I've a JVC Television model AV-S29F8S. Whenever I turn on the TV, the sound volume goes to the maximum even though I had lowered it before I switch off the TV. Please help to identify the fault.
techman
  • 3130 Answers
SOURCE: jvc av-28gt1sjf
This sounds like a microprocessor controller problem?? Try to reset the tv by unplugging overnight and starting fresh in the am. If it will go in av then your all set BVut if it dosent go into the menu to see if theres any kind of lockout in the set up for the av. If not then youll have to have the set looked at by a pro. Good Luck
Posted on Jun 07, 2006
  • 1153 Answers
SOURCE: JVC AV 270305 Brightness not Bright enough.
Yes you could look for the capacitor that is leaky, probably in the 200v line, or you could just open back and turn up G2 screen control on the Flyback. You have Screen and Focus on this black transformer with a long anode lead going to the picture tube of set. Becareful, High Voltage!
Posted on Sep 08, 2007
SOURCE: FLM 3232 television low volume
I hooked my tv up and there is no sound coming from the tv. I do not have surround sound just the tv. How do I make it work I need volume please
Posted on Jan 15, 2008
SOURCE: no sound on JVC AV-48P575 48 inch rear projection TV
Try going into the menu and find something called, "center channel input." If it is on, the sound will not work. Turn it off, and the sound should be restored.
Posted on Dec 15, 2008
SOURCE: Sharp Aquos LC-26D4OU HDTV volume adjustment problems
I found that the problem was also with my HD box. I was able to turn the volume up on the box.
Posted on Jan 06, 2009
How do I reset the volume on my tv?
your controlles on the tv set itself goes faulty simply spray some switch cleaner in buttons should sort you out
Sep 15, 2014 | Toshiba 40RV525U 40 in. LCD TV
How to find JVC AV27320 headphone jack? I've plugged into the avs(red & white) in the front panel as well as the extra ones in the back. Altho - I CAN hear the sound thru the headphones, The external...
This model doesn't have a headphone jack. The only JVC TV in the series that does is the model AV-20D202. For the JVC AV-2732, use the RCA audio out jacks with an RCA to 3.5 mm adapter to connect to the headphones. The front audio jacks are audio in (for the audio from a video camera for example).
When you use any external speakers or headphones through the audio out jacks, make sure to turn off the TV speakers. Press Menu and navigate down to TV Speakers (up/down arrows). Then use the right/left arrows to select Off and then Exit the menu. Make sure you scroll the TV volume before doing this. Note: if your headphones do not have a volume control they are a bad choice for this type of audio output.
You can find the manual for the TV here: http://books.jvc.com/booklist.asp?Model=AV-27230 .
I wish that I had better news for you.
Jan 06, 2011 | JVC AV-27320 27" TV
JVC Model #: AV-56p575--------problem with power
If this clicking is a continuous clicking sound its likely that its coming from the ballast.The ballast is the component that powers the lamp.If this component fails your lamp wont ignite and wont allow the start up to continue.
Jul 16, 2010 | JVC AV-56P575 56" Rear Projection...
Low Volume despite High setting on TV
HI I am having the same problem. tv sound is fine, then fades so that 50 is the only sound volume to hear the show. It happens intermittently. Did you get your's solved? thanks
Jul 06, 2010 | JVC AV-27050 TV
My sharp aquos television sound is very low even on max.
I had this problem with my Charter and the box had a sound button on the actual box, not the remotes. Now I have switched to Direct TV Box and have found while not so low I can't hear it, it is much lower than I know it can be and have to turn it up in the higher numbers or turn on the surround sound to hear it. Anyone know what to do with Direct Box, Direct didn't know.
Sep 05, 2009 | Sharp LC-26D4U 26 in. LCD Television
Jvc i art av 36f475: no sound
Good Day sir/maam, my guess are several, lets start at the common ones, make sure that the AV cables are good. you can try swapping cables to make sure. If possible try the cables on other units such as any DVD player. There is a possibility that the sound jack, is bad, try to vibrate the plugged cable, and see if the sound goes back if it does, you need to solder the terminals. Worse is the Amplifier section of the TV. does the TV sound normal on broadcast? check the volume, mute. or the TV setup. hope this helps. if you have additional info please feel free to ask again, let me know any progress. thanks
Jul 28, 2009 | JVC AV-65WP55 65" Rear Projection...
JVC model AV-F2983
i move you out of HP computers
to TV , JVC
asking TV repair, in a text box?
its huge topic, take a class on this?
ask JVC for books, yet,
or goggle all day for ********/?
Aug 19, 2017 | JVC AV-32F476 32 in. Television
Volume automatically goes to maximum
This sounds like there is a stuck button. With the TV off, try each of the panel buttons. You should feel the button engage. If not, that is the faulty one that should be replaced. Also, check to be sure that the plastic covering that extends to the actual switch inside the set is not broken causing a switch to be stuck on.
Keep us posted.
Dan
May 01, 2008 | Televison & Video
No sound on JVC AV-48P575 48 inch rear projection TV
Mar 23, 2008 | JVC AV-48P575 48" Rear Projection...
Jvc tv on button flashing on av 48wp34
Use remote, sounds like Tv is in child lock
Dec 21, 2007 | JVC AV-48WP30 48" Rear Projection...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
