Question about LG WM-2277HW Front Load Washer
How do I get my machine to just spin a load? It became unbalanced and I adjusted it and now just want to spin the water out?
  • 1,543 Answers
Turn power on. Without selecting a cycle, push the spin speed button to select the spin speed you desire. (if you had an unbalanced load, I'd suggest a low spin speed. You can repeat after with the next higher speed if desired) Push start.
This will give about a 12 to 14 minute pump and spin only cycle.
Posted on Mar 21, 2011
3 Suggested Answers
olddewsons
  • 38 Answers
SOURCE: whirlpool lsr8233eqo machine won't agaite or spin will drain
check belt,it mite of came off when unbalance.
or if it is a 2009 model,unplug wait 30sec. plug back in. hope this helps.
Posted on Oct 04, 2009
  • 713 Answers
SOURCE: unbalanced load- spin cycle stopped . cannot get machine to start
Hi just read your posting .Do you still require help?If so reply back and I am sure I can help you.
Posted on Jul 16, 2010
Unbalanced load
it could be your pump blocked and not discharging the water it will become unbalanced not spin
Nov 22, 2011 | Whirlpool WTW6400SW Top Load Washer
On the spin cycle, it makes a banging noice, rythmic, about 2 per second....only on the spin cycle... can you help???
The spin cycle is used to rid the water by centrifugal force. As the tub spins, the water iis forced out of the clothes. The banging noise comes from the weight of clothes being on one side making the load unbalanced. The machine will absorb some minor unbalancing. If it gets real loud & the machine starts dancing, shut the machine off by raising the lid, when tub stops, rearrange clothes.
Louie Almond
Mar 27, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My sleve is stuck in the spinning deal of my washer, how do i get it out?
Remove the rinse dispenser from the top of the agitator (spinning deal). Unscrew the agitator cap located on top of the agitator which is only hand tightened. Once the plastic agitator cap is removed from the top of the agitator you should see a screw which you will need a socket or an adjustable wrench to remove the screw. The agitator can now be removed by lifting strait up to free the sleeve. My only concern is how the sleeve became lodged under the agitator unless the tub became unbalanced from a heavy load. The other possibility could be the support for the tub is broken and needs to be replaced.
Feb 15, 2011 | Admiral AW22 Top Load Washer
I have a maytag washer i bought in 97. It became unbalanced well my husband fixed it and everytime it goes on the spin cycle it gets unbalanced again and makes a very loud noise
If the washer is truly balances (check with a level to be sure) you might just have an unbalanced load. When filling your machine with laundry, think of the tank as a big circle divided into four pie slices. Make sure you fill each of the four slices evenly. This should help,
Nov 04, 2010 | Maytag Washing Machines
Unbalanced load- spin cycle stopped . cannot get machine to start
Jul 12, 2010 | Fisher and Paykel IWL12 Top Load Washer
Whirlpool lsr8233eqo machine won't agaite or spin will drain
Oct 04, 2009 | Whirlpool Washing Machines
Describe your Kenmore 24032 \ 24036 Top Load
MAke sure that the cothes are not unbalancing the tub. Iv seen this happen where the clothes are unbalancing the tub and it moving around and the when the water for the rinse is coming out its not getting in the tub its splashing on the top of the tub ring due the the unbalanced spin. does this happen when you wash a heavy load? do you notice it not doing that when you washer a light load?
Jul 26, 2009 | Kenmore 24032\24036 Top Load Washer
My Washer will work at all. It acts dead
a small run of these actually had an out of balance switch and fuse assembly that cut power to the machine if it went way out of balance ,check and see if yours has one and replace the fuse at first but you may have to replace the entire assembly
Feb 06, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag LAT2500AAE- unbalanced
see if it has 4 adjustable feet on each corner on the bottom
get a bubble level from a hardware store and turn the feet to raise or lower OR you could use something else to raise the sides until it is leveled by looking at the bubble level.
hope this helps
thanks for your rating
Jan 09, 2008 | Maytag PAV2300 Top Load Washer
Spin Shake ...
yes the water is supposed to be there, thats called the balance ring, some machine use cement others water. you say the washer is unbalanced even when empty, is there an indicator or is the machine itself physically off balance. if there is an indicator the off balance swich might have gone bad or you might need to adjust the leveling legs.
Jul 03, 2007 | Frigidaire CWS3600AS Top Load Washer
LG WM-2277HW Front Load Washer Logo
196 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
