Changing NAT settings on TG585 - Computers & Internet
  • 3 Answers
Judging from your user name, I take it you want to switch your NAT settings so that you can play your xbox online. In order to do that, you're first going to need to set up a static IP address and then forward your ports on your router from there. Here is a simple and easy to use guide from portforward.com, just follow the steps outlined in the pictures and you should be able to get this up and running in no time.
http://portforward.com/english/routers/port_forwarding/Thomson-Alcatel/SpeedTouch585/Xbox_Live_360.htm
Posted on Mar 21, 2011
Hello, i setup a IP cam. Create an account on dyndns.org for the IP. But now when i type the given url i am linked to the setup of my Thomson router TG585 v8 What can I do? There is nothing else except...
Hi Sten -- There are several non-intuitive things you have to setup with any router and Dyndns to make this work.
On Dyndns you can setup your static or hardly every changing dynamic Internet (external - provided by your ISP) IP address in your Dyndns account settings (Not the internal NAT IP - 192.168.x.x address of the cam). if it changes more often you need a dyndns client.
On the router you have to setup port forwarding to the internal (NAT address ex:192.168.x.x) address of the camera including the port number -- or you could just create a DMZ (feature of many but not all routers) for the internal IP of the cam.
If you've done the above correctly you might want to check the troubleshooting sections at Dyndns.org located HERE and HERE.
Happy Networking and Thanks for using Fix Ya.
Mikeywaf
Apr 15, 2011 | Computers & Internet
NAT IS STRICT
STEPS TO CHANGE NAT SETTINGS TO "OPEN":
1- Using your Browser, Log on to your router (by normally typing in the 192.168.1.1 address check your router's manual to see what the default gateway address)
2- If you already know how to log in to your router, then skip this step. If you have never logged on to your router then more than likely you still have the default initial log in credentials (username: admin - Password:1234 ..... Again check your router's manual to be sure). The minute you log in you need to change that password immediately, most network-savvy folks know that 90% of the people out there never reset their router's initial password and they can log on and make any changes to suit their needs, including locking you out of your own router.
3- Once you are logged in, you should be able to find two advance settings (One if for NAT - and the other is for Upnp)
4- Let's start with the NAT setting changes, and we will move on the Upnp at the end. I have personally tried the NAT setting changes and it didn't fix anything, I still had a "Strict" NAT setting on my xbox360, Only when I checked for the Upnp "allow authorized incoming traffic" options when the NAT settings on my XBOX finally came back as "Open" and not "Strict". But I will still explain what I did anyways with the NAT table cause I know it may work for some other routers.
5- So what I did with the NAT setting is this. I located the NAT advanced setting on my router, I click on the NAT (Edit List setting) or whichever link/button you have on your router advanced NAT settings to access the table needed to open certain ports (TCP and UDP - 88 & 3074) .
6- You will need to find out what the static/dynamic (preferably Static) IP address you xbox360 has. To do so, go to the Dashboard, go to the Console settings page, and click on the network settings to see the IP address (should be something like 192.168.1.x). You will need that IP address to enter into your NAT table on your router.
7- Once you got your XBOX's IP address enter it in the NAT Port Forwarding table (From - To - IP address: those are the 3 fields you should have on the table if you are using SUA NAT)
8 - In the first line enter 88 under both "From" and To" fields, then enter the IP address of the xbox in the field where you are to enter an IP address. (this is for UDP port)
9 - Repeat the same step for port TCP (which is 3074)
10- If these changes do not help open your NAT settings, then try the Upnp option. Click on your Upnp Advances settings and click on the "Allow Traffic" option, this is mostly secure because you are only accepting the incoming traffic that matches your outgoing traffic.
Mar 02, 2011 | Belkin Basic Wireless Router
I have a PS3 and I want to change nat type from strict to open when I play Black Ops. My router is a Thomson TG585 v8. How can I do that? Thank You in advance
Hi, I'm not familiar with Thomson routers, but you can watch this video, which details the process for a netgear router. The process will most likely be similar for your router.
Feb 27, 2011 | Video Game Consoles & Games
Xbox 360 - Thomson Router TG585 v8 Strict Nat limits who you can connect to. As you can imagine this creates a problem when trying to connect to friends. Kindly, devliver a simple step by step on how to...
OK, i too have had this problem and i have solved it via this website. This thompson modem is also referred to as... o2 wireless box II/III the website link is
http://www.unofficialguidetolive.co.uk/faqs/62-my-nat-is-strict-or-moderate
Search for the specific (o2 wireless box II/III) modem and follow tthe simple instructions onscreen.
Jan 01, 2011 | Video Game Consoles & Games
Change NAT settings
The way to change the NAT settings are similarly done to those posted in this article:
http://www.halownage.com/off-topic-discussion/2626-halo-3-nat-how-change-nat-settings.html
Thanks
Jan 15, 2010 | Computers & Internet
I need to change my nat type from strict to open
This router does not have the typical "strict or open" NAT types. Looking at the manual, it looks like what you want is NAT enabled and SUA only enabled.
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906173729&ModelIndexflags=0,420041221102511,420041221102520,420050117110858,420050117110916,420050117110934,420050831093216,420050831095441,420060420160946,420060420161739,420060816160116,420080815092146,420090427144843
Page 133 has the details.
Log into router
go to the NAT tab
Enable NAT
Enable SUA only
Apply the change.
Nov 18, 2009 | Zyxel P660HW-D1 Router
Dynex-e402 change nat settings to access x-box live
Dynex DX-E402 router, changing NAT settings(UPnP) to access x-box live. go to router settings web page for router, http://192.168.1.1/, enter user name and password to access settings page. user id is usually admin this also for password. under advanced settings click on forwarding. In listed sub-catagories click on UPnp. click enable. this should solve any NAT issues with X-box 360 signing onto x-box live. dynex dx-e402 was very easy to setup.
Mar 24, 2009 | Dynex DX-E401 Router
Open NAT with Thomson (Speedtouch) TG585 v7 Router
First, try adding a wireless card to the Xbox, run the wireless off of the router OR if you have multiple connections (broadband, should be an "In" port, and several "Out" ports) Try connecting your PC and you Xbox through the "Out" ports, with the cable modem cord hooked into the "In" port...
Feb 02, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Computers & Internet Logo
489 people viewed this question
Alun Cox
David Payne
David Payne
