My usb flash disk suddenly stops working properl when i transfer a file...i cannot find it in my computer..but it connects properly.. what will i do..
  • 32,281 Answers
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Posted on Mar 21, 2011
Tip
How to Back Up Trial Software
<p>The free trial software gives the user the ability to evaluate a program before they buy. If you have a free version on your computer and want it back, you can connect an external hard drive or flash drive to do. The process can relieve headaches, if your computer crashes or gets infected with viruses.<br /> <p> <br /> <p>1. Connect your external hard drive or flash drive to your computer via a USB port. Click the Start button and click on "Computer" option on the menu. Click on your external hard disk or flash drive icon in the menu. You can use this window.<br /> <p><br /> <p>2. Click the Start button and click "Search ". Enter the name of the test software that you store in the search bar and press Enter.<br /> <p>3. Transferring files to display in the search window on the external hard disk or flash drive. A small window with a progress bar will tell you how long does it take to transfer files appears.<br /> <p><br /> <p>4. Click on the My Computer icon on the Start button when the transmission is complete and right click on your hard disk or a flash image. Click the "Eject" option. Remove the USB cable from the USB port of your computer to your software.<br />
on Jun 21, 2011 | Computers & Internet
Can't transfer my email files from old computer to new computer
Good Day!
To transfer files from an old computer you can use USB or flash drives, copy the files from your Old Computer to Flash drive, after copying---attach the flash drive to your new computer then copy the files and save it. This is the easiest way to transfer files.
Other way of transferring;
-You can also transfer files by Burning your files into a CD/DVD and copy it to your new computer.
-Get your hard disk from the old computer and attached it to your new computer
-Or connect/network your two computers.
I recommend USB or Flash drives, the simplest and easy way.
Hope I was able to help.
Jul 16, 2010 | Microsoft Windows XP Professional for PC
4gb Sandisk Cruzer USB drive on Windows XP SP3 When transferring over large files (1-3gb) I get an error message after about 3-4 minutes of transferring (roughly halfway through or near the end of...
WinXP uses its own driover for USB drives like this so as long as you have the latest updates installed that should be OK.
Make sure you are doing nothing else with the computer when transferring the file.
Check and make sure you have at least double the amount of free hard disk space as you are transferring.
Reformat the flash disk completely and tyhen run a checkdisk on it specifying to report and fix all errors.
Try defragmenting the hard drive so temporary files can be laid down contiguously.
See if there is a BIOS update for your motherboard.
May 17, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
PLS HELP ME!!! MY Memory stick in pspjust stop from functioning!!
Try to format the memory stick and copy the data will solve your problem.
Revert back for more assistance.
Jan 28, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
Maxtor 3200 was working fine. Suddenly my
Try connecting it to another computer.
If it is not detected, then either the disk-drive "inside" the unit is dead, or the "adapter" (USB-to-Disk-Drive) inside the unit is dead.
If the latter, disassemble the case, remove the disk-drive, and attach it as an "internal" hard-drive to your computer.
Nov 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Was Dragging Files Onto My 2GB Flash Drive And It Stopped Working
This story may give you hope.
This very same day, I removed my Cruzer Micro unsafely and it stopped being recognized by the computer. I plugged it into another USB port and it did not work. I tried to access it under Ubuntu Linux: I could see the drive but if I click on its icon, I get the message Unable to mount volume, no media.
I tried to reinstall the SanDisk LaunchPad, but it refused to be coaxed because it did not recognize the drive as a SanDisk.
I mourned may drive, but still had hope to recover my data. A google search took me to some data recovery company, that would charge close to 300 dollars. I had no intention of paying that kind of money.
Then, without any particular reason, I plugged the drive in a USB hub that I connected to one of the two ports that failed to recognize the drive. And the miracle happened. Windows recognized it. Was it the presence of the Hub? I don't know.
I made haste to transfer my data to a folder in my computer.
After the transfer I installed the LaunchPad I downlowed from SanDisk. It warned me that my files will be lost. But since I already transferred them, I could not care less.
When I reaccessed the drive, my files were still there. Now my drive works fine: it is recognized by Windows, as well as Ubuntu.
The moral of this story is don't give up easily, and keep trying.
What do you think?
Aug 25, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Recovery Disk
you can make you flash drive bootable.. the problem is that it might not necessary copy over the recovery cd files properly. Here is a link that can help you: http://www.bootdisk.com/pendrive.htm
Jul 24, 2009 | Computers & Internet
How do i transfer photos from my hp photosmart m537 camera to sandisk cruzer micro usb 2.0 flash drive 2gb.
Connect the HP camera to your windows pc using the usb cable provided. Open My Computer to ensure that the camera is being properly enumerated (given a hard disk letter). make note of the drive letter assigned.
If you have more than one USB port, insert your cruzer micro 2.0 stick into another USB port. Look in my computer again to determine what drive letter was assigned to the flash stick. Open a windows explorer window for each of the locations. One for the camera, the other for the flash stick. Its likely that the picture files are in a subfolder of a folder called DCIM.
Once you locate the files you want to transfer, you can highlight them using the mouse (click/drag a box around the files you want) and drag them to the other open window (flash stick folder)
If you don't have another available USB slot on the compter, you'll need to copy the files from the camera to a temporary location on your computer and then move them to the flash drive. In this case, make a new folder on the desktop and name it temporaryfiles. open that folder. open the drive letter assigned to the camera and copy whatever files you want from the camera to 'temporaryfiles'...
Then power off the camera and remove the usb cord from the computer. attach the flash disk to the newly free'd up usb port and open a windows explorer window to it. drag whatever files you want from 'temporaryfiles' folder into the folder for the flash stick.
I hope this helps!
-Ray
Mar 02, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How does this work?
When the unit is connected to the computer, ?USB Connected? will be displayed on the screen. During transfer, ?USB Transfer ...? flashes on the display. When the transfer is complete, the display will change to "USB Connected". Do not unplug the USB cable when the display is flashing. Also, check to see if the mp3 file(s) you're transferring is between 32 to 320 kbps. You may need to reinstall the USB driver for this device. Good luck.
Jun 23, 2007 | RCA Lyra RD1072 MP3 Player
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
