Question about Nokia 5200 Cellular Phone
My navigation key does not works properly even ok button is also not working . i have cleaned its surface sometimes it was helpful but now i can not acceess plz help.
Change the flex cable of your mobile
flex cables are as shown below
Posted on Mar 21, 2011
Hello sir my name is makarand kelkar i'm 4m mumbai my cell phone is nokia 5130 my cells kye pad is not work properly means navigation key of left & right & also go to key and music kye...
The Navigation key set can be changed, it will cost around Rs.250.... Just take it to a mobile repair shop and ask them to change the key navigation board. It is very simple, even you can buy the spare and change it yourself... But the music keys I'm Not sure they will work or not, because it is a well known complaint in Music series of Nokia and nothing can be done properly(so don waste time in spending money for music keys)...
May 13, 2011 | Cell Phones
My nb100 laptop. keyboard some keys not working.
There are various ways of solving this issue. Some of them has these broad explanation.
Problem #1 - My Laptop Keyboard Keys Not Working
Sometimes you may find certain keys of your laptop keyboard not working properly. You type those keys but there is no output on the screen or you need to press these keys firmly to get a result. You face this problem if you accidentally spill any liquid substance on your keyboard, or due to dust accumulating on the inside of the keys, pressing certain keys really hard while playing games or even due to absence of lubrication. Therefore you are suppose to maintain your laptop keyboard by cleaning and lubricating it regularly.
Troubleshooting Steps
  1. To start with, take out each key out from the laptop keyboard. Use a small screwdriver to carefully pry each key by making it loose. As they become loose, keys will simply pop off. Also, take out the rubber piece present under every key. Keep the keys and rubber pieces in different containers.
  2. Once you have removed all keys from the keyboard, you will have to clean the keyboard from the inside. Use cotton swabs or ear bubs and slightly dip them in water. Avoid getting them too moist, as excess water can damage the keyboard. Meticulously clean the whole keyboard using moist cotton swabs, laying extra emphasis on key spaces.
  3. Now, start cleaning keys you had earlier removed and kept in the container. Use foam rubber and lighter fluid to clean each key alone. This will help in removing any sticky substance present on keys. Apply any household cleaner on these keys and let them stay for about 15 minutes. After this, wash all the keys properly using hot water and let the keys dry completely.
  4. The small rubber pieces which you took out earlier and kept in the container have to be thoroughly rinsed in warm water, after you have sprayed a household cleaner on them. Soak these rubber pieces up in paper napkins so that they dry quickly.
  5. To lubricate the keys, place all keys (facing top-down) on a flat surface. Apply mild lubricant from all sides, on all keys and leave them to dry. Avoid applying too much lubricant instead go for a light coat.
  6. Similar to the manner in which you lubricated the keys, apply mild lubricant on the keyboard surface and let it dry.
  7. Once you have cleaned and lubricated all the parts, carefully reassemble the laptop keyboard. Begin with placing all rubber components on the keyboard. Next, fix all keys in their respective positions cautiously securing the wire in these keys. Use your finger and press down all keys, one at a time, firmly so that they fit properly in the slots. That is it.
The complete process will take you a maximum of 2 hours. Cleaning and lubricating the laptop keyboard in the above prescribed manner once a year, can prevent many 'laptop keyboard not working' situations.
Problem#2 - My Laptop Keyboard Types Wrong Characters
When your laptop keyboard types wrong characters, it is because of a software problem and not a hardware one. If you accidentally press specific keys on your keyboard, it can activate a particular function responsible for the problem.
  1. Select the control panel option
  2. Click on ? 'Regional and Language Services' ? 'Languages' ? 'Details' ? 'Key Settings'
  3. Choose the option 'Switch Between Input Languages' and click on 'Change Key Sequence'
  4. Make sure that all the check boxes in the window are unchecked and repeat the same for 'Switch to..... (Keyboard Type)'
  5. Click ?'Ok' ? 'Ok' ? 'Apply' ? 'Ok'.
Problem#3 - My Laptop Keyboard Types Numbers Instead of Letters
This is another laptop keyboard problem due to some software issue. It is possible you may have enabled a digital lock unknowingly.
