Dear , sir now i have only CD driver . can i change or put DVD driver for my computer.?
  • 89 Answers
Yeah,you can do that,get an IDE interface DVD ROM .Ask the shopkeeper for an IDE interfaced DVD ROM only,be aware he may give you a SATA compatinle DVD ROM.
Thank You.
Posted on Mar 21, 2011
Sir, my lg cd/dvd burns cd all right.Recently,it has started giving trouble. Writing dvd, the burning step seems to hang up.The bar indicator stops at 1% and the dvd does not seem to be spinning at all.If...
you might have to uninstall the cd/dvd restart your computer then reinstall it
make sure that the cd/dvdrw is getting enough consistent power test all leads that are attached to the cd/dvd including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your CD/DVD or uninstall the driver then reinstall for this device
control panel administrive tools,computer management,device manager scroll down cd/dvdrw drives you might see a yellow question mark? this means the driver needs to be updated right click to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
May 14, 2011 | LG Computers & Internet
Dear Sir, Madam My computer crashed and now all
If you have the software to your ( OS ) Operating System re-install and boot from the CD. There should be an operation for repair or reinstall for now choose repair. Allow the computer to boot and then reinstall all your software including downloading the latest drivers for your NEC be sure the drivers are compatible with the ( OS ).
Feb 28, 2011 | NEC ND-3550A DVD RW Dual Layer Burner
Dear Sirs, I have a Smart& Friendly "CD
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Dec 13, 2010 | Smart and Friendly TurboWriter (SAF795)...
Dvd player does not play cd or dvd.
Dear Sir,
Try to check the data cable of your dvd player.
Jul 20, 2010 | Samsung (TS-H352A/WBGH) Internal DVD Drive
Sir, I purchased LG DVd writer,i intalled
put the lower or higher version of power dvd software
Sep 29, 2009 | LG Computers & Internet
Laptop not show cd or dvd when i put it
Well, for starters, is your cd/dvd turned on in the bios.  Some but not all computer have a setting for this.  If your cd/dvd drive is removable, shut down the computer, remove the drive.  Reboot the computer and shut it down again.  Then reconnect the drive and start the computer back up.  This will make sure that if your drive is working, windows will redetect it.  You can check device manager to make sure it is not disabled.  If none of this works, you may have a bad drive.  If you really must reinstall windows, you can get an external cd/dvd drive pretty cheap on Ebay.  Just make sure you go into your BIOS setting and change the boot menu to external drive.  I hope this information helps.
May 30, 2009 | HP Compaq Presario C700T
NEED INSTRUCTIONS ONHOWWO FORMAT MY ACER ASPIRE 5100 SERIES
hi there
there are couple of steps involved in formating the laptop.
i will try to give simple and easy solution
--> save/backup all your important data into external hard drive or DVD/CD so you will not loose the data
--> i hope you have the xp cd with you
--> put the xp cd in the drive
--> restart the computer
--> press del/f2 to go to BIOS (setup)
--> in boot configure first drive should be your dvd drive
--> press F10/ save changes and exit
--> it will ask press any key to load from cd
--> after that the xp setup will start
--> follow the instructions
--> you can delete and create partitions here too or simply format the drive
--> install the xp
--> install the drivers
--> your laptop is ready to go but dont forget to change the BIOS setting to normal again.
hope it will help you sir.
Mar 25, 2009 | Acer Aspire 5500 5570-2609 Laptop
C'not detect my computer the ethernet contruler from mother disc
dear brother i hope you got the cd/dvd with your laptop when you bought it.
put that cd in and run it
it will install the driver
i hope it will help you sir
DVD DRIVE OF MY HP LAPTOP
what of a laptop is it this??????
Sep 21, 2007 | Toshiba SD C2502 Internal DVD Drive
DVD reading problem
1. go to device manager / right click on cd drive / uninstall driver / reboot and windows will reinstall driver 2. go to My computer right click on cd drive properties - check digital cd playback recording - check enable cd recording on this drive driver - update or uninstall reboot your computer Goodluck!
Jan 18, 2007 | Sony (DW-D22A/B2) DVD±RW Dual Layer...
Computers & Internet Logo
Alun Cox
David Payne
David Payne
