I can light the pilot light ok but when i turn the knob up it blows the pilot light out again. The cooker that runs off the same gas bottle does not seem to be getting enough gas through either.
    Brigadier General:
  • 4,736 Answers
From what you have described, it sounds like a gas pressure problem, which may be related to the gas bottle's regulator. Or you are running out of gas and there is not enough to sustain both gas appliances. And finally, there may be an obstruction somewhere in the gas line. Even a kink in the gas line could cause it. These are the things you need to troubleshoot first.
Hope this helps you solve the problem.
Posted on Mar 21, 2011
Schematic patio heater sunjoy g ph018pss
You will not be able to blow through a gas valve when it's disconnected. You may have air in the lines which would cause the pilot to go off when knob is released if not held in long enough. Try lighting again. Once the pilot lights - hold knob in for 5 minutes then release. Try twice, if pilot will not stay lit it's probably the thermal coupler. (metal prong right next to flame of pilot burner.)
Mar 13, 2014 | Heating & Cooling
Pilot light keeps going out
pilot light keeps going out! more then likely its the thermal coupling doing this. if bad it shut all gas to heater for a safety measure. just shut power off, then turn gas off and replace it. then you should be ready to go. to relight heater hold down on gas vavle knob in the pilot position, hold down and light it at the coupling where gas comes out. when it is lit, continue to hold down for 60 seconds. release knob very slow. then if its lit, turn to the run position. if flme goes out, wait at least 5 minutes to expel the gas fumes and turn to pilot and try again. good-day !
Mar 31, 2012 | Water Heaters
Won't stay lit. can't keep running
If it has been cleaned and serviced annually, the Oxygen Depletion Sensor (ODS) is probably clogged with dust, dirt and/or pet hair. In which case, the ODS is reading the oxygen level in the room as unsafe for operation.
To clean clean unit will require that you take the front of the heater off. You will find screens on each side of the heater, as well as the top. Depending on which model you have and how old it is, you may find screws under the bottom of th heater.
Once you have accomplished the removal of the front of the heater, using a vacuum with a hose and brush attachment carefully vacuum as much of the interior, as well as the burner that you can safely reach with the brush attachment. Using a canned of compressed air with a straw nozzle (like you clean your computer with), blow out the tip of the pilot tip with a quick blast of air. Then look at the pilot assembly ... about 2/3rds down the pilot from where the flame comes out, you'll see a little hole in the side of the pilot. This is the ODS sensor. Place the straw nozzle just barely into that hole and give it a quick blast of air. More than likely, you'll see debris blow out the other side.
If you see any other dust or lint the vacuuming couldn't reach, blow that away with the canned compressed air. Then vacuum the unit again. Reassemble the cabinet and try lighting again. Make sure the control knob is sitting directly in the pilot position, by depressing the control knob down. If it doesn't go all the way in, it's not directly in the pilot position. Turn the knob a hair one way and then the other, unitil the knob wil depress completely. Push the ignitor button and if the pilot lights, hold the control knob in for at least 60 seconds, then slowly release the Control Knob. If the pilot lights and holds, wait another minute and turn it to the on position. If everything works like it should, you're back in business. If not try lighting it again. If the pilot fails to hold again, the Thermocouple will need to be replaced. Contact a local gas fireplace store in your area or is you use Propane Gas contact them for the Thermocouple replacement.
Keep in mind that DESA International is out of business, but some parts like the Thermocouple are still available. You''ll need the Model Number of your heater to be sure an get the right part.
Jan 31, 2011 | Desa International Heating & Cooling
Have Cozy heater model# CDV251A .Have spark , gas/but it will not light?
Be sure the control knob is set directly on the Pilot position. When you depress the knob, if it doesn't go all the way in (Bottoms out), release the knob and turn it a hair one way or the other, until you reach the point that it will bottom out when you push it in. If that doesn't solve the problem remove the front cover to expose the pilot assembly and blow out the pilot with compressed canned air (like you clean a computer with) and blow out the pilot tip. Any other dust or lint you see, clean that out too. Reassemble the cover and try lighting the pilot again.
