Question about Toshiba Qosmio X500S1801 (PQX33U01H01M) PC Notebook
Turns off without warning, will not start again unless turned off by holding in the button
  • 36 Answers
Is the problem Consistent? By this i mean does it occur at a set amount of time into its use?
This sounds like it could be an overheating issue. Check to see if it turns off sooner when doing something CPU intensive, and if it turns off even sooner after you turn it on again. Try cooling the laptop somehow.
Posted on Mar 21, 2011
Service indicator reset
insert key into key slot and press the start stop button once WITHOUT putting your foot on the break. You should see numerous lights turn on,on the dash
weight for any warning lights to go out, in some cases, like low fuel warning light, you my need to press the BC buttonon the end of the indaca tor stalk once to remove them
press and hold the black button, on the bottom left of the speedometor, but keep holding down the button untial the next picture appers then release the button.
to cycle threw one by one all of the picture optctionsfor each service press black button once. when you arive at the SERVICE that you wish to reset press AND HOLD THE BLACK BUTTON until the text RESET?is visible under the picture then let go,finily press and hold the button again to conferm the reset.
Nov 27, 2013 | Cars & Trucks
I did try: change fuse as first it was without any lights. Then checked sockets. It started again by itself. Then I reprogram it-switch off-turn on 90'C-press start button- switch on- keep pressing f
Try this reset, it may work:
-Turn Off power switch
-Select 90 degree washing
-Press and hold Start
-Turn ON power switch and keep pressed Start button 10 sec
-Depress Start button
-Turn Off power switch and turn On again and thats it...
Credit to original poster :)
Oct 19, 2012 | Washing Machines
I need to know the procedure to reset, 'Change Oil warning' on my 2006 Ford Freestar.
On the right side of the steering wheel there is a button that says "setup". Turn the ignition key to the on position, push the setup button and hold it until the change oil warning shows 100%. There should be a message that pops up telling you to push the reset button to the right of the setup button. Push the reset button and hold until the message confirms the oil life has been changed to 100%. Release button turn off ignition key. Now start the engine to make sure the warning light does not come back on. If it does, try again.
Jan 22, 2011 | 2006 Ford Freestar
My change oil light is on, but the oil was just changed. How do I reset the computer?
To reset the light, open the driver's side fuse panel cover. Turn the key to "on", but do not start the car. Wait for most of the warning lights to go out, then press the red RESET button in the center of the fuse panel. The "Change Oil" light should flash. Then, press and hold the RESET button until the car chimes. Then, turn the key back to "off", and replace the fuse panel cover.
If that fails to turn off the light, turn the key to "On" once again without starting the car. Press the gas pedal to the floor 3 times in succession, then turn the key to "off". That should reset the light.
Jul 29, 2010 | 2000 Pontiac Grand Am GT
How can I disarm a prestige car alarm system without the remote? The owner cannot find the remote. The battery went dead and when we jump started it the alarm went off. If the drivers door is closed it...
find the program button and turn on ignition without starting the engine and press and hold the button till it goes steady
if it has a swith turn on and flip the switch till it goes on solid 1 or 2 x
Dec 10, 2009 | Prestige 2 Button Remote Security System...
Engine light came on this afternoon. quart low on oil. added.
unfortunately, no easy way, unless you buy an inexpensive code reader, you can also clear codes with them.
Dec 04, 2009 | 2000 Honda Odyssey
Battery dead unless pluged into computer. Charges
Friend, the power switch is damage thats why the charger acted as switch. replace the power switch
Jul 17, 2009 | Sony NWZ-E436F MP3 Player
How to turn off change oil light on 2001 Corvette
Unless there is something wrong with you buttons the procedure is as follows:
1. Turn ignition key to ON (not start)
2. Press ENG MET button on trip monitor & release, then press it again within 5 seconds.
3. Within 5 seconds again press and hold GAUGES button until Change Oil lamp flashes.
4. Continue Holding Gauges button until lamp stops flashing & goes out.
5. You should be done, start & shut off car. If it didn't work turn off car and start from top.
Some buttons are very sensitive so try and be deliberate & steady when holding.
If that helps please rate my answers!
Brett
Mar 19, 2009 | 1994 Chevrolet Corvette
Shuts off randomly
Hi
Have a look at your power settings
Start -> settings -> control panel -> power” settings” (don’t remember the English word)
Here are your settings for with or without the power supply.
/Teis
Was this helpful, then don’t forget to vote
Dec 15, 2008 | Toshiba Satellite A35-S1592 Notebook
How do I reset the maintenance warning indicator at the dashboard ?
Try this, it is the procedure for resetting the ASSIST computer on some Mercs
1...Turn Key to position No:2 in the ignition / steering lock 2...Press AND Hold the button "000.0" (the trip reset button) TWICE within the space of 1 (one) second and turn the key to position No: 0 in the ignition / steering lock - release button 3...Press AND Hold the button "000.0" (the trip reset button) and turn Key to position No:2 in the ignition / steering lock
That should do it....The service indicator will reset and an acoustic signal may briefly sound
Good Luck..Let me know if it works?
Nov 04, 2008 | 2003 Mercedes-Benz C-Class
Toshiba Qosmio X500S1801 (PQX33U01H01M) PC Notebook Logo
78 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
