How can i changes laptop themes theres no setting at control panel
    Sergeant:
  • 236 Answers
Suspect your are trying to change your desktop's theme and it is not apparent on the Control Panel as to how to do this so please do the following...
1. on the lower left of the desktop, click on start
2. on the start pop-up, click on Control Panel
3. on the Control Panel window, double click on Display
4. on the Display Properties window, under Theme: click on v to get a drop-down list of themes
5. select one of the other listed themes or look for more themes online or browse your laptop
6. click Apply button to see the look of the new theme or click OK to apply and exit Display Properties
Posted on Mar 21, 2011
  • 89 Answers
Right click anywhere on the desktop screen,you will get a drop down menu.Click "properties"(for win xp) or if its win 7,select the last entry on the list.You will get your theme settings.
Thank You.
2 Suggested Answers
  • 18 Answers
SOURCE: how do i change the setting in the control panel
go through the display options in control panel, and if intel than into the intel graphic options, tv wizard.
Posted on Jan 14, 2010
How do I change my screen Resolution to 1024 X 600. I have a Dell Windows 7.
  1. Close all open programs.
  2. Click Start, and then click Control Panel.
  3. In the Control Panel window, click Appearance and Themes, and then click Display.
  4. In the Display Properties window, click the Settings tab.
  5. Under Screen resolution, click and drag the horizontal slider control to change the screen resolution, and then click Apply.
  6. When prompted that Windows is about resize your desktop, click OK.
*If a Compatibility Warning window appears, click to select Apply the new settings without restarting, and then click OK.
Feb 23, 2015 | Dell Computers & Internet
The text on my pc keeps going blue, how can I stop it?
Windows allows you to change the themes of your computer. This includes the wallpaper, the screensaver when your computer is idle, any noises it makes, and even the color of the toolbars and windows. Sometimes, however, when you restart your computer, the theme will revert back to the Windows default theme, which is called Aero. This can be because you have not disabled Aero, because your performance settings are using too much energy, or because your screen resolution is too high or low for the theme you are using.
Screen Resolution b> The higher your screen resolution, the sharper the images and text will appear. Sometimes, however, the of the wallpaper for the theme is not the same as the screen resolution. This can cause your theme to revert back to the default. To fix this, click the "Start" button. Then click "Control Panel." In the "Control Panel" window click "Adjust Screen Resolution" under "Appearance and Personalization." Select the resolution that is the same as your wallpaper. b> Performance Settings b> If your computer is running on high performance settings, your computer's energy will be used quickly and Windows may automatically change the screen saver to keep the energy from running to low. To change your performance settings, open the "Control Panel" and click "System and Security." Then click "Change Battery Settings" under "Power Options" and select "Power Saver" or "Balance." b> Disable Aero b> Aero is the default theme setting for Windows Vista and Windows 7. If you try to change your theme and it reverts back to Aero, it is because Aero is still not disabled. To disable Aero, right-click on your desktop and click "Personalize." A window of all the themes on your computer will open. You will see "My Themes," which are any themes you have created, and "Aero Themes" under it. To disable Aero, click "Save Theme" under "My Themes" to make your current settings default, or select one of the themes under "My Themes." This will make that theme the default. b> Troubleshooter b> If you still cannot figure out why Windows changes the theme back to the default after restarting, you can use Windows's built-in troubleshooter. The troubleshooter will find the source of the problem and automatically fix it for you. To use the troubleshooter for your theme, open the "Control Panel" and click "System and Security." Then click "Troubleshoot Common Problems." Under "Action Center," select "Appearance and Personalization." The troubleshooter will run. When you restart after it completes its action, your theme should stay the same. Hope this helps.
b>
Dec 15, 2012 | Computers & Internet
Hi there! hi bought a Samsung N150 2 mos ago and been trying to check how to apply a theme on it can u help me..please...i have window7
Hi claireespanu...
To change the destop wall paper, themes, resolution,etc on your computer do the following
Click on Start, the click on control panel, click on appearance and themes, then click on change a computers theme.
Please take time to rate me
Aug 29, 2011 | Samsung N150 (36725723009) Netbook
I'm trying to watch a movie off my laptop with my HDMI cord but no picture sound is coming up, how do i fix this the tv is a Panasonic PT-50LC14
It could be your laptops Video Output settings.
Go to Control Panel, Appearance and Themes
Then click on Display and then the Settings tab.
There should be some selections to change the output
Nov 26, 2010 | Televison & Video
How do i change my theme back to default
Here is a link to all the information on how to change themes in windows vista:
http://windows.microsoft.com/en-US/windows-vista/Change-desktop-theme
Thank you and enjoy,
Lee
Aug 12, 2010 | Acer Aspire 7520-5185 Laptop
Laptop cut off
Go to "Control Panel", click on it, then click on "Appearance and Themes" click on "Screen Saver", Look towards the bottom of the screen and find "Monitor Settings", click on "Power". Check to see if the setting have changed, I set all my settings to "Never", that way I can shut them down when I want to.
I hope this helped.
Please do not forget to rate me
Jan 22, 2010 | Toshiba Satellite A100-S8111TD Notebook
Hopw to change ur background ?
click on start then click on the control panel.in the control panel click on display .in the display click on the themes and from there you can change the background
Jan 03, 2010 | Acer Aspire One AOA150-1949 Laptop
Lenovo T61 - When I go to Control Panel and select Display, all I get is Themes tab. How do I restore the other display tabs?
In Windows Vista you right-click the desktop background, and select Personalize...
Select Display Settings to open the Display Settings window...
To change the appearance of the control panel...
When you first open the control panel, on the left side off the pane click Classic View to revert to the older style of the panel.
Nov 28, 2008 | Lenovo ThinkPad T61 Notebook
I changed my vista home premium laptops theme. I now cannot get into the theme setting in control panel without getting a run32dll error. Could you please help? Ss my start bar looks like XP and have tried...
sorry if this is obtuse but have you tried a system restore?
go to help and support and find "undo changes to my computer using system restore"
pick a date prior to the problem and voila all should be well
Sep 30, 2008 | Computers & Internet
Computers & Internet Logo
69 people viewed this question
Alun Cox
David Payne
David Payne
