Question about Belkin (F5D7231-4) Wireless Router
Hi..I have Toshiba laptop with Windows Vista on. I am able to connect to internet using Ethernet however on Wireless it gives me error as PPPOE authentication failed. Not sure how I can go over here..
    Problem Solver:
  • 20 Answers
I suggest you to hard reset and configure the router settings manually to fix this issue.
A) Please follow the steps given below to Hard reset the router:
- Connect the computer to the "LAN" port on the router and connect the modem to the Internet/"WAN" port, using Ethernet cables.
- Take a paper clip, insert the paper clip in the reset hole of the router and hold it for 60 seconds.
- Unplug the power cable from the router after 20 seconds while the reset button is pressed.
- Wait for about 20 seconds and then plug-in the power cable back to the router.
- Wait for all the lights on the router to light up solid and then release the reset button.
- The power light will flash and then come back "ON" solid, indicating that the router is being restored to factory defaults.
B) Please follow the steps given below for configuring the router manually:
- Log on to the router web interface by typing in http://192.168.2.1, in the address bar of your browser.
- By default, the password is blank.
- Click on "Connection Type" in the left hand column under "Internet WAN" heading.
If the connection type is PPPOE (DSL):
- Choose "PPPOE" and click on "Next".
- Enter the user name and password given by your Internet Service Provider.
- Save the settings.
- Click on the "Home" link at the top of the screen.
Internet Status should show "Connected" on the top right hand corner of the web page. If not please unplug the power cable from the router and unplug the power from the modem, leave these both units unplugged for 1 minute. Plug the power to the modem first and wait for the modem to get ready, then plug the power to the router.
If the problem persists, please get back to us with the following information:
1. Type of connection provided by your ISP (Is it PPPOE, Dynamic or static).
2. Name of the Internet service provider (ISP).
Regards,
Styli
Posted on Mar 21, 2011
My dell inspiron 1545 cannot connect to internet as it says i have no network adapters installed. How do i do this
Hi Anon
Your laptop should come with an Ethernet connection as well as wireless connections, try making a wired connection via your Ethernet port, these are usually more reliable than wireless connections.
When I have experienced these sort of problems it is usually because of a missing driver.
Check that you have the proper drivers for your internet connections installed, these should come on a disk that is supplied with your laptop.
Finally check this link for Microsoft's official network trouble shooter.
http://windows.microsoft.com/en-gb/windows-vista/troubleshoot-network-connection-problems.
Sep 14, 2014 | Microsoft Windows Vista Home Premium with...
Satellite c655d-s5200: will not display available wifi connections
The RAS PPPoE driver file "raspppoe.sys" found under c:\windows\system32\drivers folder seems to be the root cause of the problem. Fortunately, we can workaround the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system.
Feb 12, 2014 | Toshiba Satellite Computers & Internet
How to fix error 651 on windows 7
Error 651 is a well-known bug in Windows 7 which happen when you try to connect to the Internet using PPPoE connection. If you're one of the victims who met this bug, you should see the following error message: Error 651: The Modem (or other connecting device) has reported an error. These connections, however, would work just fine in Windows XP or Windows Vista PCs. Below are a few solutions that can perhaps fix the problem:
Windows 7 Fix: Error 651 Modem PPPoE Broadband Internet Connection
Fix 1: - Error 651 Modem PPPoE Broadband Internet Connection
Click here to download Registry Easy to automatically fix your PC errors and speed up your system.
Fix 2: - Error 651 Modem PPPoE Broadband Internet Connection
The root of the problem is believed to be caused by the RAS PPPoE file raspppoe.sys found in the folder C:\Windows\System32\Drivers. To fix this problem, we will have to replace the file raspppoe.sys with a new one. Try to copy the file from your friend's computer which has Windows 7 installed. Alternatively, you can download the raspppoe.sys file from this site (thanks to the author). After you get the file, before pasting it into C:\Windows\System32\Drivers, be sure that you rename the original file to something like raspppoe_ori.sys, so that if something weird happen you have a backup of your original file. Paste the new raspppoe.sys into the directory after you've renamed the original file. Try to connect your modem and it should work fine now.
Feb 21, 2013 | Computers & Internet
Wireless not working pc told me error 651
In windows 7, when you try to connect using your PPPoE connections, you may be faced with the following error: Error 651: The Modem (or other connecting device) has reported an error.
These connections would work just fine with Windows XP or Windows Vista PCs.
Again, you are not alone, this seems to be a known bug in Windows 7 that is being worked at. However, you can workaround this problem.
