Question about Bosch WFMC2100UC Nexxt Essence Washer
Door Fell Off and broke off the hinges Not the hinge itself but the white plastic part of the door that attaches to them How can I fix it
  • Linda Mason Mar 04, 2012
    Help. did you ever figure out how to get the door back on? Same thing happened to us, i ordered replacement parts, but the inner white plastic thingy isn't fitting flush, and I am wondering if another part got damaged on the actual $$$ door. If you have a picture or can take a picture of what the inner hinge/metal/plastic successfully connected looks like, that would be wonderful. There are no BOSCH washers in my city, and have driven around trying to find a machine that I could stare at. THANK YOU in advance. Mom with lots of laundry stacking up.
    Brigadier General:
  • 6,277 Answers
Spares Suppliers
You will need to type into your search engine/web browser '(make) washer spares' and you should be presented with a number of sources from which you can order. During the process you will be asked for the actual model number. You could also try the Bosch site direct.
Good luck,
John C
Posted on Mar 21, 2011
How do I repair/replace a broken door?
Hello there, you will need a new hinge and probably the inside round piece of the door. Can you upload a photo? Please indicate the
E-Nr of the machine. You can find it on the label around the door and/or at the back of machine.
Jul 02, 2015 | Bosch Washing Machines
Does anyone know how to replace the hinge DA61-04866A on a Samsung french door vertical panel
unclip the plastic cover off your door hinge and unscrew the screws on your door make sure you leave the top screw in just a bit so you can take it out with your fingers before you drop the door ok same for both sides
Jan 22, 2015 | Samsung RF263AERS - 26 cu. ft. French Door...
Replacing hinge cam pin
I may need a picture to determine what is wrong. there is a screw-in pin that has a flat head top that you screw in. If that is in place, but the little cam itself (it's chrome with a black plastic center) is getting past the pin, then you have other problems. Either the 2 white plastic door closer cams on the bottom hinge are broken/worn/missing, or the lower hinge is sagging where it attaches to the cabinet of the unit and that needs to be replaced. These things can allow that cam to pass the 90 degree stop pin even when it is in place. you can look at a diagram of the hinge at http://www.greatplainsapplianceparts.com/order/subzeroparts.asp? (the question mark should be part of that link, but it won't take it so you may have to add it in the browser after you click the link). Let me know if this doesn't solve your issue!
Jan 14, 2014 | Sub-Zero 611 / O Bottom Freezer...
Strange thing over night my refrigerator has lost the suction in the doors. I have to close the door and hold the door close, to keep it close
there is a plastic part that attaches to the lower hinge that helps keep the door closed. it is like a rocker that when the door is open the door rides up on the plastic rocker then as you close the door the door rides down on the hinge rocker and helps to force it closed. mine stopped closing on it's own then all of a sudden the black plastic piece broke and fell to the floor. I am ordering a new piece if I can find the part number.
Mar 04, 2010 | KitchenAid Superba Architect KSCS25INSS...
The refrigerator door fell off. Where can I find
What I do is check the bottom mount. Make sure the plastic shims are all ok then sit the door on that and attach the center mount. I then set the top door onand attach the top hinge last. I have some apartment seminar lit. tha covers good old whirlpool ice box's, but hay once you fixed one you have basically fixed em all.
HERE
Feb 21, 2010 | Refrigerators
I have a Dometic rm2652 refrigerator the door hinge broke
the hinge is not plastic, only the insert sleeve that goes into the hole atop the door is plastic. If the actual hinge (metal arm) is broke, then you need to order a new part (not difficult if frig is 20 years or less). If you cannot find the part, go to a metal shop and show them the broken part, they usually can repair it or remake a new piece.
If the hole in the door went bad (that is: if the hole tore open and cannot hold the hinge pin) you need to have a metal repair brace added to the door. This will involve the metal shop or a good mechanic that can come to you and do the neccessary repair at the house; otherwise you need to bring the door to the metal shop. macgivor
Dec 27, 2009 | Dometic RM2652 Refrigerator
Kitchen aid khms147hss0 microwave - handle broke and gray plastic ( has 3 screws) on perimeter of door itself cracked - was going to replace complete door - how do you replace the complete door - remove...
Door parts are available separately on this model.
The parts manual is here. And you can order parts here.
You have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Dec 05, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Door hinges broken and door fell off
yeah very easy and it should only cost at most about £10 undue the old hinge with the 2screws now the door will have two little covers that held the old hinge in place take these out and make sure u get the broken pieces out of them once u have the new 1 put it on the washer and screw down first and then place the covers on the ends of the hinges and put the door in place now redue the screws on the door
Jun 01, 2008 | Candy CN146 Front Load Washer
Washing Machines Logo
124 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
