Question about Health & Beauty
Switch will not change between on and off. It is stuck in the on position.
    Problem Solver:
  • 9 Answers
Time for a new switch. these switches are difficult to explain how they work, however usually there is a small plastic piece in the switch that breaks and gets stuck in one position or the other. also the switch itself might be plugged up with dirt. good luck.
Posted on Mar 21, 2011
  • 17,130 Answers
Please mention the product/device so that we have an idea. It can be that the switch is stuck up and is faulty or that there is obstruction to the switch. Use some degreasing/cleaning spray on to the switch as you gently move if back and forth. this might clear the obstruction.
I have a 2007 pontiac wave with key stuck in ignition, wont shift out of park and most electronics wont work (radio, power windows, etc) i changed the break switch . what else could it be?
The ignition switch is very close to the brake switch, and you may have disturbed its mounting position (not secured properly and has moved out of proper position).
Jul 14, 2017 | Pontiac Cars & Trucks
99 Navigator-Radio and heater continue to run with ignition in OFF position. Ignition switch has been changed.
Stuck ignition relay possible. With hot battery, turn key off and then feel each relay. If you find a hot one, change it.
Jan 15, 2015 | 1999 Lincoln Navigator
My nissan sentra 2001 2.0 ac fan is stuck on blowing on my feet and defrost how do i fix this?
The switch is stuck in one position. The switch is defective and needs to be replaced with a new one.
Jun 08, 2014 | 2001 Nissan Sentra
Air regulator valve on dash for heat and AC stuck in on position. Ram 2500, 2004.
The most common problem is a stuck or faulty blend door under the dash.
Feb 22, 2013 | Cars & Trucks
My suzuki burgman 650 will not go into gear
Most likely, the switch for the centerstand is stuck in the depressed position, a relatively common situation. The centerstand switch, which is exposed to road debris underneath the bike, often accumulates grime and periodically needs to be cleaned. The centerstand switch's purpose is to prevent damage to the CVT when the bike is on the centerstand, and thereby has no rotational resistance. When the centerstand switch is "stuck", the ECU thinks the bike is still on the centerstand and prevents the CVT from shifting up to a higher gear.
Sep 18, 2012 | 2003 Suzuki AN 650 Burgman
Does the blend door actuator on 2001 cavalier work electrically or by vaccum?
All done electronically with a small servo motor. Sometimes the linkages just come adrift.
Sep 05, 2017 | Cars & Trucks
Blower fan will not change speed or turn off and seems to be stuck in the 3rd highest position. Even when you turn the automatic climate control to the off position the fan continues to blow. Changing mode...
Switch needs replaced in dash. you will have to take it out of the car and put a new fan switch, should work in all positions, and since its stuck that would be what I would replace first, not sure on procedure. http://hyundaisonata.com
Feb 08, 2010 | 2005 Hyundai Sonata
The knob on 2002 alero will not change position
Trace it down to the box from the switch (lubricate WD-40) and try to turn it from there. Not sure what else it could be unless the cable between the two is broken or disconnected.
Dec 28, 2009 | 2002 Oldsmobile Alero
Health & Beauty Logo
243 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
