We just bought a brand new Proscan lcd tv.It was manufactured in 2009.We've only had it for 3 days & every now 7 then it will make a loud popping & crackeling noise.Only way I can describe the sound is as when someone crumbles up a piece of paper.
    Brigadier General:
  • 8,909 Answers
If it were mine, I would have it replaced.
Posted on Mar 21, 2011
My proscan tv is 2yrs I have lines going down on the screen what wrg
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 24, 2016 | Proscan 32LB30QD 32 in. LCD TV
I replaced the power supply unit on my 50" ProScan flat screen and now it wont even turn on just a clicking sound when you hit the power button.
The replacement power supply could have been installed incorrectly or may have been defective as received.
Nov 20, 2014 | Proscan Televison & Video
I bought my 19" Proscan LCD (19LA25Q) used from a
The Proscan 19LA25Q came with a remote originally. Unless the IR receiver has failed, it should work with a universal remote. (Note: if the TV is newer than the remote (or released less than 6 months before the remote was programmed), the remote codes for your TV may not be included.) Since the code lists on universal remotes do vary depending on the age and model, please give more information than just the brand. GE remotes usually have a version code label in the battery compartment. This version code is needed to look up the correct code lists. Some GE universal remote built by Jasco codes are here: https://byjasco.com/support/ge-universal-remote-codes.
The Proscan 19LA25Q was probably built in 2007, since there are reviews from 2007. That was also the year when this size TV had to have an ATSC tuner. So if your remotes were programmed before July 2007, they may not be compatible. Some of the current Proscan TVs probably use the same parts as some Sylvania, RCA and Curtis TVs.The 19LA25Q was warranted by On Corporation which has control of the RCA brand now. However, I don't know when they bought the label.
Amazon lists a few direct replacement remotes for the 19LA25Q. See https://www.amazon.com/Original-Proscan-Control-E20F-19LA25Q/dp/B00KQVDRNK and https://www.amazon.com/PROSCAN-Replacement-Remote-Control-19LA25Q/dp/B009H5QVIO . Remotes.com also has a replacement remote: http://www.remotes.com/SearchResults.asp?Search=19LA25Q .
I hope this helps.
Apr 21, 2017 | Proscan 19LA25Q 19 in. LCD Television
When I was watching the tv it suddenly started to flash off and on and then finally will not even turn on
Watching tv all of a sudden loud buzz noise,I shut off unit turned back on loud buzz came back about 30 seconds later loud pop pop then smoke came out of top of unit, i'm not please as this unit i bought about 17 months ago @ Canadian Tire Belleville & warranty is now not covered, pobably will never buy another Proscan product but am more concerned there could be a fire caused buy this than getting unit replaced
Apr 23, 2009 | Proscan 19LA20Q LCD TV
My LCD tv's menu screen keeps popping up and won't stop.
Since it is brand new then should be OK.
Please return it to store and get another TV.
Feb 24, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Who makes proscan tv?
Proscan is produced by ON Corp. They are a leading producer for most LCD screens used by a large group of TV makers. Proscan used to be a high end RCA product. The CEO of On Corp was the head of the Proscan division of RCA. After Leaving RCA and Beginning On Corp he purchased the right to the Proscan trade mark. Thus a new beginning for a old name. Many people still belive it to be an RCA TV but it is not. It has good ratings in most reviews for TV's in it price range. It is now a sears brand much like Dynex is a Best But brand.
Dec 25, 2008 | Proscan 42LA30H 42 in. LCD Television
Proscan Tv is humming
This made my humming sound go away completely;
From JD at oncorpus.com [manufacturer of the 32LB30Q]
Please follow these instructions, should fix the hum issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone.
John
Dec 15, 2008 | Proscan 32LA30Q Television
Pro Scan On / Off Switch Problem!
Sometimes a power surge or bump will cause the program chip to hang up. If there was no surge or bump, then program chip may be defective. Any case i would return it for another.
Mar 01, 2008 | Televison & Video
Manual for Proscan 32" LCD TV
http://www.oncorpus.com/down/down.htm
This is the site for the Proscan manufacturer. Should be able to get answers and/or tech support.
Jan 18, 2008 | Proscan 32LA30Q Television
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
