I have a NEC NW803 washing machine and the spinning cycle will not run
Sounds like the timer is faulty
Posted on Mar 21, 2011
My nec nwtl456 washing machine wont empty all water when spin complete anoying is it the pump or?
Can you hear the pump motor running when you first turn the program on, or during the spin cycle? a sort of glug glug noise when the drum is NOT turning. If you can, but the water is not draining, you have a blockage somewhere. If no glug glug then the pump is seized with a coin or pin etc and must be removed and freed or replaced.
Check any filters fitted first; remove and clean them. Lower the grey drain hose onto the floor - does water run out? if not, blockage maye be in sump hose or pump chamber (sock, etc)
If it does run out, blockage will be in connection to sink / waste pipe on your domestic plumbing.
Feb 03, 2018 | Washing Machines
I have a nec nw-691, when you put it on spin cycle it brings error message --lid open??? plz help
Yuo might try making sure it is still level but I'd just try using a lower spin speed. How have to use "gentle spin" when I wash towels or my washing machine has errors and stops. If still too damp just use a gentle spin only cycle once more to finish the job.
Apr 16, 2015 | Washing Machines
H6 error code on a NEC NFL-1065 washing machine
see this causes, and fix it. God bless you
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
f the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components
f the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Sep 26, 2012 | Washing Machines
My NEC NFL855 E3 error
E3 error is discharging water problem. ie 1.the pump not working (under bra wire will stop it spinning) or 2. the discharge hose blocked or most likely 3. the pump inlet hose from the drum is blocked (with small article of cloth or coins or similar).
To Fix:
1. Open the pump filter and check if spinning during empty/spin cycle, make sure nothing jamming or twisted around impellor.
2. Check discharge hose is not crushed or kinked.
3. Lay machine on its side, access pump and remove inlet hose assembly and remove any blockage.
Jeremy
Jul 19, 2009 | Washing Machines
Nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Jun 30, 2009 | Washing Machines
NEC NW452 4.5kg washing machine - spin cycle not working
theres 2 things to look for , 1 the LID SWITCH that tells the main module that is OK to SPIN, it could be loose or defective (need a multimeter to check the voltage on switch) 2 the DRAIN PUMP MOTOR , usually it gets stuck with lint and debris, need to open washer ,locate at the bottom on one side where the DRAIN hose is connected, is a small motor , take it out and check inside for clogged stuff , also check drain hose , hope this helps , AJ
May 16, 2009 | Washing Machines
My LG TROM wash googd but dosn't want to spin
Check and see what type detergent you are using. I bought regular liquid detergent and the machine began making noise during the spin cycle and the drum would not spin. I was informed that you have to use detergent that is labeled HE (High Efficiency). The regular liquid detergent will suds up during the wash cycle which then causes the drum to slip and not spin during the spin cycle. What you are hearing during the spin cycle is the drum slipping. Unplug your washer for 30 minutes and let it reset. This lets the suds dry out. Run a cycle with no spin to rinse out the drum. This should eliminate your problem. If you have clothes in the machine, run a cycle with no spin, just don’t add any more detergent. Then run the normal cycle with spin a second time with no detergent. I hope this cures your problem.
Apr 11, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
HELLO WE HAVE A NEC WASHING MACHINE AND IT HAS STARTED TO ONLY SPIN LARGE LOADS OF WASHING IF THERE IS A SMALL LOAD IN THE MACHINE IT GETS UNBALANCED AND WILL NOT SPIN EVEN WHEN WE MOVE IT AROUND IN THE...
FRONT LOAD MACHINES ,WE DO NOT RECOMEND WASHING SMALL LOADS IN FRONTLOAD WILL NOT CLEAN CLOTHES PROPERLY,, ALL FRONT LOAD MAKE SAME NOISE WILL TRYING TO START SPIN CYCLE
Nov 27, 2008 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Lg washing machine wft855a top loader
Following up my comment from yesterday, I took the machine apart and discovered that the black rubber cover on the valve that releases the cold water had perished and cracked, and wasn't opening properly.
I tested the hot and cold solenoids and everything checked out ok. Was just the cold valve sticking.
The wash cycle was working because I was using hot/warm water. As the rinse cycle needs cold water to get started, it was not working and the rinse and spin cycles wouldn't complete.
I have swapped the valves over for now (put the working hot one on the cold side and am using cold water only). It's working while I order a replacement...
Sep 07, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
67 people viewed this question
Top Washing Machines Experts
