Question about ASUS P5PE-VM Motherboard
Sir i have MIC2_L,AGND,MIC2_R,PRESENSE#,HP_R,MIC2_JD, JACK_SENSE,HP_L,HP_HD in my motherboard (asus p5pe) but in front audio wire there are only five pins MIC_IN ,MIC_GND,SPK_GND, R-RET,L-RET. and i am not able to connect these. please help me to connect these wires.
3 Suggested Answers
  • 207 Answers
SOURCE: asus p5pe-vm front panel audio connector (10-1 pin FP_audio)
jumper setting for audio panel? i didnt get tht one
Posted on May 22, 2008
bad_theta
  • 31 Answers
Look this picture below, this is ASUS P4VM front panel.
Hpe its solve your problem....
Posted on Jun 01, 2009
Trying to find sound chip so i can restore my sound on my computer. i loaded windows 7 professional and i have an intel asus p5pe-vm mother board. need help please
This is just simple way. Just connect your front panel audio plug connector with your mother board audio socket.
In your motherboard there are several chassis-mounted functions. For your help i add a motherboard layout image.
Jul 03, 2016 | ASUS P5pe-vm Motherboard Intel 865g Lga...
I have an Asus P5QL PRO Motherboard and I'm trying to connect the FP audio and I need some help on how to connect it up properly. On the heaphones lead I have 4 connectors: EAR R EAR L RETURN...
Hi
Pin arrangement for Front panel Audio is usually:
Pin 1 Left MIC-IN Pin 1 right GROUND
Pin 2 Left MIC VVC (or MIC Power, or MIC BIAS) Pin 2 Right empty
Pin 3 Left R EAR (or R OUT) Pin 3 Right R RETURN
Pin 4 Ground or Empty Pin 4 Right empty
Pin 5 Left L EAR (or L OUT) Pin 5 Right L RETURN
This arrangement should apply to both the HD AA/FP or the Standard AC'97 Headers.
I hope this helps
Aug 28, 2011 | ASUS P5QL PRO Motherboard
Front panel power switch & led'S pinout
asus web site download manual for a p5pe-vm thats all you need
Apr 30, 2010 | ASUS P5PE-VM Motherboard
How to connect audio from motherboard p5s800
It is Asus P5S800-VM motherboard. Download the manual from Asus, click the link provided;
http://www.asus.com/Search.aspx?SearchKey=P5S800-VM
You'll need to download and install Adobe reader to view the manual;
http://www.adobe.com/products/reader/
Turn to page 1-29. Section 11. Front panel audio connector (10-1 pin FP_Audio1). Notice there are two jumpers. One across pins 9 and 10. Another across pins 5 and 6. Pin one is marked, AGND and pin two is marked MIC2. ECT.
This is default setting when using the rear audio jacks. You can not run rear audio and front audio at the same time. (So pick one or the other). To run front case audio remove the jumpers and connect the I/O cables to the FP_Audio1 pins. There is a work around. You can buy an adapter that will split the audio from the rear allowing you to connect secondary audio and mic ports. Open the link provided;
http://www.cablestogo.com/product.asp?cat_id=2009&sku=40422
You can buy these locally. To connect the FP_Audio remove the jumpers and connect the I/O cable to FP_audio pins. Use Adobe reader and zoom in. You'll find each pin is marked.
Cheers'
Mike
Mar 08, 2010 | Computers & Internet
Asus p5pe-vm front panel audio connector (10-1 pin FP_audio)
Nov 26, 2008 | ASUS P4S533 Motherboard
Audio deosn't work on mobo
Hi Chris, the problem can be one of two issues. If the sound jack located at the back of the PC did function at the same time as the front case sound jack. Than the problem is the jack it's self is bad. (Back of PC). Someone had to hook up the front mic & sound jack to the motherboard. So disconnecting the front sound & mic may give you rear sound & mic.
Turn to page 2-29 in you're user manual for the Asus M2N-SLI. The pic shown is the default setting for the front case audio & mic. (What you do see are the two jumpers connected). So disconnect any connector & place a jumper over pins 9 & 10, (last two pins at the right of the two rows of pins). Place another jumper over pins 5 & 6.
Pin 1 is the first pin on the left bottom row (MIC2). Pin 2 is the first pin, left edge top row (AGND). Pin 8 is not installed but you still count its spot as if there was a pin. (This is how the board was setup from factory). Once you fix this you should regain sound & mic function at the rear of the PC. To fine tune the audio run the Asus sound effect manager. If you installed this software, (Recommended). If it’s not by you're clock than it’s in control panel.
Link to all for M2N-E SLI
http://support.asus.com/download/download.aspx?modelname=M2N-E%20SLI&SLanguage=en-us
Good Luck!
m
Jun 07, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Front audio in casing
The front panel audio for this board is labelled FP_AUDIO and is on the bottom left hand side of the board. See page 39 of the following; http://dlsvr03.asus.com/pub/ASUS/mb/socket775/P5PE-VM/e2609_p5pe-vm.pdf They're all labelled correctly. In your case, L-out - Mic2_L, L-ret - Mic2_R etc
May 29, 2008 | ASUS P5PE-VM Motherboard
F_AUDIO <==> CASE
1- PORT_1L == MIC_IN
3- PORT_1R == MIC_PWR
5- PORT_2R == R_OUT
9- PORT_2L == L_OUT
-------------- OTHER SIDE ------------- (case wire)
2- GND
4- GND (other)
6- R_Return
8- key
10- L_Return
May 16, 2008 | ASUS P5PE-VM Motherboard
Front audio connections
OK, let the speaker cable be your guide, its a for pin female connector, form there you should find your way.
let me know
Dec 15, 2007 | A-Top XBlade Mid-Tower Case
ASUS P5PE-VM Motherboard Logo
204 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
