Question about JBL GT150 Car Subwoofer
Hey my SUBWOOFER is making noice (like bhur bhur), its nor working properly
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 108 Answers
The regulator or the audio ic may be colapsed.replace them .
Posted on Mar 22, 2011
Hi my note book just makes bleeping noice and black screen when turned on.
hey
the beeping noise is an error message here are some common beep errors
http://www.computerhope.com/beep.htm
finding out what the exact error is will help you in towards the proper troubleshooting action
cheers
djbr1ck
May 13, 2011 | Dell Inspiron Mini 10 Notebook
Hello, \r\nI have a 2003 dodge neon SE. I hear a loud roaring noice and vibration from the front end, the noise is really loud (like a truck) when I start it. When Car in drive the noice is loud but when I...
Hey Shona... Please take your car to a qualified professional... this could be something very serious related to safety.. do not take a chance.. let them diagnose your problem..please...
Jul 14, 2017 | 2003 Dodge Neon
My Z5500 logitech subwoofer makes weird noises similiar to thunder, it doesn't matter is there input or not. it just makes "thunder" noices all the time and wont *******. what is wrong in it?
Most likely its broken... if its less than 3 years old, call logitech, they'll send you a whole new system for free without you having to return the old one. Just make sure you have your receipt.
Feb 27, 2011 | Logitech Z-5500 Computer Speakers
Panasonic sb-wa 340 active subwoofer has just low freequensy noice from subwoofer ! The other speakers working good and dvd fanction normally !
This is normal operation.. The subwoofer will only play sounds below a set frequency...There may be a crossover setting in your menu that you can adjust the frequency cutoff to your liking.
Oct 01, 2010 | Panasonic SC-HT690 System
Does not want to work
to make sure it's the subwoofer at fault and not the amp, speaker wire, rca's, radio, power, or ground wiring, you should, if possible, hook up a known good subwoofer to see if it works properly. if it doesnt, check fuses, grounds, the remote amp turn on wiring, etc. it could even be something as simple as a setting on the stereo itself. if the substitute subwoofer does work properly, double check to be sure the original sub is wired correctly. if it is, i'm afraid you've got a faulty/bad subwoofer. I hope this helps and good luck!
Feb 17, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
My nail gun makes a small noice but will not shoot. The battery is charged but it is not doing any thing. The first thing it did before it quit was worked fine for ten nails. Then it just made a faint...
I know a lot of Dewalt nailers will not shoot properly once the battery is starting to get a little worn/has a lot of charging cycles on it. Their picky about having fresh batterys. How old is the nailer/batterys?
Dec 13, 2009 | Black & Decker 16GA Finish Nailer Kit
JBL subwoofer PSW-D115
Hi Im a Certified Repair technician, I seen few problems with this unit, there is a amplifier module inside this unit, is really hard to find since JBL discontinued this almost immediately.
Sorry no really worth to bother........
Apr 10, 2009 | JBL PSW-D112 Speaker
Velodyne subwoofer
First make sure that the cables are properly connected up. Make sure that the output of the amplifier feeding the sub is working properly and has no faults.
If the above is okay, it is possible that the power supply in the sub, and or the output stage has a failure. In this case the sub will require shop service to have it working again.
Jerry G.
Jun 12, 2008 | Velodyne DPS-12 Subwoofer
SP-PWM505
MOst of the time it is the jack that the cable plugs into that has the problem. .
Also the jack is not broken but HAS broken the solder connection TO the jack.
If you know someone who can safely take it apart and solder, let them try.
Feb 07, 2008 | JVC TH-M505 System
No signal on subwoofer out in Onkyo TX-SR703(E) - similar to TX-SR803
Hey Tad, I have the same problem and perhaps a solution. I just moved to the other SW "pre-out" and it seems to be working..the green light is on . Whatever works i guess.
Jan 24, 2008 | Onkyo TX-SR703 Receiver
JBL GT150 Car Subwoofer Logo
37 people viewed this question
Top JBL Car Audio & Video Experts
hoyzee1
Rob Beech
Steve Sweetleaf
Steve Sweetleaf
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