Jan 26, 2011 | Cozy (W352E) Heater
We have a new gas bottle and new connection valve but the gas doesn't seem to be getting through to light.
IF YOU ARE SETTING GAS VALVE TO PILOT AND PUSHING DOWN BUTTON AND NO GAS TO PILOT YOU MY HAVE CLOGGED PILOT RESTRICTOR WHICH IS AT END OF PILOT TUBE WHERE YOU LIGHT PILOT ,REMOVE FITTING AND BLOW OUT DIRT. MOST RESTRICTORS ARE HARD TO GET OUT, JUST STICK PILOT IN SINK RUN WATER IN HOLE AND BLOW OUT WITH AIR PRESURE. DRY BEFORE RE -INSTALL. YOU SHOULD BE ABLE TO HERE HISS OF AIR BLOWING IN HOLE WITH LIPS.
Apr 19, 2010 | Williams 2509612 Ceramic Mid-Size Heater
I have an older monterey wall heater that is gas that wont seem to light. I cant even get the gas to start from the pilot can you help me?
You could have a plugged pilot line. You will need to get to the gas valve and shut the gas supply off. Once you did that, unscrew the pilot line that supplies gas to the pilot assembly. You can then turn on the gas supply and rotate the pilot knob to the pilot setting. Depress the knob into the gas valve. You should be able to smell and hear the gas come out of the hole where you unscrewed the pilot line. Don't do this with a cigarette in your face. Once you verify you have gas, release the knob and shut off the gas supply. Take a can of air and blow thru the pilot tube, first from the pilot assembly in the heater then from the open end of the pipe. Replace the pilot tube making sure you don't cross thread the fitting. Tighten well. Again turn on the gas supply, spray or rub some soapy water on the fitting you tightened, depress the knob and hold it. The soap will bubble up if there is a leak. Fix it. Now light the pilot.
Jan 20, 2010 | Heating & Cooling
I have a gas log fireplace, but can't get the pilot to light.
Hi right reconnect what you have undone and test the joints with a soap solution for gas leak first.
follow the pilot tube back to the valve to see if the is gas coming out of the valve there will be air first then gas try this , then let me know what you found plesae
Dec 23, 2009 | Desa International Unvented Gas Space...
My magic chef kitchen range oven won't turn on, no gas
Some of the models require you to push in the oven thermostat knob to set the pilot if it blows out. So try pushing in the knob and hold it while lighting the pilot. When the pilot lights continue to hold the knob in for about a minute. When you let go of the knob the pilot should stay lit. If it does not stay lit then try it one more time. If it continues to go out the thermocouple or aso might be bad and will need service.
Sep 11, 2009 | Magic Chef 31000 Gas Kitchen Range
Rangemaster 110 gas cooker - RH Oven lights but doesn't heat up
Will the flame go out if you turn the control knob to the off position?
Sometimes gas cooking control knobs have two seperate types of control in the one knob. One control turn the gas on or off, one adjusts the variable quantity of gas allowed through a gap to your flame jets. Some control knobs can get gummed up and stick a little. The can be fixed by carefully taking apart the control knob, taking note of EXACTLY how everything goes back together and cleaning any gummed up bits. Then reassemble the knob and drizzle soapy water over the control to test for leaks. A leaky gas join blows bubbles and makes noise. Let me know if this fixes the problem.
John
May 08, 2009 | Rangemaster 110 (Gas) Kitchen Range
No Hot Water in morning
Remove the cover then the access cover, then you can see inside,
the pilot light is probably out.
If out turn the gas off, then get a long match, grill lighter,or piece of paper ready to light, you should be able to see the little thin
gas line that runs inside the tank and see where it connects to,that is where you need to light, now that you see where to light, turn gas knob to pilot, and press down and at the same time light the pilot.
( blow into the pilot area before putting match inside to make sure no gas has built up inside) Hold down the knob for a minute then release, if pilot goes out try again and hold down longer, if you hold it for 3mins and it does not stay lite, the thermocouple is bad and you will have to replace it.
Apr 14, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
