Question about Dual XD6210 CD Player
Where can I buy a RCA Cable and/or adapter for my Dual XD6210 so that I may have it installed in a 2001 Hyundai Elantra?
  • 2,427 Answers
RCA cables like these can be brought from any electronic shop, no special rca cables are required ..
you do mean RCA right ?? this is what is looks like (below),, and can be brought from any electronic shop.its the same kind used to connect your dvd player to your tv. BTW these cables are only necessary when connection to an amplifier. other than that,, you have all ther wires you need on the unit, 2 power and 8 speaker wires. yellow is connected to the battery, red to the battery or ignition, black is the ground, and the pair colored wires are connected to the speakers. The unit ships with these wires so there is no need to buy them seperately. If you seek an adapter to convert the units electrical to your vehicles electrical you will not find it, It has to be connected via the wires. Simply clip the wires out of the old units adapter.
Posted on Mar 21, 2011
How do i change poer assist belt on hyundai coupe 2.0ltr 2001?
Check the attached links,similar models to yours power steering belt replace.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Install Replace Power Steering Belt 2001 06 Hyundai Elantra
Accessory Drive Belts Replacement 2001 Hyundai Accent
How To Install replace Alternator Belt 1999 06 Hyundai Elantra 2 0L
Mar 10, 2016 | Hyundai Cars & Trucks
How do I reprogram the key fob on my 2005 Hyundai Santa Fe without having to pay the fee at the dealership?
Well, you basically have only 3 choices:
1. Pay the fee at the dealership
2. Purchase the high-dollar equipment that is required to perform the programming procedure
3. Forget about adding another key fob to tor vehicle.
TECHNICAL SERVICE BULLETIN
Group
90 - ELECTRICAL
Number
03-90-020
Date
October, 2003
Model
Elantra 2001-2004, Santa Fe 2001-2004, Sonata 2002-2004, Tiburon 2003-2004, XG(NNN) NNN-NNNNand XG(NNN) NNN-NNNN2004
Subject
SECURITY SYSTEM KEYLESS ADAPTER CABLE
This bulletin supersedes TSB # XXXXX
DESCRIPTION:
The security system keyless adapter cable (SPX/Kent-Moore P/N 09900-21300) is a special service tool (SST) that is used for programming new keyless entry remote transmitters to the factory security systems. The keyless adapter is used in conjunction with the Hi-Scan Pro (with Hi-Scan SOL Pro Software Version 09-29-03 or newer) and Data Link Connector (DLC) Cable.
SERVICE INFORMATION:
The keyless adapter cable can be used on the following vehicles:
^ 2001 -2004 Elantra
^ 2001-2004 SantaFe
^ 2002 - 2004 Sonata
Apr 24, 2011 | 2005 Hyundai Santa Fe
How do I fix a low idling on 2002 elantra
there will be a screw buy the throttle cable in the engine bay, i ask why do you want to up the idle revs if it runs fine at them revs
Aug 15, 2010 | 2001 Hyundai Elantra
+ Battery cable replacement 1999 Hyundai Elantra
make sure your radio and ignition switch is off.first you disconnect negative cable first then the positive cable.then you replace new positive battery cable first then you hook the negative battery cable back up last.
May 11, 2010 | 2001 Hyundai Elantra
Where is located speed sensor for hyundai elantra 2001
its located at the transmisson, were the drive cable would go
Mar 09, 2010 | 2001 Hyundai Elantra
2001 hyundai elantra, replaced timing belt, all marks are aligned, engine tries to start but will not catch.
Did the car run before belt installation? Need to give all info if you want a informed answer 15 year Hyundai tech
Nov 02, 2009 | 2001 Hyundai Elantra
Program factory remote keyless entry for 2003 Hyundai XG350
This bulletin supersedes TSB# 02-90-001.
DESCRIPTION: The security system keyless adapter cable (SPX/Kent-Moore P/N 09900-21300) is a special service tool (SST) that is used for programming new keyless entry remote transmitters to the factory security systems. The keyless adapter is used in conjunction with the Hi-Scan Pro (with Hi-Scan SOL Pro Software Version 09-29-03
or newer) and Data Link Connector (DLC) Cable. SERVICE INFORMATION: The keyless adapter cable can be used on the following vehicles:
  • 2001 - 2004 MY Elantra
  • 2001 - 2004 MY Santa Fe
  • 2002 - 2004 MY Sonata
  • 2001 - 2004 MY XG300/350 0390020a.gif
NOTE
  • The 2003 - 2004 MY Tiburon does not need the Keyless Adapter Cable to add keyless entry remotes to the factory security system. Instead, the Hi-Scan Pro connects to the vehicle using only the DLC cable. See page BE-60 in the 2004 MY Tiburon Shop Manual for the latest instructions.
  • The most current Keyless Adapter Cable Instructions are available in the following shop manuals:
SHOP MANUAL
PAGES
2004 MY Elantra
BE-73 - BE-74
2004 MY Santa Fe
BE-43 - BE-44
2004 MY Sonata
BE-40 - BE-41
2004 MY XG350
BE-46 - BE-47
KEYLESS ADAPTER CABLE INSTRUCTIONS:
  1. Connect the keyless adapter cable to the Hi-Scan Pro DLC cable. 0390020b.gif
  2. Plug the keyless adapter into the vehicle's 10-pin multi-purpose connector located behind the driver's side lower instrument panel (next to the DLC). NOTE Sample vehicle shown is the Santa Fe.
  3. Turn the Hi-Scan Pro ON
    and press ENTER
    . NOTE "Release date 29. Sep. 2003" OR LATER
    must appear on this screen. To update your SOL card with the latest software go to www.hmaservice.com and refer to TSB 00-00-001.
  4. Select option "HYUNDAI VEHICLE DIAGNOSIS"
    and press ENTER
  5. Select vehicle model and press ENTER
  6. Select option "TRANSMITTER CODE SAVING"
    and press ENTER
  7. Ensure that the key has been removed from the ignition cylinder before proceeding. 0390020h.gif
  8. Follow the steps noted on the Hi-Scan Pro screen to program the remote(s). NOTE The factory security system can only be programmed to accept two remote transmitters and MUST be programmed for both remote transmitters at the same time.
  9. Press ESC
    on the Hi-Scan Pro and verify that the remote(s) are functioning properly.
  10. Turn the Hi-Scan Pro OFF
    and disconnect the adapter cable from the multi-purpose connector.
May 22, 2009 | Hyundai Motor 2003 XG350
Rear window break light
You either have a 'single filament' bulb installed in a 'dual filament' brake lamp socket ... OR .. you have a 'dual filament' bulb short circuited internally. Check your rear brake lamp bulbs (supposed to be 'dual filament' - two contacts on their bottoms). When you step on the brake pedal, do your dash lights LIGHT UP? A 'cross circuit' exists between brake lamp circuit and parking lamps circuit.
Apr 15, 2009 | 2001 Hyundai Elantra
I Locked my keys in my 2001 Hyundai Elantra
wellits a smilple thing they have this round wire with a handel and they will yake the strip of ur driver side window don't worry it can be put back no need to buy a new one . and he will push the wire that is connecting both the handels and then open ur door.
Oct 22, 2008 | 2001 Hyundai Elantra
Dual XD6210 CD Player Logo
98 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
