How i connect my mbox 2 mini with my behringer minimon MON800 stereo monitor matrix mixer, i have 2 pairs of studio monitors
  • 4234 Answers
SOURCE: connecting a behringer djx700 mixer to a panasonic amp
The problem is most likely between the turntable and mixer. You need to be sure that the turntable is connected to a phono input. I'm not sure if your mixer has one. If not, you need to have a phono pre-amp between the turntable and the line input on the mixer.
Check that first and get back to us if you still have problems/questions.
Dan
Posted on Aug 21, 2008
SOURCE: need woofer for B2030A
Check the watts and size on your old woofer and go to radio shack and get a repacement woofer with the same wattage and size.
Radio shack make great replacement speakers and woofers.
Posted on Feb 14, 2009
  • 5603 Answers
SOURCE: Hum and Buzz Ground Loop
Best way is with balanced audio lines. Use either XLR or TRS cables IF your devices have those connections.
Also, do NOT use light dimmers as these are often a source of the higher frequencies that cause buzz.
Also power ALL the interconnected audio devices from a single source outlet rrather than from mulltiple building receptacles.
Posted on Jul 28, 2009
SOURCE: Connect Dell Mini with HDMI to VGA PC flat monitor
hi,
you would need an HDMI to VGA adapter. sometimes it would come in a form of a separate cable or just a regular adapter which would convert the HDMI end to VGA (the blue one that has 15 pins)
you can purchase these cables from your local computer store.
hope this helps
Posted on Jul 12, 2010
  • 5603 Answers
SOURCE: How do i connect 2 monitors to the one monitor
The monitors will have to be POWERED monitors with built in amps.
You can simply use a wye splitter cable to drive the two monitors. Run the cable from the mixer to one monitor and put a wye cable and an extention to the second powered monitor speaker.
Posted on Jul 25, 2010
Testimonial: "Thanx, just what i wanted"
How to connect behringer ms16 monitors to a xenyx q8o2usb?
Hello, i've read and watched the manual and the xenyx itself and what. there is to understand if you just read everything. Your speakertje come at the output of your xenyx and that thing you can use as audio source or put your soundsources in your mixer and just play it.
  • Built-in stereo USB/Audio Interface to connect directly to your computer. Free audio recording, editing and podcasting software plus 150 instrument/effect plug-ins downloadable at behringer.com
So just use the mixer as your audio interface and your ready. The xenyx is nice for the money, the ms-16 which they call 'studio'-monitots is offcourse nonsens. Nice sounding laptop speakers are they, but in a home studio you need at least speaker 400euro/piece , but you can play with this nicely.
Aug 31, 2014 | Behringer Audio Players & Recorders
Where can I get a schematic for the output section of the mixer on a behringer 1280s?
No hope. I have replied to this sort of question elsewhere but Behringer are very protective of their stuff and won't even let us have diagrams. Only Behringer service. If anyone has any Behringer service manuals / schematics we would love them
Oct 31, 2013 | Behringer B3031A 2-Way Active Studio...
Monitors not audible with Behringer 1680S
Assuming you're trying to power the monitors from this unit as well as the mains.....Confirm that the amp switch is in the middle position which splits the internal amps....one for main and one for monitors. Output A would power the monitors.... B would power the mains.
Aug 26, 2012 | Behringer PMP1680S Europower 10-Channel...
Behringer Xenyx 1622FX - How do i get a passive stage monitor to work?
You need to send your signal from the mixer to an amplifier and then go from the amp to your speakers.
Alternatively, buy a pair of active speakers.
Jun 06, 2012 | Behringer XENYX 1622FX Premium 16 Ch Mixer...
Hi i would like to know how to connect in ear monitor to my behringer xenyx 1002fx
by in ear monitor I assume you are talking about a set of stereo headphones.
These would plug into the PHONES jack, which is located just to the left of the MAIN OUT jacks.
If your headphones have a 1/8 inch jack, you will require a 1/8 inch female to 1/4 inch male stereo adapter.
These are fairly common, and can usually be purchased at any audio store or Radio Shack or The Source by Circuit City.
Apr 09, 2011 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Hi, We have recently purchased a Behringer PMP6000/VP1220/VP1220F PA package we have a pair of speckon to 1/4 TS connectors and a pair of 1/4 TS to 1/4 TS connector cables we have the mains on tripods and...
Please read a tip I just posted regarding a hazard of the Speakon to 1/4 inch cables when used with these PMP mixers.
If you are using your main speakers as stereo, then you will need either powered monitor speakers OR an additional seperate amp for them. The mon outputs on the mixer are LINE LEVEL and are not driven by a power amp. Use TRS (balanced) interconnect cables from these to POWERED monitor speakers.
You can parallel your two mains providing the parallel impedance is 4 ohms or greater (two 8 ohms in parallel at most). The the monitor speakers can be paralleled and the switch set to Main/Mon so that one side of the power amp drives the mains and the other drives the monitors.
To prevent damage to the mixer, make sure all speaker leads are secure before powering the system. Run the speaker leads through the handles of the speakers to prevent inadvertent unplugging due to personell tripping over cables.
DO NOT use the bridge mode in your use.
Aug 07, 2010 | Behringer Europower Pmp5000 Powered Mixer...
How can i connect a behringer eurorack to a mbox 2 for protools
basic speaker cable from the eurobacks speaker output to the di selection on mbox... in one of the input slots
Jan 15, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
I have a behringer xynyx 1204,and a protools personal studio,with mbox2 mini,and im just wondering if its possible to plug the mic into the mixer,instead of the mbox,and still be able to record vocals into...
It is possible, you can simply put a Y-cable for Mic or a splitter for the mbox and the Mic. You can plug the mic directly to the mixer then the other jack on the splitter connected to the mbox.
Jul 25, 2009 | Behringer Music
Multiple audio noises even when mixer faders are down
100% raidiation problem!
it was wid my denon protech also,
see if earthing is correct for all gears,
try keeping an equidistance of 10"inches between each gadets
May 25, 2009 | Digidesign MBox 2 Mini (USB, includes...
Connection to Mixer
I am not sure about that brand but on my Roland Speakers, the TRS jack lives inside the XLR. I first missed it. Take an XLR and try to connect. I can't imagine that they would not have XLR especially for studio monitors. Also are your speakers passive or active, that is something that I would seriously at. No amplitude, low signal, no active.
Aug 18, 2007 | M-Audio DX4 Active Studio Monitors (Pair)...
52 people viewed this question
 Grubhead
Grubhead
