Question about Pioneer GPS
I can not get my head unit mode DEH-P6500 I can not figure out how to turn mute off..
  • 6 more comments
  • skater4life4 Mar 21, 2011
    I can switch between mute or att. but if i turn att on i have sound but no volume control or its muted.
    I dont really know how to use this site so if im doing it wrong i am sorry i can switch bettween att and mute but theres no off options and in att mode i cant control the volume.
    i was on my phone prior to it becoming muted i never like synced it somehow to the head unit i do not even know how to do that. The phone is actually turned off in the house and still no change i have referred to the manual.
    I have searched hi and low for the reset button and couldn't find it i am currently trying the old school reset of disconnecting the battery and removing the fuse.
    Oh nothing changed im going to have to take it to a shop i think something is not right.
    I cant find that button for the life of me unless its on the back of the whole unit maybe?
    I even busted out the flashlight brighten it up and i could not find it. I guess its kinda an old model were is your button located.
    Im in the USA ill need to look at it during the day i guess thanks for your impute.
  • 3,530 Answers
Welcome to Fixya
Press Function to select Telephone. Press function repeatedly until telephone appears on the display.
Press the back and forward arrow to switch the telephone muting/attenuation. Please click here fo the manual then go to page 34 for further details.
Thank you for using Fixya!
Posted on Mar 21, 2011
  • 5 more comments
  • Jose Cada
    Jose Cada Mar 21, 2011
    Did you use your mobile phone for this unit? Have you checked page 34? The unit will be muted or attenuated when you are making phone calls or receiving calls. Normal operation will go back once you ended the phone call.
  • Jose Cada
    That's weird. try to reset the head unit to factory default settings. take note that all settings will go back from the first time you open the unit out from the box. here's the procedure:
    Press the release button on the front of the radio the drop the front panel, then remove the front panel by pulling it away from the unit.
    Locate the reset button, which is a tiny button labeled "Reset."
    Push the reset button using the pointed instrument to reset the unit.
    Replace the front panel by inserting the left side into the unit first, then pressing the front panel into place.
  • Jose Cada
    yeah you can do that also.. let me know what happened after disconnecting the battery.
  • Jose Cada
    resetting the unit should work. i bet there is something wrong with the unit.
  • Jose Cada
    every DEH unit have that button..i am not quite sure how yours doesn't have that. Mine is DEH-7450.
  • Jose Cada
    right before the hinge. i guess it was manufactured in a different way in your country. disconnecting the battery should work. i put mine on ATT/Mute then disconnect the battery then put it back in. the unit reset to factory default. There is definitely a problem with your unit.
  • Jose Cada
    I'm from the philippines. Try to check at the back of the unit just to make sure.
I NEED A WIRE HARNESS FOR A PIONEER DEH-P6500, IS
try pacparts.com. any good car audio store should probably have it
also.
Jul 22, 2010 | Pioneer DEH-P6500 CD Player
Pioneer DEH-P6500 head unit doesnt turn on
Check your radio fuse. It is likely if you didn't disconnect your battery terminal that you may have blown a fuse.
About the speaker distortion, you may need to install filters to each speaker. They are not very expensive and can be found at just about any electronics store.
Feb 26, 2010 | Pioneer DEH-P6500 CD Player
Display flashing on my deh-p6500
It has what is called reverse mode which flashes to protect the display to turn feature off please follow these steps.
Press the 5 numbered button when power to this unit is turned off while the ignition switch is set to acc or on will cancel the reverse mode and stop the flashing. Hope this helps.
Jan 06, 2010 | Pioneer DEH-P6500 CD Player
XM radio portion just quick working..display on DEH-P6500 reads "antenna"..any things we can try out?
No experience with this issue, but in your shoes I would check the satellite antenna connection into the back of the unit. From there, I would chase the wire and make sure it is not frayed. If that does not resolve or lead to a resolution of the issue, borrow an XM antenna and see if it will work then. If not, then something has happened internally with the head unit, most likely at the antenna connection jack.
Jan 03, 2010 | Pioneer DEH-P6500 CD Player
Pioneer service center
Have you tried,
HAYNES ELECTRONICS
586 WEST CAROLINA AVENUE
HARTSVILLE, SC 29550
US
(843) 332-4878
Jan 25, 2009 | Pioneer DEH-P6500 CD Player
Need color codes and wiring diagram for a 2003 Pioneer DEH-P6500
The wiring colors are the same on all major brands of head units it goes a following:
Red: swtiched +12
Yellow: constant +12
Black: ground
Orange/white: dimmer
Yellow/black: cell phone mute
Blue/white: amp turn-on
White:FL speaker +
White/black:FL speaker -
Gray: FR speaker +
Gray/black:FR speaker -
Green: RL speaker +
Green/black: RL speaker -
Violet: RR speaker +
Violet/black: RR speaker -
I hope I could help. Good luck
-Andrew Hawkins
Aug 20, 2008 | Pioneer Car Audio & Video
Cellular mute button
The yellow/black wire at the back of the head unit may be grounded. Make sure it's not pinched or shorting on anything.
Feb 27, 2007 | Pioneer DEH-P6500 CD Player
Mute
do you have anything hooked up to the mute cable? if not make sure you have black tape around the open end
GPS Logo
105 people viewed this question
Top Pioneer GPS Experts
David Burbee
David Burbee
Are you a Pioneer GPS Expert? Answer questions, earn points and help others
