Question about Marantz 105 Tuner
Maratnz 105B tuner stereo lamp does not light any more. What voltage is the lamp.
I have an 06 Buick Lucerne rear courtesy lights do not work front courtesy lights work fine?
The BCM receives battery voltage from the CTSY/RF TRN fuse in order to supply power to the courtesy lamps. The BCM applies this voltage to the courtesy lamps through the courtesy lamp supply voltage circuits. When any door is opened, the door open switch contacts close and the BCM receives a door-open signal. If the BCM receives a door lock or unlock signal, the BCM will activate the courtesy lamp supply voltage circuit, providing battery voltage to the dome lamps and the left and right footwell courtesy lamps. The courtesy lamps can be manually activated by placing the interior lamp switch in the DOME position. For more detailed information concerning courtesy lamp operation refer to Interior Lighting Systems Description and Operation.
The BCM receives battery voltage from the INT LAMPS fuse in order to supply power to the inadvertent courtesy lamps. Inadvertent power courtesy lamp feature provides a similar function for the interior lamps as a retained accessory power feature. The BCM will energize the courtesy lamps supply voltage circuit when the BCM is in the active state (awake). When the inadvertent power courtesy lamps supply voltage circuit is energized, it supplies voltage to all the interior lights listed below. The BCM will continue to supply voltage to the interior lamps after the ignition is turned OFF so that the interior lamps may be operated.
Feb 15, 2018 | Buick Cars & Trucks
Marantz tuner 120 stereo light will not come on,
Probably it is suffered by over aging. You need a skilled repairman.
Oct 01, 2014 | Marantz Audio Players & Recorders
Aiwa stereo repair tuner backlihgt too dim
Might need a replacement lamp for the backlight module.
Sep 03, 2014 | Audio Players & Recorders
The stereo light on my marantz 2226b receiver does not come on even on a stereo fm station
my first question is does the light come on when you turn to Tape, Phono, Aux selection? If no lamp is blown, if it does come on then your tuner need to be serviced. FM tuner work is NOT for a novice. I would be glad to take a look at the unit.
Thanks
www.back2lifeelectronics.com
Sep 23, 2012 | Marantz Audio Players & Recorders
Where do i hook the switched 12v+ on my 1997 chevrolet lumina to on my new stereo?
find a hot wire one with 12 volts in it all the time near the stereo and tap into it or figure out which is the hot wire on the plug to the old radio for that the key will be on for voltage or run a wire from the fuse box that's hot get a voltage test light at the parts store they're cheap and worth their weight in gold be sure not to hook radio up backwards that'll be the end furn radio off when installing
Feb 25, 2011 | 1997 Chevrolet Lumina
Have stereo yellow wire to battery, black wire to ground, red wire accesory to fuse box have power supply problem after stereo is on for a while. the sound distorts and when you change radio station it...
I suggest you ensure the ground is made to a sensible ground point and the supplies are also good and the antenna is also properly grounded and then monitor the supply voltage and the current consumed by the radio until it begins to distort. If the voltage and current remain steady the fault is either local interference or inside the radio, probably in the tuner.
If the current climbs and the voltage remains steady the fault is likely in the audio section...
Nov 18, 2017 | JVC AM FM CD DET FACE CAR STEREO
Hi! Sony tuner st-sa5es,stereo lighting is bliking, signal is very good and sound is stereo for short time and mono for short time.Ihave indoor aerial Fanfare,Thankyou.
I still think it is antenna orientation or there is interference. it probably works well on mono perfectly. if not then it is a defective tuner module inside the receiver.
Feb 28, 2010 | Sony Audio Players & Recorders
Sony lcd kp60xbr800 no raster in tuner all voltages ok. in tuner power ok, menu ok, but no raster please help sergioaguirre0182@hotmail.com thanks
You have a lamp driver error that can be and most likely is faulty and has to be replaced,Also i would not recommend you putting a bigger lamp unless the part numbers are the same to the lamp you are replacing.Moreover most of sony's error codes are the same from crt to lamp tv set like your lcd model tv set, the same concept was used to built your lcd tv set just with different features.
Sep 08, 2009 | Televison & Video
I have a panasonic pt-45lc12
If you are not a tech you don't want to mess with the voltage that feeds the lamp. The vibration of moving the set can cause the lamp to go bad. blinking LED is usually a sign the lamp is bad. It is a good Idea to open the lamp door and then close it again to make sure the door switch isn't the problem
Jun 15, 2008 | Panasonic PT-45LC12 45" Rear Projection...
Light
You need the remote to turn that light off.
Jun 09, 2008 | Sharper Image Slim One-CD Stereo with...
Marantz 105 Tuner Logo
71 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
