET7WIC-BK-Z
The Sylvania Netbook is an inexpensive 7-inch device that is convenient for accessing the Internet on public or private Wi-Fi networks. It is not intended to replace a regular computer for daily tasks; its purpose is to provide a lightweight unit to access social media and perform small tasks. The netbook defaults to mobile websites, but it does a good job at what it is intended to do. Connecting to Wi-Fi networks with your Sylvania Netbook requires configuring the device properly.
Boot up the Sylvania Netbook by pushing the manual switch below the screen. Push the F9 key to turn on the Wi-Fi on the device. Select the little wireless icon in the toolbar at the bottom; it looks like a small computer. Choose the "Wireless Information" tab. This will show the online status of the device, as in whether it has connected to the Internet. If you have checked the box beside this option, this tab also notifies you when new networks are available. If the status shows that you have connected. You may need to add your wireless router manually in the setup. Do this by choosing, "Add New." Obtain the necessary setup information from your wireless Internet provider. If you have an encrypted network, you will need to fill in that information about your router. To configure the wireless setup further, click on the name of the wireless network. Click on "Advanced Settings" and adjust your connection choices; this tab determines the order of connection if there is more than one network available. Another important setting on this tab is the "Allow Windows to configure my wireless settings" option. Check that box. Click the "Internet Explorer" icon on the desktop. If you are online, you will pull up the Google homepage. Hope this helps.
Dec 27, 2012 | Sylvania Synet7wic-bk-z2 Netbook
Does the notebook come with wireless net and can I get online with this product
According to the link below, it does have built in wireless-g, which means you'll have to be near a wireless hotspot.http://www.cheapstingybargains.com/95645/sylvania-7-g-netbook/
Mar 01, 2011 | Sylvania G-Netbook
I was able to connect to my router but I have to manually turn on the wireless internet switch to "On" each time I restart the computer. Then I have to select the router and connect. Is there...
1. switch to "On" each time is need
2.automatically connect to your router need somesetting in your computer
3.you can chang the QUNE in wireless list then select auto,then del other wireless AP name.
Dec 29, 2010 | Sylvania G-Netbook
How to connect to internet sylvania netbook 7''
selct a wireless network to start with ; if you have and you are showing a connection with no internet access then try restating your router. Also double check your wireless switch to make sure its turned on
i hope this helps
Vague
Dec 25, 2010 | Sylvania G-Netbook
How do i connect the netbook to my wireless network
It depends on the OS you're running. Basically, go into the Network Wizard and setup the new connection properties. It's different for Windows XP versus Vista and Windows 7.
--Crazy PC Lady
Dec 24, 2010 | Sylvania G-Netbook
Bought daughter a 7" Sylvania netbook for X-mas,
See: http://digitalgadgets.com/netbooks/support-7in-netbook.htm for a detail of how to connect. If that does not work then see my how to at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
You may also see:
Wait for the little computer icon in the lower right corner to show two radiating side waves with a red X under the icon. The red X indicates that the WiFi has not connected. double click on the Computer icon and a window opens up with RT28701 as the header, with all zeros in the fields.Click on the tab Wireless Information. and a new window opens up. Look for the name of your home wireless network, and double click on that name. another window will open up called Network Properties and you will see some entries, with the name of your network as the SSID. go down to the key box that says The key is provided automatically, and uncheck that box. At the long box that says Network Key type in your code for the network key. This code was assigned when your network was set up to prevent someone else from accessing your network. When you finish, check the box The key is provided automatically and from then on your machine will connect automatically because it will remember your key.
Dec 18, 2010 | Sylvania G-Netbook
Yes how you connect to the internet with your sylvania 7" netbook what programs you use to connect to the internet
Make sure your DHCP routers LanIP is setup as 192.168.1.1(nothing else will work). This is needed for wireless or wired access. On the Sylvania netbook press fn-F9 keys to turn on the wireless access. click and launch the wireless icon on the bottom of the screen and choose your wireless network from the information tab and click connect. Look at the connection status below the wireless list.
Sep 19, 2010 | Sylvania G-Netbook
Sylvania G-Netbook Logo
179 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
