Question about Jabra BT8010 Wireless Headset
Hay my Jabra bluetooth is reading Upgrade mode SW ver.:1-33-0 when i plug the charger to it. But when i unplug the charger it doesn't work. How do i fix this ?
4 Suggested Answers
SOURCE: Not sure if Jabra bluetooth headset or charger that not working
I had the same problem, called support, they told me battery is defective or too old and doesn't accept the charge. Battery in a headset is hardwired and can't be replaced, so the whole thing is trash :(
Posted on Jul 10, 2007
  • 53 Answers
SOURCE: Jabra Bluetooth not charging and startup
You can visit an expert technician for hands on service.
Posted on Oct 20, 2008
  • 12 Answers
SOURCE: i lost the charger for
Hey there sanjeev! There should be an USB port on the back of the headset, it is the micro-usb port. Therefore, if you have a cable from your camera, mp3 player or any other gadget that uses a micro-usb port, take their cable, plug it into the headset and let it charge! :D
I hope it helped! Take care! :)
Posted on Mar 04, 2011
Cant pair my iPhone with jabra sp5050
forget the headset
turn bluetooth off
turn the headset device off
reboot phone.
try again
Mar 04, 2014 | Jabra A320s Bluetooth Wireless Adapter
How do I pair it with my phone? i lost the manual If I just turn it on, it my cell doesn't seem to find it. It says to put the Jabra in discovery mode. How do I do that? Also, do you know how I can...
Christine,
To put the Jabra in discovery mode, turn it on and hold the answer/end button for five seconds until the bluetooth light starts flashing and it announces "pairing mode." Then connect with your cellphone!
You can order a new charger for your car/computer from this link:
http://www.buyjabra.com/US/accessories/universal-charging-kit-car-usb-136.html
Or, for your wall from this link:
http://www.buyjabra.com/US/accessories/us-wall-charger-for-bt530-jabra-halo-144.html
Best of luck!
- Zach
Mar 05, 2011 | Jabra Cruiser InCar Speakerphone Black
I cant pair my jabra bluetooth to my evo!
First, put the headset into pairing mode. To do this, remove it from the Stone charger and press and hold the answer/end button until the lights flash four times slowly - this indicates that the unit is off. Then, press and hold the answer/end button again - you'll soon start to see lights flash - hold the button until the green light is on steady and the blue light is flashing. This is pairing mode. Now your Evo should be able to "find" the Stone to pair with it from within the Bluetooth menu on the phone.
Jan 20, 2011 | Jabra Stone Bluetooth Headset
My headset will not turn on
Hello
Your bluetooth headset is powered by an internal battery. If the battery is not charged,it just won't turn on. Fully charge your battery before use.
Make sure that the power outlet you're using is working and that the cord is fitted correctly into the wall, PC or Car outlet and the Jabra Bluetooth device.
Try unplugging the Jabra Bluetooth device and see if it turns on. If so, use the Jabra Bluetooth device until the battery is completely exhausted. The next time you charge it, check that it is charging properly
If the Jabra Bluetooth device is still not charging, check what happens when you initially plug the Bluetooth device into its charger. If the light on the Bluetooth device flashes on and then off again quickly, it is likely that the battery is no longer working. Batteries cannot be replaced or covered warranty
Dec 30, 2010 | Jabra BT150 Wireless Headset
Jabra SP700 will not turn on. Charged until green light came on. Took off charger, and put it back in. Light turned red. Eventually went green again. Will not turn on. Back to red when I plugged in...
You've probably accidentally put it in locking mode. Here's what the manual says about it, and how to get out of it:
Locking mode
To prevent accidental key presses that could turn your speakerphone
on e.g. while carrying it in a bag, the speakerphone can be
turned into locking mode. Press simultaneously the Answer/End
button and FM button for 4 seconds while the speakerphone is
turned on. The speakerphone is now turned off and can only be
turned on again by pressing Answer/End button and FM button
simultaneously for 2 seconds.
Sep 24, 2010 | Jabra SP700 Bluetooth Car Kit
Jabra BT3030 Device in Discoverable Mode?
Read the users manual(google is your friend)
But in case they drop support soon, turn the beastie on, press and hold the Vol+ and Answer Call buttons till the "on" light goes solid. You're now in discover mode.
May 15, 2009 | Jabra BT150 Wireless Headset
BT350
try turning bluetooth off . first erase bluetooth connections on phone. turn off phone and take out phone's battery for ten seconds. put battery back in and turn on phone. plug bluetooth into charger for ten seconds and unplug it. try re-pairing bluetooth with phone. This worked for me!
Mar 06, 2008 | Jabra BT350 Wireless Headset
Jabra vbt185z, light stays on, won't connect to phone
My head set had another pin code other than 0000 when I recieved the unit which made it dificult to connect. I learned how to reset it to the default pin of 0000 which allowed me to sync it with my phone. After using it for a month or so my phone requested the pin again.I entered 0000 and once again would not accept the pin. I had to retore the default pin again and it works just fine. Here are the instructions. Plug your vbt185z into the wall charger and while connected press down and hold the center blue button untill the light comes on.(about 30 seconds)Unplug the the ear piece and turn the unit on.Now enter pin 0000 and your phone should accept the pin.
Dec 29, 2007 | Nokia 1600 Cellular Phone
May 26, 2007 | Jabra BT250 Consumer Headset
Jabra BT8010 Wireless Headset Logo
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
romy sibug
romy sibug
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
