Question about Garmin Edge 305 GPS Receiver
Garmin 305 impact injury
I've only had my edge305 for 1 week; it took a tumble whilst on my handle bars, I think it got hit around the front of the unit, the screen is not damaged at all. I ceased to work straight away the accident. Is this something that could be reapired?
Will your warranty cover it? If not, I just described how I took mine apart because it wouldn't work. The bettery connects to the unit at the top of the unit where you plug it in. These thing are notorious for bad battery connections.
Posted on Aug 11, 2008
Loss of sound garmin forerunner 305 gps
This is a pretty common problem due to a design flaw in the 305 (although Garmin disagrees). There are open holes on the back of the watch for the speaker which allow sweat to corrode the speaker or material such as sunscreen to block the sound. You can attempt to clear these holes if they're blocked, but it's unlikely to help.
If your watch is still under warranty, call Garmin. As soon as you tell them about the loss of sound, they will arrange for you to exchange your watch for a refurbished one. When you receive your refurb, place tape over the holes to keep the gunk out (doesn't really impact the sound level).
Dec 12, 2011 | Garmin Forerunner 305 GPS Receiver
My Garmin 305 which I have had for 5 years when locating satellites fills the bar graph up only about 1 centimeter and then resets back to zero and fills up again to about 1 centimeter and resets back to...
I got exactly the same problem last Friday. I could not fix my device yet but the link for the post below has some good tips that may work for your device.
https://forums.garmin.com/showthread.php?p=81080
After I ran GPSChipsetTypeG_300 file my device still shows GPS 0.00 version. I have tried many times without sucess.
Aug 05, 2011 | Garmin Forerunner 305 GPS Receiver
Forerunner 305 "problem receiving activities"
I've had this problem. First -- and this sounds weird -- use a USB port on the back of your computer. Do NOT use a "secondary" type of USB port, such as an add-on hub, the ports on the front of a desktop machine, ports built into peripherals like a monitor, etc. Apparently, all USB ports are not created equal. Second, make sure you've the freshest Garmin Communicator plugin (which may entail a fresh download/install).
Apr 28, 2011 | Garmin Forerunner 305 GPS Receiver
How can I change my Garmin 305 from miles to kilometers?
Hit Mode till you see History,Training,Navigation, and Setting. Scrol to Settings using the down arows on the right hand side of the watch. On the same side of the watch hit Enter.
Hit enter on General.
Scroll down to Units (You can't see it right away, you have to scroll down) hit Enter on Units. There you can change to Metric.
Mar 17, 2010 | Garmin Forerunner 305 GPS Receiver
I received my Garmin 305 back from Garmin about two weeks ago. It had been sent ind because it would not charge. One of the buttons on the back became missing and it would not charge. I received it back...
Hmmm. Did you try and reload the software? It should recognise the unit but maybe it needs to "reconect" .
My wifes watch always seems to stop comunicating with her PC. I think it is becasue she does not close down the process using windows safely remove hardware icon. In anycase reinstalling the sofware gets hers going again.
Mar 16, 2010 | Garmin Forerunner 305 GPS Receiver
Garmin 305 wont power on, wont charge on cradle
Same thing happened to mine. Put the unit in the cradle (just like you are going to recharge it) and press the reset and mode button at the same time for 3 seconds. This will "wake" the unit up.
Mar 30, 2009 | Garmin Forerunner 305 GPS Receiver
My garmin edge 305 powers down as soon as i press the mode butto
I had the same problem after a rainstorm. Although the unit is supposed to be waterproof, it was not. Garmin replaced the unit when the mist did not clear after a few weeks, and the unit never worked after that.
Jan 03, 2009 | Garmin Edge 305 GPS Receiver
Garmin 305
I think that you have got a loose connection on the battery. I had the same problem, took the top off and had a poor connection on one of the battery terminals.
Any jolt would cause it to shut down.
Should be a simple fix if you don't mind going inside!
Jul 05, 2008 | Garmin Forerunner 305 GPS Receiver
Garmin forerunner 305
My husband is the best!  Here's what he did and now it works:
Hold the on/off button and mode button, then hit the lap/reset button.
Hope this helps!
Jun 21, 2008 | Garmin Forerunner 305 GPS Receiver
Garmin Edge 305 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
