Question about Maytag Washing Machines
Maytag W-7 Washer water fill does not stop
My Maytag W-7 top load Washer water fill does not stop and the water level goes up and overflows. i suspect the small rubber tube that connected to the bottom of the drum. looks like a probe tube. it fell off its top clamp and i put it back, not sure at water level it needs to be. no leaks thru drum or joints- just overflow because of water fill
thank you for your help
Gregory
    Scholar:
  • 111 Answers
Yes, I think that rubber tube measures water level. But I've never changed one. Good luck.
Posted on Aug 02, 2008
Roper top loading washer RTW440VQ1 will not stop filling up
The pressure switch, also called the water level switch, is what control the amount of water goes in the machine, If your machine is constantly filling to the overflow point, then that is your problem. Now, if water is going in and the level is staying the same then your machine drain line is lower than the pump and your siphoning out the water as it goes in. Pull the drain up a little a that should fix the problem.
May 22, 2012 | Roper RAX4232KQ Top Load Washer
My washer fills with water and keeps filling doesn't stop on the selected water level for the load. It doesn't wash because the water keeps filling. What's wrong with my washer? Help please (Maytag...
The problem is simple and easy to fix. Your washer has a tubing which runs from the base of the tub to the water pressure switch. It might have vibrated loose from the switch, or their can be some sediment in the tub. Blow out the tubing and reattach it securely to the switch and pump out the water in the tub. Then try it again. I wrote an article about this:
Help my washer is overflowing !!!
Jan 07, 2011 | Maytag PAV2300 Top Load Washer
LSE7806A stack: the wash fills to the water level/load size selected. it starts to agitate then stops and begins to fill with water again which causes overflow, help please
Your fill sensor is leaking and allowing air pressure from the clear tube to seep out. First make sure your clear tube from the tub to the water level valve is firmly connected. If it is then you may need to get a new water level adjuster switch.
Mar 09, 2010 | Maytag LSE7806A Top Load Stacked...
Washer fills, but overflows, will not go into wash cycle on any water level or washer setting, however on final spin cycle will spin water normally!n HELP!!
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Feb 11, 2010 | Maytag PAV2300 Top Load Washer
Maytag Top loading Washer, fills but won't stop filling and then overflows and will not start the cycle
there is a small tubing about 12 inches or so that connect from the water level dail to the tub of the washer. sometimes the clamp on there gets loose and that interfers with the communication. try changing the tubing and or just tighting the clamps. you will need to lift the top of the washer off to get to it.
hope this helps
Mar 06, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer overflowing
Remove the tube from the water level switch. Blow it out so the sediment will stop blocking the tube. Re-attach it and pump out the water. Retry.
Jan 04, 2009 | Maytag PAV2300 Top Load Washer
Washer won't stop filling with water
In yor machine control panel you have A part called a pressure switch or water level switch. that controls the water level and tells the timer to start aggitating .If the part is bad the machine will over fill and keep running the water!!
Sep 01, 2008 | Maytag PAV2300 Top Load Washer
Fill switch cutoff
remove the 2 screws on rear of console pull console slightly forward and roll it up and back..ck small hose to water level switch to be sure it is on..is water stopping when control knob is pushed in?? if not suspect inlet valve replace it ..if it does suspect water level switch or that hose also hose may have small hole in it somewhere or be pinched
Aug 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washer
this could be the water level switch or the small flexible plastic tube that goes from the water level switch to the side of the tub. this tube may have worked loose if the washer is vibrating too much.
Jun 30, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
156 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
