Question about Datamax Office Equipment & Supplies
My Datamax E-2403 won't print labels at all even the test page inspite it got the right driver.
  • 27 Answers
SOURCE: Datamax M-4206 printing too slow
The way you can do this is to use Datamax fonts in your LabelMatrix program instead of truetype fonts like arial or times new roman. After making this change, do a test print and see if print improves. Another possible solution is use USB instead of Parallel cable (if you're not using it already).
Posted on Dec 30, 2008
  • 54 Answers
SOURCE: datamax dmx-m-4206
check for the flatness of the printhead across the platen.
also check to see if the head is not worn(will be white colored at the head heat elements.
also check to see if the platen is severly worn.
Posted on Feb 25, 2009
  • 54 Answers
SOURCE: Regarding Datamax E-4203 - Won't print
Check to see that the label sensor is over the gap in the label. It is just under the head on the right hand side.
You might also have the unit configured incorectly. If you go to the Datamax site, you can download the printer config program, It is easier to use than trying to push the buttons in the correct order to configure the printer.
Also use at least a 6" long label, and print the config file to see if you are set correctly for gap mode if using die cut stock.
SOURCE: Cannot print test page from PC on Zebra DA402 label printer
Which driver are you using? Did you try the Seagull drivers?
ftp://ftp.seagullscientific.com/drivers/archive/7.1/7.1.4/Zebra_7.1.4.exe
Posted on Mar 07, 2009
Nic61
  • 1073 Answers
SOURCE: s there any free software for running Datamax E 4203 Printer? it is meant for printing library barcode labels.
http://www.datamaxcorp.com/software/e-class/
There u go!
Manuals, drivers, firmware and utility for the E-class,E-4303,E-4204 and E4304
Good luck
Nic
Posted on Apr 24, 2009
Prints no label
Your program is most likely sending codes the printer does not understand. Try a test page from your driver if that works check the settings in your program. If it fails the driver test print you may have the wrong driver installed.
Aug 05, 2014 | Datamax Office Equipment & Supplies
Why datamax M class 4208 only prints on one side of the label?
When printing on less than full width media, the printer has a printhead-leveling cam to adjust the right side of the printhead
for even pressure distribution. To adjust the leveling cam:
1. With media loaded in the printer, print a label (press the
FEED + CANCEL buttons simultaneously) and
examine it..
2. While observing the printed labels, loosen the
Thumbscrew and move it to the left most position. (see
Example 1, below).
3. Next, move the Thumbscrew to the right until the
printed labels contain a complete, even image (see
Example 2). Tighten the Thumbscrew.
Apr 30, 2014 | Datamax I-4208 Thermal Label Printer
When we print labels, it skips one each time. We have been on the phone with Datamax three times and all systems appear normal. When we do a test of the Datamax it DOES NOT skip[ any labels but as soon...
Hello, Nancy.
It's clearly your application, since a test print appears normal and all systems appear normal. Is it possible to reinstall your application ?
Hope this helps.
Mar 06, 2011 | Datamax DMX-I-4208 Label Printer
My datamax will not print labels even though it goes through the process
if the printer seems to function . and when your queued label printes, but no text on label, check to see if your driver will do a test print to the printer. if it does, check your fonts. Some Dmax printers will have a difficulty using TT fonts, especially in serial coms.. Try the printer fonts(datamax0, 1,2,3,4.
Feb 03, 2011 | Datamax DMX E4203 Printer
Datamax WS6308 print error in .net
El controlador de Seagull es muy bueno y con muchos parametros, intenta modificar los parametros del spooler. Seagull driver is very good and with many parameters, try to modify the parameters of the spooler. buscar
Nov 24, 2008 | Epson Printer
May 16, 2008 | Datamax DMX E4203 Printer
Won't print labels
Ended up being the heating settings - they were to low, so when I hit print...it would spit out a label but nothing would be on it.
Problem solved!
May 14, 2008 | Datamax DMX E4203 Printer
Datamax problem
You probably need to adjust the leveling cam if you have not done so already. This is the green thumbscrew near the print mechanism.
Dec 18, 2007 | Datamax M-4208 Thermal Label Printer
Datamax E class
Go to Control Panel > Pritners and Faxes. You should be able to see your printer there. You can check and ask it to print a test page.
Jun 05, 2007 | Datamax 1/PK EXTERNAL LAN INTERFACE METO...
44 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
