Question about Miele Washing Machines
I need inlet valve and door seal for model #w806 can you supply?
    Brigadier General:
  • 6,277 Answers
Hi from retired Englishman in SW France, Sorry but this forum does not supply any parts direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and giving guidance for free on the web ;-0)
Spares Suppliers
You will need to type into your search engine/web browser '(make) washer spares' and you should be presented with a number of sources from which you can order. During the process you will be asked for the actual model number.
Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
Good luck,
John C
Posted on Mar 21, 2011
GE dishwasher inlet valve leaking
see this steps and fix it. God bless you
Dishwasher Not Leveled
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily.
Door Seal
This is not very common in most dishwashers. To check this look for rips and distortion of the seal. If it is ripped or distorted you will need to replace.
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispenser gasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace water inlet valve.
Drain / Circulating Pump
Some dishwashers have separate drain and circulating pumps Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. Follow the tutorial on replacing the pump
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust the switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the toe kick and maybe the front panel to inspect.
Jul 13, 2013 | GE Dishwashers
Leaking from motor
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
God bless youc9c8c0e9-8a93-431d-b16a-9b8d97f35d28.gif14b36f01-1d58-4f2a-8f54-fc14feec17e3.jpg
May 23, 2013 | KitchenAid Dishwashers
Leaking from top
follow the next step, for test. God bless you
Water Inlet Valve
Door Seal
Apr 05, 2013 | Whirlpool Dishwashers
Leaks from handle
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Jan 27, 2009 | Danby DDW1805W Designer Series...
Washer is overfilling
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Jan 25, 2009 | Whirlpool 24 in. GU1200XT Built-in...
We have a GE Dishwasher Model # GSD 2000 Z02AD - water leaks
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Jan 06, 2009 | GE 24 in. GSD2230Z Built-in Dishwasher
Brand new dishwasher installed and water leaks out bottom of door
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note…If the main motor of your dishwasher is mounted vertically, beneath thecenter bottom of the dishwasher, the following instructions probablyapply to you. But if your motor is mounted horizontally, the pump isn'tserviceable--you need to replace the entire pump and motor assembly.
Themain tub seal is beneath the drain impeller. It prevents the water inthe dishwasher from leaking out near the shaft of the motor. To get tothe seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Door gasket or seal Overtime, door gaskets and seals harden and lose their ability to sealproperly. You can't repair the seals. You need to replace them ifthey've begun to leak.
Water-inlet valve Thewater-inlet valve, itself, seldom leaks. But, the water-supply linefrom the house and the rubber tube leading from the valve to the insideof the dishwasher may leak. Tighten or repair/replace these asnecessary.
The water-inlet valve could mechanically stick open.When that happens, the water continues to flow into the dishwasher,which then floods your kitchen. Turn off the water supply to thedishwasher, and replace the valve.
Hoses Behindthe lower access panel on your dishwasher are several rubber or plastichoses. If the leak appears at a connection, try a new clamp. If thatdoesn't work, replace the hose.
Dec 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Westinghouse 906 leaks from front door
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Oct 05, 2008 | Westinghouse 24 in. MDP531 RF...
Water seeping in dishwasher
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Jul 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Leaking water on floor in front of dishwasher
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Dec 27, 2007 | Kenmore 24 in. 16022 Built-in Dishwasher
Washing Machines Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
