Cable connector is broken off, how do I replace it?
    Scholar:
  • 90 Answers
Hi there, cable connector is readily available at any electronic supply store. You can bring your sample and have it replace. They can also have it assemble for you. And ask for instruction on how to connect into your TV. hope it helps..please rate and vote
Posted on Mar 21, 2011
How to replace broken cable connector
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular TVs are given; with illustrations. You can get details there.
Aug 08, 2015 | Televison & Video
Connector of cx5500 pinter model c331a loss usb connector
lose connection or cable broken. if lose then slightly press usb cable at flat side and try again. if broken it is better to replace.
in some cases you have to use original usb cable. other wise there is no connectivity.
Feb 24, 2011 | Epson Office Equipment & Supplies
Cable input connector broken off
Usually the connector or at least a new connector can be put back on. If there is minor damage to the board, a tech can repair it in most cases.
Jul 25, 2009 | Televison & Video
Tip of LANC connector on Sony tripod broken off!
Two options:
1. Replace the cable with the same connector.
2. Replace the 2.5 mm connector.
I took the LANC cable from an old Sony remote, open up the tripod remote control handle and replace the whole cable. Some soldering required to remove the wires from the PC board and solder the new wire.
The PC board has marking White/Black/Red, the replacement connector with the Tip to the White, the Ring to the Red, and the Shell to the Black.
Nathan
Jan 12, 2009 | Televison & Video
RCA F36676ET broken cable connector
expertize needed for repair any avg shop can repair min chg.
Dec 03, 2008 | Televison & Video
Cable connector broken
You can buy replacement antenna jacks for this. What you have to do is remove the tuner and it's shields, then unsolder the little tab off the board of the tuner which is what remains when they break off. Then you can resolder the new jack in place and the center pin back to the board of the tuner.
Mar 28, 2008 | RCA HD52W59 HDTV Projection Television
Broken RF Connector
you would have to get a new part for it. try looking online and out in your model number and put in rf connector needs replacing
Mar 10, 2008 | Apex Digital AT2002S 20" TV
Broken cable connector
Yes, its not that difficult. You may even find that you can salvage the one that you have. You'll have to unplug the TV and remove the rear cover. The connector may be located in the rear cover or a plate that sticks through the rear cover.
The connector may be attached to the TV's motherboard or a sub-board. It may even be just a bulkhead connector with a cable that is bolted to a plate.
Let me know what kind of "F" connector it is and I'll help you locate a replacement. Maybe you'll be lucky and just have to resolder the old one.
- Jim
Jan 31, 2008 | Zenith B27A11Z 27" TV
Cable Connector inside TV
Unless you know how to sholder well and know how to do an isolation test on the set after its repaired I would let a pro do it My friend as I've seen it a hundred times. A peep will simply hook up a connector to the set and ground the connector or what looks like a ground and as soon as that set is pluged into an ac outlet and a cable or sat line is attached KAPOWWWWEEYYY.. It smokes and you end up blowing out the bridge rectifiers aong with all sorts of things. Now dont get me wrong please as you can repair set if and only if you wanna take that chance by simply taking a piece of coax cable with a connector on one end and soldering the center wire onto the broken wire that came off the connector and then soldering the outside or sheild wire to the place where the broken connector was attached if at all possible BUT I repeat this is not a good way to do this. Good luck
Mar 23, 2006 | Sanyo DS31590 31" TV
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