The RAS PPPoE driver file "raspppoe.sys" found under c:windowssystem32drivers folder seems to be the root cause of the problem. Fortunately, we can workaround the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system . If you do not have access to a Windows Vista system. click here to download raspppoe.sys file (unzip)
DO VOTE ME
Dec 07, 2010 | Computers & Internet
Cannot connect to wireless network with Vista
I don not think there is a problem with your laptop. It connects to your network when you use the Ethernet cable, because the wired network is yours. As to the 4 networks to which you are trying to connect with the wireless, they must be secured as they should be. If you want to access them (and why would you since you have your own Internet connection), you will have to ask authorization from the networks owners (your neighbors). If they agree, they will provide you with all the information you require to log on and share their bandwidth.
Dec 28, 2009 | Microsoft Windows Vista Home Premium with...
Using Wireless + PPPoE at the same time kills router. SMCWBR14-G2
From your description, I am assuming you have a direct ethernet connection from an RJ45 connection in a jack in the wall. If this is the case, then you would just need to purchase a wireless router (linksys, D-link, netgear, etc). Connect the ethernet connection from the wall to the routers internet or WAN port. You will need to access the routers firmware configuration and set it to connect with PPPoE, so get your username and password from your ISP if you are not sure what it is.
You will be able to continue to have the PC plugged into the router with an ethernet cable, and then run the laptop with a wireless connection, just be sure to configure the laptop with the security key if applicable.
If you were using a software PPPoE connection on your PC, quit using it. Just set your network adapters on both computers to DHCP, and you should be good to go.
Hope this helps
Chris (ziraffa)
Jan 14, 2009 | SMC (SMCWBR14-G2) Router
DNS error when connecting PS3 to internet
you could try getting a wifi adapter and creating an access point, you can connect that way if your ps3 has wifi I have a laptop with windows XP Pro and have been trying that my desktop PC with Vista Home can see it.
MY Components:
-Desktop PC with Vista Home (Main PC, connected to Internet with Ethernet to a Linksys Wireless Router B and G).
-Get internet thru cable TV (broadband),from this cable modem plugs to router and from router to PC Vista(desktop)
-Linksys Wireless G/B Router
-G-Card for my Laptop Windows XP Pro and
-Playstation 3 capable of sharing info and use printer
At the moment all of them have internet w different IP's (000.000.0.001, 000.000.0.002,etc.). What I want to achieve is that I can use the Printer that is connected via USB to my PC Vista (desktop) and share files. Right now the only thing been able to do is that my PC Vista see my Laptop but Can't find my PC on my laptop. Anybody, Help?
-When I turn On my media sharing in my PS3, my internet on Laptop loses it while PS3 search and find,then, because laptop lost wireless,the PS3 looses the laptop and I get wireless back. I knowis a stupid setting but tired of workin back n forth. Thanks
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
I cannot install windows live messenger
well...seems that perhaps the download is being compromised by the speed of your net connection. you on wireless? try a direct ethernet connection to get that handled.
also, make sure it's the vista version of live messenger
Jun 16, 2008 | Toshiba Portege R100 Notebook
Wireless connection for toshiba satellite A135-S4527 laptop
Hi, there are few steps to allow the wireless network to get connected to the internet.follow these steps
  1. Verify that the Wireless hardware is working (Right click the My computer icon then goto properties then hardware tab and device manager.see the network adpater is corrctly installed.
  2. Then you can check the ip address in the ethernet properties.
  3. Then check the DNS server is connected
if it is not working , i have one web site here you can see the settings and devices to connect.
http://www1.umn.edu/adcs/network/wirelessxp.html
try it and inform to fixya.com
Apr 19, 2008 | Toshiba Satellite A135-S4527 Notebook
No internet connection through router D-Link DI-524
-Connect your router to the wall and connect your laptop to the router using a cable.
-Use Internet Explorer and type the following line in the address bar: http://192.168.0.1
-You should see a Username and Password Screen...type admin for the username and leave the password blank, unless of course you did give it a password.
-Next you should see the D-Link setup page with tabs across the top that say Home - Advanced-Tools-Status-Help
-Click on the WAN button on the left side of the screen
-Now you should see the WAN Settings Screen
-Click on "Dynamic IP Address" (You should not use PPPoE)
-Click on the Apply button at the bottom of the screen.
-Now close your browswer and restart your computer.
-You should now be able to access the Internet...through the router cable and wireless
-Let me know if you need more help with any of these steps.
-Good luck...and I hope this helps!!
Jan 14, 2008 | D-Link AirPlus DI-524 Wireless Router
Belkin (F5D7231-4) Wireless Router Logo
56 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
