Question about Kenmore Top Freezer Refrigerator
Water leaking inside of frig, seems to be coming from vent below freezer
    Guru:
  • 683 Answers
Usually if a refrigerator is holding water this means that the condensate from the freezer is not going down into the pan in the bottom, the water has to go somewhere so it ends up in your refrigerator. Find the drain line in the bottom and try some how to blow it out, if you can do this and clean the pan you should be ok.
Posted on Mar 21, 2011
Hotpoint model #ctxy14epjrwh slow water drip from inside of the refrigerator. inside the top of the frig, center, there are several components that appear to come down from the freezer. the lowest one...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the centeroldtech2332_52.jpg
Aug 24, 2011 | Refrigerators
Water inside on shelves can not determine where it is coming from checked back of refrigerator can not see any leaks inside or outside. cleaned up water cleaned under fins etc one day later more water...
A temporary solution is to remove all frozen food, ice tray,shelf and bottom plate. you will see the water drain trench and a drain hole in the back center of the freezer. Unplug the drain, free it from ice or debris and flush with hot water. I have the same problem with my frig. This is not a permeant fix, but it will stop water from dripping through the vent ports The defroster may be defective or the air flow is too restricted. Good luck.
Jan 02, 2011 | Kenmore 64802 Top Freezer Refrigerator
Water leaks inside,cant seem to locate drain. Water freezes in bottom of freezer,then runs down to the bottom of frig. I SEE a drain in the back right of bottom of frig but it sits up like a knob with...
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer
Nov 19, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Maytag side by side fridge freezer leaking water
Your drain plug within the evap area of the freezer is frozen, turn frig off, let sit for day or two with doors open. Once all ice has melted then take rear freezer evap cover off and pour water into try and make sure it drains, if not then unplug drain. This is usually caused by a defrost heater bad or unit not going into defrost when it's supposed to, may be main board.
Sep 30, 2009 | Maytag Sovereign 60 Side by Side...
Water comes out freezer door
Defrost that drain with a hair dryer and remove the debris . That should solve the problem . The red you see ( this is normal ) , is the defrost heater , thawing out the frost on the coils . The defrost water HAS to go out the drain or it will freeze the opening and the defrost water will flow out thru the bottom of the freezer door .
Aug 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
At the top of the frig where the cold air blows into a small "vent" is it suppose to still have styrofoam the inside of the small "vent"? PC Water is leaking into frig and into veg bends.
most likely the drain is clogged..if it is, the water flows to the path of least resistance, hence, into the air vents and down under the crisper..remove rear freezer panel. the drain pan is located under evaporator. Defrost the drain pan if there is ice in it. there will be a small drain hole. this is where you need to see it gets open via hot water and all will be ok..make sure you hear or see it flowing into drain pan...Bruce Denton, master tech
Jun 19, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Freezer not defrosting
Most likely there is a leak in your freezer seal allowing moisture to build up and form the ice blockage.
Jun 17, 2009 | Jenn-Air JCD2389G Side by Side...
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Food freezing in frig
Go to the link below and the choose line 22 and click it. That link page helps identify most common problems you may have with your refrigerator, Thanks Sea Breeze.
 http://www.applianceaid.com/refrigerator.html
Sep 11, 2007 | GE Profile PSI23NCR Side by Side...
Kenmore Top Freezer Refrigerator Logo
180 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
