Question about Dometic RM2452 Refrigerator
Hi my Dometic RM2510 fridge does not seem to work on 12 volt at all. I was told that it was a three way fridge when purchased with van - The power selector switch has elec/gas/12volt selection available. Have checked terminal voltage at rear of fridge and is getting full 12 volts. Works great on 240 volts. Can you help? Is there a separate element for 12 volt? Regards Nigel
    Top Expert:
  • Dometic Master
  • 8,471 Answers
Yes 12 volt element
Posted on Oct 06, 2017
3 Suggested Answers
22yooper
  • 828 Answers
SOURCE: Dometic Caravan Fridge 7271
Your refrigerant may have completely separated in the system. Shut of the gas, disconnect the electrical and remove refrigerator from the coach or if you have sufficient room inside set it on a clean area. This operation is what is called burping the system.
1. From the base roll it onto the door and wait five minutes.
2. roll it onto the top and wait five minutes.
3. Roll it on the back and wait five minutes.
4. Return it to the base and wait five minutes.
Reinstall it or test it on electrical. It should show signs of cooling in about 30 minutes in the freezer compartment if the system is not plugged in the boiler.
Posted on May 26, 2008
  • 51 Answers
SOURCE: dometic rm2620 rv refrigerator
No you need 12vdc for the control board. If you have a convertor 110ac to 12vdc this will work for your supply instead of the battery.
Posted on Sep 07, 2008
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
Is the 12 volt lights and fridge usually run off the same 12 volt cable?
fridge runs off 12 volts regardless or LP but need 12 volts to run
Sep 09, 2014 | Dometic Refrigerators
Cant find the fuse for the refrig. no power
Check connection for 12 volts, at back of fridge behind vent cover .(outside) Make sure 12 volts getting to the lugs where they join. If you have 12 volts to there, unplug fridge at receptacle usually on left side by back of fridge, just to be safe. Remove cover on circuit board and look for a blown (glass type fuse in there.)
May 03, 2010 | Dometic NDR 1292 Refrigerator
Dometic Refrigerator Model RM 2820 Stopped working purchased 5-4-2004 . Tom Collins
Hi Tom,
If your fridge quit working altogether, check your DC fuses in the fuse box, as well as the back of the fridge under the black plastic cover (3 amp). Though the fridge uses LP and 120vac to cool, it is controlled by 12 volts.
Apr 30, 2010 | Dometic RM2620 Refrigerator
I have a dometic rm 689 in my 1970's kustom koach trailer and i'm trying to understand usage. it has a 3 way switch on back of it that i don't know what it's for. can you tell me
Three way fridge:
1: Runs on 12 volts from the trailer batteries. Hard on power and uses batteries frightfully fast.
2: Runs on propane. This is best for places where there is no 120volt power lines. This still needs 12 volts to CONTROL the fridge so have a battery on board.
3: Runs on 120 volts. Great if you can plug in the trailer.
Mar 28, 2010 | Refrigerators
We have a 3 way Dometic fridge in our caravan. Have lived in the van for last 12 months ( grey nomads) have had no probs until trip home this week from Yulara to Victoria. Pulled up at night and freezer...
Temperature does play a big part in the efficiency of the fridge. The condenser at the back of the fridge needs cool air flow to allow gas vapour to be converted back into a liquid.again.
Nov 12, 2009 | Dometic RM2652 Refrigerator
How many amps does a unit like this use?
The RM2652 is rated at 120VAC @ 2.7 amps.
Jul 15, 2009 | Dometic RM2652 Refrigerator
Dometic RM2452 Refrigerator Logo
233 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
