Question about D-Link DWA-525 IEEE 802.11n (draft) - Wi-Fi Adapter PCI - 150 Mbps Pre-802.11n
I have a 64 bit vista pc connected to a wireless network with a dwa-525 card. Ping -t to router ia fast (<3ms>), but as soon as I browse to a url, the ping time deteriorates to >2 sec or even times out. Something is throtlling my wireless connection to this pc - I have other computers connected to the same router with no problems. Anyone have an idea of how to find out what is causing this? Thks.
  • 1 more comment
  • scubamut Mar 21, 2011
    tried changing channel - still the same.
    update: replaced the dwa-525 with my older dwa-510
    Update: replaced dwa-525 with an older dwa-510 and the problem disappeared. Is there a problem connecting an 802.11n adaptor to an 802.11g router? I understood 802.11n to be backward compatible.
  • 38 Answers
If there are other wireless networks in the area it may be a channel issue with the router. You may want to reference to your users manual on how to change the channel that the router operates.
Posted on Mar 21, 2011
Wireless internet limited connectivity
The first thing to do is reset the router. There is a button on the router that you press with a paper clip.You will then have to access the router with your browser and a cat5 cable connection to change all the settings that you might need to change for security. DHCP should be enabled and there should not be an issue with the number of concurrent connections.
Feb 28, 2014 | Computers & Internet
Mac OSX 10.6.8 HP laser printer connected to ethernet port on router. Can connect and print wirelessly from one computer on network but not another. How to fix?
Can you ping from both computers? (Open terminal and try "ping <the printer's IP address>" obviously replace the <> with the IP of your printer) I'm not too familiar with Macs but can you comapre the driver version? If there is a universal HP driver, use that.
Nov 03, 2013 | NetGear WNDR3300 - RangeMax Dual Band...
I have installed a N150 Wireless adaptor DWA-525 to my desktop XP, and entered the pin etc to start the connection. However the adator is in a endless loop trying to 'Acquire a Network Address'....
go over to the bottom of the where the clock is on taskbar pace the mouse over the the little computer it shows what does it say exactly?
if its still searching right click and hit repair. If that dosent work then right click again and click on view wireless connections
Jun 23, 2011 | D-Link DWA-525 IEEE 802.11n (draft) -...
I set up my Belkin N Wireless Modem and it has been working fine. Except I did not install it with a "password" at the time of setup. How do I put in a password now. I cannot find a program in...
Hi psheayn,
Kindy copy this steps in notepad and also copy the screen shot before u start doing it.
You can put up a wireless password manually b logging in to the router interface but you should be very careful because if you change any thing else it might be a messup your whole router so kindly do the following steps alone.
Step 1: Open the internet explorer
Step 2: Clear the address bar and just type the number alone which is 192.168.2.1
Step 3: You will get router screen as below
Step 4: In the left corner of the page under "Wireless" Security and select security mode as "64 bit WEP "
Step 5: Type any 2 numbers per box as u like and apply changes. Also make sure that you are gonna copy the password. If you want to connect any other computer in future you will need to have that password to connect.
Step 6: Under security in left side select "WPS or Wifi Protected Setup" and select WPS as disabled and apply changes. Dont worry it not related to security its just an option that has to be disabled if you enable the 64 bit WEP password.
Step 7: Then Connect wireless computer to the wireless network name and will ask for the password this time since password has been enabled. And ur router is gonna be a protected one and no one can hack it.
Step 8: In case if ur not able to connect to the network remove the preferred network and connect to it.
To remove preferred network
XP OS
Start -->control pannel --> Network and Internet connection-->Network connection --> Right click on Wireless network connection icon --> Select 2nd tab Wireless network --> Remove preferred network one by one.
Windows Vista/ Windows 7
Start -->control pannel --> Network and Internet connection -->Network and sharing center --> In the left side select Manage Wireless network and remove preferred network one by one.
Check out the screen shot to enable security on the Router and to disabled WPS
Nov 06, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
My Belkin wireless router works fine on my Toshiba (Windows Vista 64 bit), but will not connect wirelessly to my Sony (Windows Vista 32 bit). At one point I heard it had to have settings changed for the 32...
No issues like that.
Network should show up no matter what the OS is, if the wireless card is working fine.
If u r not able to connect after that, check the security settings in the computer.
Nov 03, 2010 | Computers & Internet
Connection to linksys wrt300-n router drops frequently from wirelessly connected laptops - even when sitting in the same room mere feet away from the router. I've set it up to use MAC filtering and AES...
Try to Disconnect and Connect the Internet Manually in the Wireless Network Connection. Also this can be a problem with our Computer or Laptops Lan Card which may be having issues in connecting.
Sep 13, 2009 | Linksys WRT300N Wireless Router
Connecting Linksys wrtu54g wireless router with Linksys SPA 2102
If you want to receive "incoming" telephone-calls:
ADSL modem <---> Linksys SPA <---> wrtu54g <---> wired computer
and Linksys SPA <--- telephone-line-1 --> telephone hand-set
and Linksys SPA <--- telephone-line-2 --> FAX machine
or Linksys SPA <-- telephone-line-1 --> mechanical telephone-splitter
with telephone-splitter --> hand-set
with telephone-splitter --> FAX
Mar 19, 2009 | Linksys Wireless-G Broadband Router
WLAN having consistant high latency with frequent all-out fail
I would suggest borrowing a different known working wireless adapter, and test trying that. Or test using a wired connection, just to prove it is the adapter. Perhaps the wireless adapter you are using is flaky.
Jan 10, 2009 | Linksys WRT300N Wireless Router
Dwa-142
It wil work in vista..
Vista drivers here..pick the latest v 1.30
ftp://ftp.dlink.com/Wireless/dwa142/Drivers
Sep 23, 2007 | D-Link RangeBooster N DWA-142 (1010125954)...
D-Link DWA-525 IEEE 802.11n (draft) - Wi-Fi Adapter PCI - 150 Mbps Pre-802.11n Logo
189 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
