We have the R1480-series service manual for this model and have uploaded it to our site
here to help you.
You will need the
free Adobe Reader to view or print it.
Double-check your wiring against the "pictorial diagram".
The switches will have a "C" (common) terminal, and a "NO" (normally open) terminal, and some will have a "NC" (normally closed) terminal.
As long as those connections are the same and the voltage and current (amps) ratings are the same or higher, any number of switches will work.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door
switch or mount trouble can be caused by slamming the door or by
opening the door while it's cooking without hitting the Stop pad first.
There
are plastic mounts inside the microwave which hold the door switches
and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes
it's a broken tab on the switch holder, allowing the switch to rotate
just out of position. This tab
can be hard to see, since it is under the bottom edge of the switch.
It's easier to secure the switches with hot glue than to replace the latch heads, by the way.