Pressing the 'Function' key along with the 'Num lock' key (Fn + Numlock) or press the 'Function' Key along with the 'Shift' and 'Num Lock' key (Fn +Shift + NumLock). This will disable the lock and consequently solve your problem
Dec 20, 2010 | Computers & Internet
Hello sir/madam , in my nokia n70 device the left navigation key and the buttons 1 and 3 does not work . up and down navigation keys are also not working . kindly tell me the right solution
Hi Friend!
The best advice I can give is that you bring your phone to a technician for check up. You might not want to tinker with your device on your own and end up with a dead unit altogether but if you wanna give it a try, the problem somestimes is a dirty or corroded keypad. Remove the membrane attached to the keypad and use a cleaning solution such as a paint thinner to clean the keypad surface. Use a piece of cotton with the solution. Another thing you should also check is the keypad connector. Check if it is properly aligned.
Dec 19, 2010 | Nokia N70 Cellular Phone
My navigation keys do not working properly
It might be your navigation key has a loose connection to your cellphone that is why sometimes it does not work properly... I am recommending you that you must change your cellphone casing
Jul 30, 2009 | Nokia N72 Cellular Phone
Navigation Wheel Center Button Doesnt Work
Sometimes what happens is that the receptor in the back of the device gets corroded (or sticky from kids) and it causes the buttons not too work fortunately if a Verizon Wireless is unable to see any physical damage they should warranty replace the device without any problem, and even if your device is out of warranty they offer a replacement for 50 dollars which is still cheaper than having a cell phone repair tech actually fix it for you, if the store will not do it for you call the customer service 800-922-0204 and they will change it for you. hoped this help!
Mar 05, 2009 | LG CHOCOLATE VX8500 Cellular Phone
The JVC remote control, model JVC RM-SXVS60J, has stopped working as far as the bottom buttons go even though the top buttons work fine. If you can help, please.
Since the top buttons are working fine, i doubt that the remote is faulty. Sometimes its due to moisture/dust accumilating on the remotes board and creates a barrier against the board and the buttons. You may need to open the remote and clean the surface of the mainboard.
Hope this helps
JigSaw
Aug 04, 2008 | JVC AV-56WP74 56" Rear Projection...
Erratic keypad
It must be dissassembed Clean both surfaces (pad bottom surface and board up surface so they would have good contact) with alcohol solution liquid sweep and let them be dry. Next assemble it again and test it. if START KEY persit not working even if it is clean, a small leaf of aluminium must be stuck at the pad bottom of START KEY. Be sure you can carry out this procedure well done otherwise you 'll need to buy another keypad. Good Luck!
Jan 05, 2008 | Kenmore 63672 Convection/Microwave Oven
Keypad not working
you will need to take the case off the phone and check behind the buttons where the pads touch the circuit board these sometimes get greasy or dusty causing it to not create a conection between button and the circuit board clean the circuit board with dry dust free cloth look for signs of grease or water damage if this is clean or after cleaning put phone back together and try buttons if they still dont work you could try replacing the keys that you press as sometimes after alot of use these fail to connect with the board properly causing buttons not to work if you replace these and still dont work then it could be a warped board this happens if you have sat on phone or had it in pocket and let on something causing pressure on the case and this will warp the board their is no cure for this the only thing to do is buy new phone as a new board will cost as much as the phone hopefully this is not the case it might just need your keypad replacing try my first two sollutions first if this dont change anything then i would take it to repair shop and see if they think it is a warped board hope this is some help to you
Nov 01, 2007 | Nokia 7610
Nokia 6255i keypad problems...PLEASE HELP!
if you manage to open the phone you go to the face plate were the key pad is possitioned and clean it with isoprophyl alcohol that can curethe problem . advice by dogy
Jul 03, 2007 | Nokia 6255i
Nokia 5200 Cellular Phone Logo
44 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
