Question about Asrock ALiveNF7G-HD720P M/board, nVidia 7050, HT2000, Dual DDR2-800, PCI-E x16, DVI+VGA, HDCP... Motherboard
No video output seen on the monitor.my motherboard is asrock Alive NF7G
  • 36 Answers
Try checking your ram, unplug one module at a time and try using different configurations.
If you hear beeps at the beginnning of machine startup, it is a Ram Problem.
Posted on Mar 21, 2011
Hello, my system has Asrock P4I45GV Motherboard.
your possessor fan dos not properly work or fan casein do not properly instal or your power supply faulty.
Sep 04, 2013 | Asrock P4I45GV R5 Motherboard
No video output
video card then see cable as well
Mar 04, 2013 | Asrock K8 Upgrade NF3 Motherboard
I have an Asrock Alive NF7G-FullHD motherboard. The pci-e slot is not working what maybe the problem of these boards? I have 4pieces of these boards all have the same problem. Thanks for your input.
You have to change the BIOS settings for the Primary Graphics Adapter. Restart the system and go to BIOS Setting and Change the Primary Graphics Adaptor to [PCI Express]
(This item will switch the PCI Bus scanning order while searching for video card. It allows you to select the type of Primary VGA in case of multiple video controllers.)
The default value of this feature is [PCI]. Configuration options:
[PCI], [Onboard] and [PCI Express].
Asrock Alive NF7G-FullHD User Manual
Please refer to Page 46 of the above Manual
Hope it helps! Good Luck!
CreativeTECH
Feb 22, 2011 | Asrock ALiveNF7G-HD720P M/board, nVidia...
Power light panel on but no loading.sata11 asrock ddr800 ALIVE NF7G-FULLHD.walang response when you on the power but light front panel light up.
u must replace your processor only if u not hearing anytype of beep sound from pc. if u hear beep sound than u must replace ram of your pc.enjoy good luck plz vote on my comments
Sep 03, 2009 | Computers & Internet
Asrock motherboard prescott 800
If your monitor is plugged into your computer in the same area as your USB ports and everything else, you are using on-board video. If it is plugged into a card using one of the expansion slots located lower on the computer, it is a separate video adapter. Changes to BIOS settings can make it so it is not sending your video output ro the correct port in that case. You could have a problem with your power supply or your motherboard. Just because you hear the motors on the devices doesn't mean there isn't a power porblem. The motors use 12V DC, but most of the logic circuitry that makes everything else work is only 5V DC. Many motherboards have a small LED on them that serves as a "power good" indicator. If that is not on, the power supply is the most likely culprit, otherwise the motherboard probably needs to be replaced. Something else you should check before buying replacement parts is that no USB flash devices are plugged into the computer and that no blank CDs are inserted into any optical drives. I have seen both cause similar problems on other system.
Jun 07, 2009 | Asrock P4i65G Motherboard
I need free sound card and video card
http://www.asrock.com/support/download.asp?Model=&Socket=AM2&Product=ALiveNF6G-VSTA&OS=XP - here are your free drivers. Download the one that indicates AUDIO and VGA on the left column click on the download icon on the right side.
Apr 27, 2009 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
Asrock ALiveNF7G-HD720P M/board, nVidia 7050, HT2000, Dual DDR2-800, PCI-E x16, DVI+VGA, HDCP... Motherboard Logo
427 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
