Question about Datamax E-4203 Printer
My Datamax E-2403 printer dosen't print any label at all even the test page I can't print it. Meanwhile i got the right driver for the printer
  • 54 Answers
SOURCE: Regarding Datamax E-4203 - Won't print
Check to see that the label sensor is over the gap in the label. It is just under the head on the right hand side.
You might also have the unit configured incorectly. If you go to the Datamax site, you can download the printer config program, It is easier to use than trying to push the buttons in the correct order to configure the printer.
Also use at least a 6" long label, and print the config file to see if you are set correctly for gap mode if using die cut stock.
Posted on Feb 25, 2009
SOURCE: Cannot print test page from PC on Zebra DA402 label printer
Which driver are you using? Did you try the Seagull drivers?
ftp://ftp.seagullscientific.com/drivers/archive/7.1/7.1.4/Zebra_7.1.4.exe
Posted on Mar 07, 2009
bartech9
  • 155 Answers
SOURCE: HOW TO PRINT LABELS IN DATAMAX PRODIGY PLUS PRINTER USING VB.NET
Tu necesitas utilizar comandos DPL. Pero si vas a utilizar graficos o windows true type fonts, tu necesitas un cartucho de memoria ram o flash. You need to use DPL commands. But if you use graphics or windows true type fonts, you need a RAM or flash cartridge.
Posted on Jun 10, 2009
  • 130 Answers
SOURCE: Trying to Print USPS Labels from PayPal on TLP 2844
see if you can set the printer preferences to borderless printing.
Posted on Jun 14, 2009
  • 5 Answers
SOURCE: We use the Datamax Printer to print labels with
Position fault or Out of stock when the printer is loaded with paper stock can usually be solved by calibrating the printer.
Press & hold the FEED button. Let the printer cycle 8-10 times. Should feed to the right position and say Calibration Complete in the window.
Hope this solves your problem.
Posted on Aug 21, 2010
Prints no label
Your program is most likely sending codes the printer does not understand. Try a test page from your driver if that works check the settings in your program. If it fails the driver test print you may have the wrong driver installed.
Aug 05, 2014 | Datamax Office Equipment & Supplies
Why datamax M class 4208 only prints on one side of the label?
When printing on less than full width media, the printer has a printhead-leveling cam to adjust the right side of the printhead
for even pressure distribution. To adjust the leveling cam:
1. With media loaded in the printer, print a label (press the
FEED + CANCEL buttons simultaneously) and
examine it..
2. While observing the printed labels, loosen the
Thumbscrew and move it to the left most position. (see
Example 1, below).
3. Next, move the Thumbscrew to the right until the
printed labels contain a complete, even image (see
Example 2). Tighten the Thumbscrew.
Apr 30, 2014 | Datamax I-4208 Thermal Label Printer
I have a Datamax DMX I-4212 Barcode Printer. Computer operating system is Windows XP. I use a third party software package, to produce barcode labels. The company is Argos Software. The printer is set as a...
Welcome to FixYa.
It shows that the printer is not communicating properly with the computer.
Solution:Uninstall the current printer driver from the control panel then re-install it.Your printer should came with a cd (software/driver/installer), use it to re-install the driver.
Thak you for using FixYa.
Dec 23, 2011 | Datamax DMX-I-4212 Label Printer
My datamax will not print labels even though it goes through the process
if the printer seems to function . and when your queued label printes, but no text on label, check to see if your driver will do a test print to the printer. if it does, check your fonts. Some Dmax printers will have a difficulty using TT fonts, especially in serial coms.. Try the printer fonts(datamax0, 1,2,3,4.
Feb 03, 2011 | Datamax DMX E4203 Printer
Datamax WS6308 print error in .net
El controlador de Seagull es muy bueno y con muchos parametros, intenta modificar los parametros del spooler. Seagull driver is very good and with many parameters, try to modify the parameters of the spooler. buscar
Nov 24, 2008 | Epson Printer
May 16, 2008 | Datamax DMX E4203 Printer
Won't print labels
Ended up being the heating settings - they were to low, so when I hit print...it would spit out a label but nothing would be on it.
Problem solved!
May 14, 2008 | Datamax DMX E4203 Printer
Datamax problem
You probably need to adjust the leveling cam if you have not done so already. This is the green thumbscrew near the print mechanism.
Dec 18, 2007 | Datamax M-4208 Thermal Label Printer
Datamax E class
Go to Control Panel > Pritners and Faxes. You should be able to see your printer there. You can check and ask it to print a test page.
Jun 05, 2007 | Datamax 1/PK EXTERNAL LAN INTERFACE METO...
Datamax E-4203 Printer Logo
151 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
